Outer tie rod adjustment/lock/jam nut?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itsgottabeyourbull, Aug 21, 2022.
  1. Aug 21, 2022 at 11:11 AM
    Itsgottabeyourbull
    Itsgottabeyourbull [OP] Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    Does anyone know what size the outer tie rod adjustment/jam nut is? mine is completely seized. Tried heat, pb blaster and etc.
    Any info would great be appreciated
  2. Aug 21, 2022 at 11:12 AM
    Itsgottabeyourbull
    Tulsa Oklahoma
    Picture for help
  3. Aug 21, 2022 at 11:17 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Screw pblaster, use atf
  4. Aug 21, 2022 at 11:20 AM
    Itsgottabeyourbull
    Tulsa Oklahoma
    Trying now but would rather just go buy if available
  5. Aug 21, 2022 at 11:34 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Did you modify that rubber bed liner to fit your 1st gen?
  6. Aug 21, 2022 at 1:21 PM
    Itsgottabeyourbull
    Tulsa Oklahoma
    Hahaha great eye sight and yes. Had a 2017 Tacoma and sold it for the tundra than bought my 1st gen. The rubber Matt almost fit but required very light cutting to fit
  7. Aug 21, 2022 at 1:56 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    27mm. It was a hard wrench to find for me at least. The long handle set at Harbor Freight goes up to 26mm, the jumbo set only goes down to 35mm. The service wrenches have a 27mm, but it's probably too short for that job. I ended up buying a 27mm Husky wrench at Home Depot.
    Your real issue might be holding the tie rod end enough to be able to torque on that nut. If you don't have a vise it might be worth finding someone that does.
  8. Aug 21, 2022 at 1:58 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Just buy new from Toyota. low Range Off-road had them too. It’s basically a consumable if you are hitting it that hard at this point
    Bivouac likes this.
  9. Aug 21, 2022 at 2:47 PM
    Nessal
    Texas/Bay Area
    I bought that liner and saw that it was tight near the wheel arches. I didn't want to modify it so i ended up selling it. I thought maybe you got one that didn't need modification.
  10. Aug 22, 2022 at 8:45 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you don't have a vise, put a pipe wrench on the straight part of the OTR while you turn the 27mm nut. Use penetrating oil. You may have to turn the nut ever-so-slightly in the "out" direction and then tighten it again a few times to get the rust to loosen up. Again, use plenty of penetration oil (or ATF as one of the other guys here suggested). Patience here will save you $50 plus shipping for a new OTR.
  11. Aug 22, 2022 at 9:10 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  12. Aug 22, 2022 at 9:27 AM
    Jakuku Pahwheenis
    J Phoenix
    South Carolina
    Coworker here has a coffee cup with a PBlaster label on it. I told him PBlaster ain't shit, ATF FTW.
  13. Aug 22, 2022 at 9:40 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    New part should come with a new jam nut. Mine always have.
  14. Aug 22, 2022 at 9:53 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is not correct. OEM does come with a castle nut and cotter pin, but not a jam nut. The 555s from TrailGear/Wheelers/LowRange also do not come with a jam nut.
  15. Aug 22, 2022 at 9:59 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    As previously stated. Mine have always come with new hardware. Try Napa.
  16. Aug 22, 2022 at 10:30 AM
    Itsgottabeyourbull
    Tulsa Oklahoma
    Castle nut and cotter pin but no jam nut. OEM doesn’t come with jam nut
  17. Aug 22, 2022 at 10:56 AM
    Digiratus
    Roaming the PNW
    The RedHead
    No thanks.
  18. Aug 22, 2022 at 12:56 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Your truck your call my guy.
  19. Aug 24, 2022 at 7:06 PM
    Ž@¢K
    Ž@¢K Farts a lot..
    Ky
    2003 Tacoma TRD 4dr Prerunner 4wd conversion
    6”rough country lift, 35” bfg mud terrain, step bars, home made solid 5" bull bar frame mounted top and bottom with gussets ( used an excavator to completely suspend the truck in the air held only by the bull bar), 180k, no rust, no leaks, no cel's, no issues. 4wd conversion with front and rear e-lockers.
    I got outer and inner and came with castle. Codder, thrust washer and a thick jam nut and a thin jam nut.. i think theyre both jam nuts .. not sure though because the ball that goes into the knuckle didnt have anything between tge boot and knuckle so when i tried to tighten the castle nut on i couldnt get it past hand tight without pancaking the damn boot. Got dark and mosquito blood suckers got too thick so i had to quit for the night.. went all kinds of wrong. Old outer came off with 14 turns. New one goes on with 14 and thing is pointed towards the other tire.. so between that and the castle nut thing i know i screwed it up.. parts were exactly the same size and thing so i dunno why it went on like it did. And not sure why the inner came with what looks to be a jam nut and outer came with one also..
