Out of the loop for years, what should a 2.4 clutch replacement cost?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1996_2.4, Oct 24, 2022.
  1. Oct 24, 2022 at 9:06 AM
    1996_2.4
    1996_2.4 [OP] Well-Known Member
    Last time I had a clutch replaced was 10 years ago, $500 for lifetime clutch and no tax (Oregon) on a Camry.
    Couple of questions since I'm at their mercy and no one will quote me a price over the phone:
    1) In Tigard, Oregon area, what is a decent price to put in a clutch on my 2.4?
    2) From what I've learned on this forum, my slave cylinder is what's causing my clutch pedal to be stiff as hell. What's a fair price to get slave cylinder replaced? I'd fix it myself if I was physically able, believe me.
    3) What's a fair price for both master & slave cylinder replaced?
    Finally, can anyone recommend a shop in the Tigard area? Very grateful for all the advice I've found on here.
  2. Oct 24, 2022 at 9:58 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    If you have a 4x4 and need flywheel. Probably be around $1500+. If not 4x4 it will be less and if your flywheel can be resurfaced even less. That’s in California too most likely high estimate being your in Oregon.
    1996_2.4[OP] likes this.
  3. Oct 24, 2022 at 10:34 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its fair that shops don't want to quote over the phone. Sometimes it may just need a clutch and flywheel, or it might need hydraulics too. If they quote too high to cover their butts (hydraulics AND clutch kit for example) they'll sound expensive and scare you away. If they quote too low, they risk having to do part of the job for free just to get it all done and driveable.
    The days of sub 1,000$ clutch jobs is over. If you're 4x4 I'd expect at least 1,500 minimum
    Gamma11 and 1996_2.4[OP] like this.
  4. Oct 24, 2022 at 7:07 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    His 2.4 only comes in rwd......2rz.....
  5. Oct 24, 2022 at 7:11 PM
    1996_2.4
    Yes it's the basic 2 wheel drive, 1996 2.4. You'd think this would be the cheapest clutch to replace since it's neither front wheel drive or four wheel drive.
    I'm thinking since it shifts and drives fine that it's not the clutch, but the pedal is stiff as hell, maybe shot slave cylinder.
    So what's a fair price to just replace a master and slave cylinder these days? Wish I was 18 again, I'd do it myself after school and be driving again in an hour lolz.
  6. Oct 24, 2022 at 7:40 PM
    Smokestacks
    BayArea
    I’m not familiar with that layout. But Does it go into gear alright? Can you make that clutch slip? Or If your main problem is the stiffness of the clutch pedal?
  7. Oct 24, 2022 at 7:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does a "fair price" even matter if you're just throwing parts at it?
    Usually the only way for a slave to fail is by leaking. If it isn't leaking it's probably fine. I guess it could seize up internally but that's gotta be pretty rare.
    If you're feeling increased resistance like something is binding I suspect something inside the bell housing, like a release bearing sticking on the quill or a clutch fork sticking on the pivot.
    I've seen the pivot wear a hole in the clutch fork and start to go through it. Then it's stuck and doesn't want to hinge back and forth
    ArizonaBrian and Smokestacks like this.
  8. Oct 24, 2022 at 11:16 PM
    1996_2.4
    Shifts perfectly with no noise or slips, even when I go hard on it. But it damn needs both feet to push the stiff clutch pedal down, so I'm sure it's a busted slave cylinder. How much should that cost to fix on a 2WD?
  9. Oct 25, 2022 at 5:37 AM
    lilmanjo_
    lilmanjo_ Lord of the Porch
    Jo
    2001 TRD 4x4 3.4/MT
    I bought my own parts and with labor it was around $500. I guess it kinda depends on where you live and who does the work
  10. Oct 25, 2022 at 6:55 AM
    Smokestacks
    BayArea
    For your truck around $300
  11. Oct 25, 2022 at 10:46 AM
    1996_2.4
    Took it to a shop today and they said there was nothing wrong, my knee is just too thrashed to press the clutch.
    lilmanjo_[QUOTED] likes this.
  12. Oct 25, 2022 at 3:08 PM
    O'Silver_Taco
    MD
    You're gonna have to switch to Tiktoc videos.......they can help you from there....
  13. Oct 26, 2022 at 8:51 AM
    Carguy41
    Carguy41 New Member
    I recently had my master cylinder and slave cylinder replaced at a Toyota dealership for $600 total OTD. Slave cylinder was $185 and master cylinder was $415 for a 97 4x4
  14. Oct 26, 2022 at 9:37 AM
    1996_2.4
    You are brave. I heard dealerships really rob you as much as possible over an independent shop.
  15. Nov 16, 2022 at 3:29 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    This isn’t exactly what you asked but I recently did my own in my driveway but only because my rear main seal was leaking and I had to be in there anyway. I bought a kit from Rock Auto and think with the cost of resurfacing the flywheel it cost me $200 total. It was all the labor and other things that had to be done to get to that point that was difficult and would have made it expensive.
    Don’t pay for a shop’s overhead for mere donkey labor if you can help it, especially the stealership. Plus when you do it yourself you can take your time and ensure it’s done correctly, not merely to make someone else money. I understand however that this isn’t an option for everybody.
    Good luck.
  16. Nov 16, 2022 at 9:18 AM
    1996_2.4
    Thanks for the advice, but I'm 60 years old with a shot left elbow. If I was 18 I'd be all over it and get it done after work and drive it the next day :)
    Sfish2002 likes this.
  17. Nov 16, 2022 at 9:59 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    what is a lifetime clutch? :confused: and where can I find one lol
    Clutch jobs aren't cheap at shops, the parts are relatively cheap but the labor charge is what gets you. For my truck, most shops about 6 years ago wanted anywhere from $900 - $3k to do a clutch job on my 04. The $3k was a dealer quote.
    1996_2.4[QUOTED][OP] likes this.
  18. Nov 16, 2022 at 10:00 AM
    eon_blue
    Azusa, CA
    I would have them to do the rear main seal while they're in there, for peace of mind. Since the transmission has to come off anyway.
    edit - nvm, just saw that the clutch wasn't the issue.
  19. Nov 17, 2022 at 7:23 AM
    1996_2.4
    The lifetime clutch was a deal from clutch doctors here in oregon. you have them put in a clutch and the parts were replaced free forever, you just had to pay for the installation
    eon_blue likes this.
  20. Nov 17, 2022 at 9:35 AM
    eon_blue
    Azusa, CA
    Ah, I was hoping someone somehow invented a clutch/flywheel kit that never wears down :(
