(OUT OF STOCK) Viper 4806V 2-Way LED Vehicle Remote Starter Kit w/ Installation.
Discussion in 'Deals & Coupons' started by Hoangde, Jan 28, 2017.
  1. Jan 28, 2017 at 8:57 PM
    Hoangde
    Hoangde [OP] Well-Known Member
    stbear likes this.
  2. Jan 28, 2017 at 8:59 PM
    Paint6it9black
    Paint6it9black Well-Known Member
    Rob
    Easton, Pennsylvania
    2011 Tacoma TRD Sport
    OME 3" lift in front Extended Kings in rear Dakar leaf pack Shackle Flip 1” body lift All-Pro front bumper All-Pro Apex rock sliders Kore 4x4 Custom HC rear bumper Window Tint 5% Mesh Grille (homertaco) Rigid Industries led fog lights Fog light anytime mod Rear Diff breather mod CB Radio Safari Snorkel Home Made tire carrier (not by me) 37's Cut, Bashed and Dented Freedom SS pillar lights Smittybilt x2o 10k winch synthetic U-Bolt Flip RCI Full Skids 2" cut off fenders Front and Rear ARB lockers Geared 4:88 On board air with 2-1/2 gallon tank Relocated cab mounts
  3. Jan 28, 2017 at 9:01 PM
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    That's a start, give me a few mins lemme pull the write up I have and see if there is a model no.
  4. Jan 28, 2017 at 9:44 PM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Will this kit work on 3rd gens with push button start? Thinking about pulling the trigger on this. My truck got broken into about a month ago.
  5. Jan 28, 2017 at 10:19 PM
    Hoangde
    Yes, this will work with push button start vehicles. Whether the vehicle shuts off when you open the door depends completely on the model vehicle you drive. All depends if the immobilizer bypass module has firmware with a "secure takeover procedure" for your model vehicle.
  6. Jan 29, 2017 at 3:57 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    It's also serious overkill unless you need the extended range remotes. Third gen PTS Tacomas are Remote-Start-Ready and you can simply add a DBALL2 and have remote start from your OEM keyfob.
    See my signature on how to roll your own with a $38 DBALL2 and $29 XKloader2 (and possibly resell the XKloader2 when done with it), or @KB Voodoo sells pre-flashed DBALL2 kits.
    No takeover on 3rd gen PTS Tacomas. All remote starts will shut off when the door is opened. Not even the OEM units from Tundras or Corolla/Camry keep it running, and Toyota support claims that's by design.
    KB Voodoo likes this.
