OTT…is there a downside?
Discussion in 'Performance and Tuning' started by Mutts2020TRD, Apr 7, 2024.
  1. Apr 7, 2024 at 3:37 AM
    Mutts2020TRD
    Mutts2020TRD [OP] New Member
    Colorado
    2020 Cement TRD Off Road
    2” Rough Country Leveling kit Dx4 Terrain wheels -6 offset Wrangler ATR shoes RedRock high clearance exhaust S&B cold air intake Optima gold top battery Tacotunes 5 channel amp Kenwood Excelon speakers Custom sub box w/ 10” woofer Ram accessory dash mount Rago bed stiffeners Seat Jackers Bestop soft shell Dash cam Door sill protectors Rough Country seat covers Weathertech floor mats Satin black hood stamp (More to come)
    My Tacoma is now 4 years old w/53k miles. The more research I do on the Overland Taylor Tune, the more I’m inclined to add it. Are there any notable “cons” I should be aware of?
    9pm, Magiriano and four22 like this.
  2. Apr 7, 2024 at 3:37 AM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    None.
    Mutts2020TRD[OP] likes this.
  3. Apr 7, 2024 at 3:56 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Are you in an emissions testing state?
    The tune is close to getting the CARB certification, but it doesn’t have it yet. This would be the only con I can think of.
    the mild/medium is wonderful. I must say, 90% of the time I am just using the mild, only use ECT when towing or need spirited boost in Indy traffic
  4. Apr 7, 2024 at 7:03 AM
    FLAK-TAC
    SW Florida
    2022 TRD OR LB
    I do not live in a “Emission Testing” state. There was a thread not too long ago that was about this and the “state” detected the tune and he failed the test. You basically have to flash back to stock every time you go let the government tell you if it’s ok to drive your car and then reinstall the tune once you pass…
    I now understand you were asking op if he lives in one of those states….
    YotaFAB and Mutts2020TRD[OP] like this.
  5. Apr 7, 2024 at 7:20 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
  6. Apr 7, 2024 at 7:25 AM
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    No "cons" it is one of those changes that you make and eventually you forget about them because it just works better. I don't even remember how my truck drove before the OTT flash, I also did the mild version.
  7. Apr 7, 2024 at 8:59 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  8. Apr 7, 2024 at 9:07 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Tire wear
    :burnrubber:
    dipb4urip and faawrenchbndr like this.
  9. Apr 8, 2024 at 7:17 AM
    sublimaze
    sublimaze Well-Known Member
    No downside...unless you enjoy your Tacoma struggling to find the proper gear to be in.
    dipb4urip and Mutts2020TRD[OP] like this.
  10. Apr 8, 2024 at 9:45 AM
    BillyE
    BillyE Well-Known Member
  11. Apr 8, 2024 at 9:57 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    OTT gets a ton of praise, but my experience with it hasn't been that if I'm being honest.
    I do not enjoy how it drives around town. Previously running KDMax Sport and then going to OTT.....feels like I went back to stock in terms of shift points luggin around town.
    just my 2c…
    Buyersremors and tollster64 like this.
  12. Apr 8, 2024 at 10:59 AM
    BillyE
    Interesting—your issue is around the transmission programming?
  13. Apr 8, 2024 at 11:05 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Have you tried any other tuned aside from KDMax and OTT? Also did you try returning to your tuner for a reflash to see if that remedied your issue?
  14. Apr 8, 2024 at 11:17 AM
    Technique
    Alex
    Utah
    Yep. You can feel the extra hp/torque with OTT don’t get me wrong. It’s faster off the line for sure.
    But cruising around town, it just shifts way to early for me, many times I notice I’m at like 1k rpms at 35mphish. And the truck falls on its face. Then I give it gas and we shift. Rinse and repeat for most of my town driving unless you’re getting on it a bit harder than normal.
    And yes, I have flashed different variants of the tune. Started with the spicy tune and thought maybe that was the issue but I’m on mild now.
    I’ve been on a Kdmax (since before it went paid), valleytune sport, OG OVTune, and now OTT for the past 2-3k miles.
    I’m not trying to say don’t get the tune, it’ll be better than stock for sure, just stating my complaint with it because I’ve never seen anybody make complaints about it, hence why I tried it.
    joba27n likes this.
  15. Apr 8, 2024 at 11:19 AM
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    The downside is not doing it sooner.
    Thunder Fist and Edaw33 like this.
  16. Apr 8, 2024 at 11:27 AM
    Captain Dirty Beard
    Captain Dirty Beard Well-Known Member
    Colorado
    2023 Ice Cap Tacoma TRD Off Road
    OTT tune
    Totally agree. It's almost like when you tip into the throttle, the tune is closing the throttle, and then you have to give it even more pedal before it "wakes up" and accelerates. To me it doesn't seem like it is upshifting, but rather just a dead spot in the calibration. Super annoying.
  17. Apr 8, 2024 at 12:35 PM
    BillyE
    My truck is a manual, so I don't know how the transmission is affected byt the different tunes. Of the tunes you've tried, which do you prefer?
  18. Apr 8, 2024 at 12:38 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    OTT makes is noticeably better.
  19. Apr 8, 2024 at 12:53 PM
    OffroadAlliance.com
    OffroadAlliance.com Well-Known Member Vendor
    Brockton, MA
    2018 Tacoma TRD Pro
    Whats your reason for "needing" the tune? Where is the Tacoma slacking as far as performance in your aspect/driving patterns? Tunes are usually not ideal if you tow or use the truck as a "truck", as its usually performance related and changes shift points and adds power. Regearing will fix alot of drivability issues, however is more expensive than a "tune" but fixes the internal gearing ratio problem that causes shift points and the lack of power in mountains or with a load. Gears will "fix" the issue without changing electronics and the ECM.
    Essentially if a powertrain module or component is faulted or damaged, any warranty you have with a tune will likely be voided whereas gears void the "axle" warranty and differential, but doesnt change/void transmission, motor or any power components that can leak or have warranty issues.
  20. Apr 8, 2024 at 12:59 PM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    I have to agree. On the highway or when "into" the throttle it's def nice, but just cruising around town I too have this experience. Way too low of RPM, try to give some gas and it falls on its face because it refuses to shift unless I give far more throttle than I should need, and then it downshifts and takes off like a mofo. I also have an issue where I have zero throttle input from 0 to say, 5% pedal travel, but not all the time. It randomly happens when pulling into the driveway or trying to leave a stop sign. Nothing, nothing, nothing, then BAM! Finally have throttle at whatever percentage the pedal has traveled. I've tried reaching out to my tuner but I can't get them to respond.
