Original rim size
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bfunk, Feb 6, 2020.
  1. Feb 6, 2020 at 8:05 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    Got a 97. Been lifted. Want to go back to orig wheel size. What size stock rims, wheels and....can I replace without removing the lift? Thank u in advance.
  2. Feb 6, 2020 at 8:17 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Original wheel was either 31x10.50R15 or 265/70R16. Might look a little odd with the lift and such a small tire.
  3. Feb 6, 2020 at 8:17 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Should tell you the orig wheel size on the driver side door sticker.
    Yes, you can go back to original size without removing the lift. Most people lift to fit bigger tires, so if you’re going back to stock, it shouldn’t be a problem.
    Only issue is if they have 16” or bigger wheels and they did the tundra brake upgrade. If it has those brake calipers, you can’t fit 15” rims.
  4. Feb 6, 2020 at 8:18 PM
    2BeersPlease
    What sort of lift do you have? Do you have any pics?
  5. Feb 6, 2020 at 8:24 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    I'll get some and post tomorrow. Local tire shop couldnt tell me size of rims on truck. Don't want to get new tires if rims are wrong.
  6. Feb 6, 2020 at 8:25 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    Thnx jbrandt and 2 beers.
    2BeersPlease likes this.
  7. Feb 6, 2020 at 8:30 PM
    jbrandt
    Justin
    The tire shop couldn’t read the size that’s printed on your tires???
    Holly shit, don’t go back there!
    4xdog and 2BeersPlease like this.
  8. Feb 6, 2020 at 8:31 PM
    2BeersPlease
    Rim size should be on the rim somewhere. It's either 15x7 or 16x7.
    That's what I was thinking.
    Bfunk[OP] likes this.
  9. Feb 6, 2020 at 8:43 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    That’s not a flip comment — it’s serious advice. Run, don’t walk, from that place.
  10. Feb 6, 2020 at 8:52 PM
    jbrandt
    Justin
    Yes, this needs repeating. I was dead serious.
    No different than if you take your car to a shop, and they can’t tell you what kind of car you have. Or your computer to a computer replair shop and they don’t know what kind it is.
  11. Feb 6, 2020 at 9:04 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    My thoughts, too. Super small town, not a lot of options...but it sure seemed odd they couldn't determine rim size.
  12. Feb 6, 2020 at 9:08 PM
    jbrandt
    Justin
    You look on your door sticker yet?
  13. Feb 6, 2020 at 9:10 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    Looking in the a.m. will get pix too of lift. So appreciate the input!
  14. Feb 6, 2020 at 9:11 PM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    Thank u all!
  15. Feb 6, 2020 at 9:17 PM
    Muddycoinwash
    Muddycoinwash Well-Known Member
    2015 TRD OR access, 2000 4x4 reg
    wheel 15x7, tire 31x10.5
  16. Feb 6, 2020 at 9:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    A '97 came with 15s, most likely a 15x7. Metric sized tires were not introduced on 1st gens until the '01 model year.
    And you can't always rely on the sticker for rubber size. Mine says 215/70r16 which is not what it came with.
    OP, on that same sticker that everyone is telling you to look at, it will also list a diff code. For example, BO3A. The original gear ratio can be established from that code and that will tell you more about the stock tire size.
  17. Feb 7, 2020 at 4:40 AM
    JC34X4
    JC34X4 Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    Stock should 225/70/15
    may I ask why u want to go to stock?
  18. Feb 7, 2020 at 5:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    I was going to say that too. But I also assumed they couldn't tell him the OE sizes (not the ones on vehicle) because door stickers usually only state tire size and wheel diameter, not the wheel width, right?
    Till I saw his profile says he has a 4wd racoma.
    That model didn't have door stickers.
    :D
  19. Feb 7, 2020 at 8:39 AM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    lol Tacoma!
  20. Feb 7, 2020 at 11:53 AM
    Bfunk
    Bfunk [OP] Member
    1997 4wd Tacoma
    Here's a pix. will check door sticker next.
    Clearwater Bill likes this.
