O'Rielys Drums out of round/major vibrations.
Discussion in '1st Gen. Tacomas (1995-2004)' started by JJ04TACO, May 9, 2015.
  1. May 9, 2015 at 9:37 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I'll add my experience to the search results to help others.
    I did the rear brakes and didn't anticipate the drums being 1/1,000th" from being out of spec. Turning them would have put them there. So I made a snap decision to go with their replacements. Brake Best I believe. Well the title says it all, and man was the vibration bad. Did some searching and found similar issues with aftermarket varieties. My originals lasted 145k mi and the original shoes had plenty of life left though they were wearing a bit unevenly. I'm amazes at how long the rears lasted. The drums wore out faster than the shoes.
    What irks me is that I could have turned them but that decreases the life of a brand new drum. I didn't want to fiddle around and see if it was one the other or both. Frustrating.
    So OEM here I come. OEM has proven the way to go for me 90% of the time. And with Toyota of Dallas pricing and same day pickup, it's hard to beat.
    I'll revise this if the Toyota drums somehow don't fix this issue but somehow I think I'll be ok...
  2. May 9, 2015 at 2:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Long ago I learned Brake Drums and Rotors need to be stored flat or hard to believe they will warp
    Since pretty often for the most of the chain stores are clueless it is possible the store these in a vertical position.
    I had good luck with the Napa Drums I just installed
    Deathbysnusnu likes this.
  3. May 9, 2015 at 3:06 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I would think its more likely they were palleted standing on end and the pallet was dropped or had too much weight stacked on top of it.
    they are turned when they are made so short of machine malfunction (which happens) its very uncommon to get them out of round like that
  4. May 9, 2015 at 8:06 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    They looked good and seemed well made. I thought when adjusting the shoes that it wasn't a big deal that they rubbed for about 45 degrees of the 360 degrees of rotation. Come to think of it they both did that. I thought it the shoes would align to the drum after a few pumps of the brakes after the adjustments were made. Oh well I already have drums from Toyota Dallas on order. I'll be picking them up on Monday and that will be that, I hope.
  5. May 10, 2015 at 5:46 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You always turn new drums out of the box. They are not machined true from the factory and improper storage methods, like sitting on the edge instead of being stored flat, will make them go out of round.
  6. May 10, 2015 at 11:50 AM
    keakar
    karl
    louisiana
    the drums aren't casted or "poured" with a turned pad surface, they are spun balanced and weights are welded onto the drun then it is machine turned smooth true and round at the time its made. the very act of turning them makes them true, you CANNOT turn something and it NOT be true.
    now its never a bad idea to check them and have them returned before using but they are turned when made.
  7. May 10, 2015 at 12:32 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You missed the point again. Cast iron distorts in a very short time. If drums are stored on their edge, they will be out of round. You turn them to make the Inside surface true again. As a rule you always turn new drums.
  8. May 10, 2015 at 12:56 PM
    keakar
    karl
    louisiana
    no, I was only disputing your claim that
    because they are.
    I was NOT disputing (or endorsing) your claim that they change shape after casting
    as a real world observation, I have never needed to turn a rotor or drum out of the box for any of the 20 some odd brake jobs I have done and I specifically check them for being out of round and only had one that was returned and replaced for a good one.
    your advice is good and based on sound logic but the blanket assumption they all need turning I do not agree with based on actual proven experience
  9. May 10, 2015 at 9:45 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Picking up Toyota rotors in the AM. I'll have them on and tested hopefully by the afternoon. I'll ask the parts dept., just for shits, if they recommend a turn prior to install. I'll ask the same of the guys at o'Rileys as well. Again just because I can. I agree that if they are turned, they're true, but shit happens, who knows why they are out of round. :)
  10. May 10, 2015 at 11:47 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not to many places in this part of the country even turn drums or rotors any more just replace .
    to time consuming
