Optima blue top
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Apr 25, 2019.
  1. Apr 25, 2019 at 6:48 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    Are either of these good for my truck? They don’t have red or yellow tops here.
    Thanks
  2. Apr 25, 2019 at 7:37 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I've run all 3 colors in various cars in the past. Currently have a red top in my Challenger.
    I used blue tops in my cars that had aftermarket systems because of the extra binding posts.
    Was nice to have a dedicated post just for lights and amps
  3. Apr 25, 2019 at 7:38 AM
    jardoo
    Beirut, Lebanon
    Oh awesome. Figured the blue ones were for boats.
  4. Apr 25, 2019 at 7:42 AM
    5nahalf
    Erik
    Minnesota
    nartmot likes this.
  5. Apr 25, 2019 at 7:42 AM
    jardoo
    Beirut, Lebanon
  6. Apr 25, 2019 at 7:42 AM
    5nahalf
    Erik
    Minnesota
    Also, make sure you get the dark gray case one.
  7. Apr 25, 2019 at 7:43 AM
    jardoo
    Beirut, Lebanon
    He smaller one? Why?
  8. Apr 25, 2019 at 7:43 AM
    5nahalf
    Erik
    Minnesota
    The binding posts are where the battery terminals go. Cars have clamps that go onto the posts, boats can also have just eye lugs that bolt to the battery. Bluetop has both.
  9. Apr 25, 2019 at 7:45 AM
    5nahalf
    Erik
    Minnesota
    The light gray is a deep cycle, the dark gray is for starting. It doesnt make a ton of difference, but if your just starting the truck, then the dark gray. If you plan to run things off battery power while the truck is off, then the light gray will work.
    tcjacado and jardoo[QUOTED][OP] like this.
  10. Apr 25, 2019 at 7:59 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Was checking out that link @5nahalf sent and this is at the bottom. Should be pretty clear the difference between them and casing colors
    "Note: The difference between BLUETOP and YELLOWTOP deep-cycle batteries is that BLUETOP batteries have both automotive (SAE) posts and threaded studs, while YELLOWTOPS (other than D31T) only have SAE terminals.
    If you ever get confused about the colored tops, just remember: If it has a dark gray case, then it’s a starting battery; if it has a light gray case, then it’s a deep-cycle (dual-purpose) battery."
    Good info to have.
    jardoo[OP] and 5nahalf like this.
  11. Apr 25, 2019 at 8:12 AM
    5nahalf
    Erik
    Minnesota
    BTW, if anyone is interested. Go to local places that sell car batteries, ask them if they have any dead optimas in their core bins you can have. Optima lots of times will warranty the battery for you and you can get a free one.
    Me and my dad did this for a while when I worked at a auto parts store.
    jardoo[OP] likes this.
  12. Apr 25, 2019 at 11:10 AM
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
    Is 7/2018 the newest battery they have on the shelf?
  13. Apr 25, 2019 at 11:12 AM
    jardoo
    Beirut, Lebanon
    Yea unfortunately. I’m in the Middle East. This stuff is hard to come by.
    And thanks for the info guys!
    TRDPro916[QUOTED] likes this.
  14. Apr 25, 2019 at 1:29 PM
    jardoo
    Beirut, Lebanon
    I have a bunch of led lights, 4 of them. I guess light grey would make more sense ?
  15. Apr 25, 2019 at 1:35 PM
    5nahalf
    Erik
    Minnesota
    Depends, are you running more than 250 watts over trucks max draw? are you planning to leave them on when the truck is off?
    If you say no to them, then its not needed and the dark gray is fine.
    Keep in mind, your truck has reserve power from the alternator already, so you would need to exceed that amount by 250 watts to really need the light gray.
    But, in the end it doesnt matter all that much really. Both will start the truck just fine.
  16. Apr 25, 2019 at 1:35 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Isn't the Light Gray a 31M? Does it fit in the 3rd gen without a different battery tray?
  17. Apr 25, 2019 at 1:38 PM
    jardoo
    Beirut, Lebanon
    I see. And not sure but I’ll do some research.
    Thanks.
  18. Apr 25, 2019 at 1:39 PM
    jardoo
    Beirut, Lebanon
    Good Question, no clue.
    I know it takes 24f and 27f.
  19. Apr 25, 2019 at 1:39 PM
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Fits pretty good.
  20. Apr 25, 2019 at 1:40 PM
    jardoo
    Beirut, Lebanon
    Nice!
    Sociopenguin[QUOTED] likes this.
