Opinions on CSF Radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4WDTrout, Jun 7, 2024.
  1. Jun 7, 2024 at 10:15 AM
    4WDTrout
    4WDTrout [OP] Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  2. Jun 8, 2024 at 5:40 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I've had one for 5 years now. It seems like it's decent quality and I would say has improved cooling slightly. I like that it's all-aluminum. That said, with the prevalence of plastic use in radiators and never having had a problem with any of the OEM's in our other Tacomas, I'm sure you're fine going OEM.
    And if you'd like to buy my OEM radiator and shroud, all with 34k miles on it in the CSF box, it's for still sale! LMK
  3. Jun 9, 2024 at 11:22 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I put one in a few years ago. Logged temps before and after. Overall lower and much, much more stable with the CSF unit (unsurprising given the increase volume and surface area). I can't get my coolant temp above about 188 or 190 even running hard in the Southwest.
    The plastic clip-on top part of the factory shroud will still fit - it won't line up with the new radiator but if you clip it into the radiator support and just let it lay on top, it isn't going to go anywhere and will do better than nothing.
    You could order a sheet of ABS real cheap and make a new one, but I haven't bothered.
  4. Jun 9, 2024 at 2:33 PM
    TacoTuesday1
    FL
    you put what in
    CSF $100-200 plastic
    Or CSF all metal maybe $400+
    honestly a good all metal sounds temping for many reasons
    From whatever company is best whoever that is
  5. Jun 9, 2024 at 6:33 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The CSF all metal. I don't recall the exact price but it was very much worth the marginal extra cost above OEM. Somewhere in my build (link in sig) if you ctrl+f for "CSF" you'll find a link to the posts about it.
  6. Jun 10, 2024 at 9:12 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    So far all I see is reasons I SHOULD buy the CSF. I’m thinking I will probably go that route.
  7. Jun 10, 2024 at 9:17 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    I was thinking about moving to a larger all-metal radiator & it seems like there are 2 major aftermarket brands, CSF and Mishimoto.
    Both look really cool and seem to offer improvements etc etc but there was a long thread on TW forums somewhere about some pretty nasty-sounding quality-control issues with one of those two brands. If I can find that thread I'll crosspost a link to it here.
    Reading it gave me some serious doubts about moving away from the OEM radiator.
    Currently at 79K miles with no coolant leaks etc. I'm inclined to leave well enough alone.
    4WDTrout[OP] likes this.
  8. Jun 10, 2024 at 10:00 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I installed a CSF 3200 (non all metal) from rockauto ($95) two years ago. I see they have gone down in price, to $73. I installed a CSF in our, then, 98 Sienna some 15 years ago and it is still working fine.
  9. Jun 11, 2024 at 3:23 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Mine came from URD.
    No issues installing, using, etc.
    One complaint, the drain faces aft, not down. So drained coolant goes everywhere, vs in a bucket.
    Torspd likes this.
  10. Jun 11, 2024 at 4:21 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I've seen some grumblings about Mishi and counter-grumblings that the grumblers may have gotten counterfeit parts. No complaints about CSF other than gaps when putting in the FJ or other models into the Tacoma, which is obviously not a fault of the part.
  11. Jun 13, 2024 at 9:07 AM
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    The red truck in the first video had a failing radiator and the owner didn't even know. We were just doing some preventative maintenance and caught it on time. I replaced my radiator with an aluminum csf in another video and have had much better cooling under stress conditions compared to the stock radiator. The temps during normal conditions stay relatively the same compared to the stock radiator due to the thermostat.
    Stock radiators are fine but the plastic tanks will fail at some point. With these trucks getting up there in age and mileage an upgrade like this seems to be money well spent imo.
    https://www.youtube.com/watch?v=gbFvQ6DDQto
  12. Jun 13, 2024 at 9:23 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Thanks for the info Gio!
    I’ll be ordering the parts to do this job in the next few days.
    greenEFSI[QUOTED] likes this.
  13. Jun 13, 2024 at 9:32 AM
    ChumpChange
    ChumpChange Active Member
    Kyle
    Stock '06, 4x4 V6, access cab
    FWIW I ran a CSF radiator in my Nissan Xterra. My truck was N/A but I used a radiator for a supercharged model to take advantage of the expanded capacity (the SC trucks used larger radiators than N/A).
    As far as quality goes, I was very impressed with the CSF. Full metal construction, nice welds, perfect fitment. They seem to know their shtuff and I'd absolutely but their product again.
    herecomesace and 4WDTrout[OP] like this.
  14. Jun 13, 2024 at 9:50 AM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    I went with the CSF primarily to ditch the stock plastic end caps, secondarily for added cooling capacity. Aside from a tiny hole in one of the welds that i had to plug with JB weld (didn't want to deal with waiting for return), i have been thoroughly happy with the CSF. very hard to get the temps to go above 190F.
    Charlie Bravo and 4WDTrout[OP] like this.
  15. Jun 14, 2024 at 9:26 AM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    I just put the mishimoto one in and it's night and day
  16. Jun 14, 2024 at 9:29 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Mine has been in for a bit over a year, even in the desert I rarely see temps over 190 with 90-100 degree outside and pushing the truck I have had "0" issues. Upgrade. you wont regret it!
  17. Jun 16, 2024 at 7:30 PM
    GilbertOz
    GilbertOz Driver
    CA
    Thinking about it more, I want to do this mod. Obviously w/ a thicker all-aluminum radiator the cooling capacity is going to be vastly improved. For those few times when I might be hauling heavy, uphill, in summer.
    I also want to do an electric-fan mod. Easy option to shut off the fan for any deep-water crossings, and for possible MPG savings/horsepower improvements from reduced crank losses when the fan doesn't need to be running. (In winter months at low engine output levels.)
    (OTOH: an electric fan motor is going to be a lot more sensitive to water/mud than the stock crank-driven fan..)
    Going to read around the TW forums & see if I can dig up what looks like the best-of-breed solution. Probably a Mishi radiator; I really don't like the CSF aluminum-bung-on-aluminum-drain setup. Mishi's drain looks far better implemented.
    Whatever I go with, I also don't want to %#*(& around with having to weatherstrip the shroud for proper radiator fit/air flow.
    eherlihy likes this.
  18. Jun 16, 2024 at 8:49 PM
    TacoTuesday1
    FL
    im probably gonna ginuea pig test the $150 eBay one
    Big Lol if it works…
    it says 3 row instead of 2. Not sure if it comes with bushing fitment kit or what. I would hope so. It says Tacoma fitment.
    Audi used electric fans for a while. Two of them. Not exactly a wheeling rig though.
    I thought the point of clutch style is it is water crossing ability by automatically slowing down? Seems it succeeded for me in the past.
    GilbertOz[QUOTED] likes this.
  19. Jun 16, 2024 at 8:57 PM
    GilbertOz
    GilbertOz Driver
    CA
    Hmm maybe the only time people break the standard clutch fan on water crossings is when they PLUNGE IN at 15-25mph and high rpms. All theoretical for me; the deepest water I've been in came up about 1" above the hubs on standard P265/70/R16 tires.
    If I got any aftermarket rad I would probably hydrotest it overnight at +25% above design pressure before installing, as a leak/lemon check.
  20. Jun 16, 2024 at 10:14 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Is URD the best place to buy the CSF Radiator?
