Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 24, 2020 at 9:45 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Hoarding up on chicken ?
    Need those biscuits for the trails. ...
  2. May 24, 2020 at 10:06 AM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    Popeyes! Ah, the memories!
    Delicious biscuits.
    Semi-cooked chicken.
    3 days of explosive diarrhea.
  3. May 24, 2020 at 10:49 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Lol same reason I have not eaten KFC in 30 years.... Soon as someone pulls out a bucket, my colon starts to quiver... it has not forgotten.
    pete37, Norilsk and weight[QUOTED] like this.
  4. May 24, 2020 at 1:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Atlas86, ontarioyota, Dye22 and 4 others like this.
  5. May 24, 2020 at 2:45 PM
    #Scotch and Brass
    #Scotch and Brass Well-Known Member
    Ontario
    2019 Tacoma TRD 4X4 in Cement
    Tinted Windows Centre Tray Molle Backseat cover Molle Visor cover TRD Pro Grill De-Badged the chrome Decals off Blacked out Badges Blacked out Tailgate letters DiomandBack bed cover 17" ProComp Bandido Wheels Toyo Open Country AT Bilstien 5100 all around 2.5" Eibach Coild 1.5" ProComp rear block Sway bar relocate kit Front Runner Custom Bed rack
    Hahah. I can’t touch the stuff. Cleans me out in no time flat. Not in a good way either.
    daks[QUOTED] likes this.
  6. May 24, 2020 at 3:16 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Hope everyone is having good weekend!
    Taco and sausages :101010::cheers:a
    ontarioyota, Snail81, cwisema and 5 others like this.
  7. May 24, 2020 at 3:17 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Wait your gas cap locks?
    :duh:
    Tridet167 likes this.
  8. May 24, 2020 at 3:18 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Looked up alignment on the web and on TW and cant rally find what I'm looking for, so last resort I'll ask hear.
    Background:
    2014 tacoma acess cab v6 4.0l six speed
    265 65 16 wheels and very good snow tires no odd wear and pressures all adjusted to 32psi
    new lower control arms with new cam adjusters
    new spc upper control arms set at 0 caster, also triede +2 also tried -2
    toe is adjusted to 0 tried adjustment of 1/2 in and 1/2 out
    Problem:
    when you hit any bumps in the road the steering wheel moves a little
    you can let go of the steering wheel and it goes no where just moves as you hit bumps
    dose not pull left or right and returns just fine.
    Question:
    is there any alignment tech's or knowledgeable persons out there that can tell me why this is?
    not asking for a cure just want to know why the steering wheel is moving when I hit a bump
    My wifes corolla can go over any pot hole and that steering wheel will not deviate from center. was just wondering why?
    Thanks in advance
  9. May 24, 2020 at 3:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Not stock, no. Toyota sells a locking one P/N C0170-00020, but it's just a repackaged Stant P/N 10504. It's slightly wider than the stock cap, so the tether no longer fits.
  10. May 24, 2020 at 3:32 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I can only speak for myself. With 4 inch lift and 33's my steering wheel does that. It's nothing crazy just a slight tug. I think it's normal with larger tires and changes to suspension. In your case, not sure.
  11. May 24, 2020 at 3:34 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Phenomenon is simply called bump steer. It's usually minimized at vehicle design stage by altering steering rack location so the tie rods and control arms converge to a single point:
    On our trucks, this geometric relationship is worsened when the truck is lifted. If you lifted the Corolla 3", it may behave similarly. On Mustangs, they sell spacer kits to correct bump steer for lowered cars. AFAIK no one offers a similar kit for Tacomas, because people don't buy these trucks for handling prowess. You'd also be limited to heim joint tie rods, which will need replacement every 2-3 years in our climate.
    Atlas86 and ontarioyota like this.
  12. May 24, 2020 at 3:37 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Cereal...all these guys missed a sausage party jab? Shame on you all
    Sloweburn and Norilsk[QUOTED] like this.
  13. May 24, 2020 at 3:41 PM
    Windigo
    Farook
    '14 Acess Cab
    thanks its what i was thinking, I'll just live with it and occasionally try my luck with fine adjustments.
  14. May 24, 2020 at 3:42 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    I would target. ..
    0 Camber
    +.02 Toe
    At least 1.5deg Caster but more is better, 2 deg to 3 deg seems to be "the spot" that a lot of people like, reduces bump steer when you have positive caster.
    Since most roads crown to the left in North America 0 to .5deg more caster on driver side.
    But if you are above 2 deg caster keeping them even is fine.
  15. May 24, 2020 at 3:44 PM
    Windigo
    Farook
    '14 Acess Cab
    Thanks guys.
    just doing this in my driveway so no way of measuring accurately.
    just thought maybe its something all tacoma's share.
    forgot to mention bilstein's on lower clip and 887's
    oh and currently 2" wheel spacers
  16. May 24, 2020 at 3:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Since you have SPC uppers, find a level surface, and you can do all your alignment with a fishing line and a digital level:
    As far as I know, those Michelin jack stands were made in a different Chinese labor camp and not under recall :anonymous:
    Shveet and llamasmurf like this.
  17. May 24, 2020 at 3:58 PM
    Windigo
    Farook
    '14 Acess Cab
    thanks i did that same thing today
    Shveet and 3JOH22A like this.
  18. May 24, 2020 at 5:13 PM
    weight
    Kevin
    Ontario, Canada
    Ain’t no sausage party until they’re swollen and blistered.
  19. May 24, 2020 at 5:36 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Donut made a sweet video on alignmnets a few weeks back. Explains a lot of it in laymans terms but also have a DIY guide for it with the same fishing line method
    https://www.youtube.com/watch?v=NZUgNJjUQLY
  20. May 24, 2020 at 5:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The dihedral LCA angles are painful to watch. Roll center is probably below the ground on that Miata. :bananadead:
    Shveet[QUOTED] likes this.
