Only will start with starting fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by T4life, Mar 26, 2020.
  1. Mar 26, 2020 at 12:24 PM
    T4life
    T4life [OP] New Member
    Chuck
    1995 Toyota Tacoma
    None
    My 1995 Tacoma with the 2.7. will only start with starting fluid after I replaced the head gasket. After it starts with starting fluid it runs great and has no issues. I have replaced the battery, fuel pump, plugs, wires, distributor, fuel pressure regulator. Cleaned throttle Once it starts with starting fluid it runs and drives great. Please help????
    Lucifer1 likes this.
  2. Mar 26, 2020 at 12:36 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    Be Advised : Starting fluid is for Diesel Engines Only, and can damage your Gas engine, if you have to start your engine this way, use WD40 only, it works and is cheaper.
    once the engine spins and builds oil pressure bypassing the relay and energizing the fuel pump and continuing to run points to a relay or wiring problem.
    Good Luck
    PennSilverTaco likes this.
  3. Mar 26, 2020 at 12:39 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    I thought starting fluid could only be used on carbureted engines; I guess I was wrong!
    b_r_o and Lucifer1 like this.
  4. Mar 26, 2020 at 12:53 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @PennSilverTaco
    It is a common mistake, "starting Fluid" is much to harsh in gas engines can cause broken rings, and it can detonate in the crankcase in rare cases.
  5. Mar 26, 2020 at 1:29 PM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Well damnit man. If that’s the case, my 96’ F-150 should’ve blew up. I had to do that casing down a fuel pump problem for a month cause it was All I had to drive. Lol
    Edit: I’d take a look at the relays and see if it’s something small you might be missing as well as a ground maybe. Good luck.
  6. Mar 26, 2020 at 2:40 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Bullshit. You're not supposed to use ether on diesel engines. The myth is that diesels get addicted.
    You can use ether AKA starting fluid on any gas engine 2 or 4 stroke.
  7. Mar 26, 2020 at 3:08 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Check the Circuit open relay it sounds like the contacts that should be closed at cranking are not
    Starts with the Fluid the run set pulls in and keeps it running
  8. Mar 26, 2020 at 3:14 PM
    Cucvfan
    Cucvfan Well-Known Member
    I agree, if the diesel has glow plugs, I've always been told not to use starting fluid on it. As far as that myth, I've never understood how an engine could get "addicted " to anything.
  9. Mar 26, 2020 at 3:45 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Exactly but it’s perfect for huffing... ehhh
  10. Mar 26, 2020 at 4:14 PM
    CD20H
    Ben
    North Texas
    Ever hear of a gadget called a PCV valve? It stands for Positive-Crankcase-Ventilaton. That little doohickey removes combustibles that slip by the rings. Typically they have a hose going from them to a vaccuum port on the carb or throttle body so it can be burned in the combustion cycle. Where you heard that it can accumulate and ignite in the crankcase sounds like a muffler bearings tale.
  11. Mar 26, 2020 at 4:56 PM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    Muffler bearings and addicted engines, Toto were not in Kansas anymore, how about broken and or damaged spark plugs from using Diesel starting fluid in a gas engine ?
    Wyoming09 likes this.
  12. Mar 26, 2020 at 5:10 PM
    Rachelsdaddy
    Southern NH
    Geeeezus, poor guy just wanted to ask a question
  13. Mar 26, 2020 at 5:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the coolant temp sensor and temp sensor wiring.
    Its the other way around. Ether won't detonate in a gasoline engine until the spark plug fires. There isnt enough compression to light it off sooner than normal.
    Diesels however have much more compression and the fuel (whatever fuel you're feeding it) has to be introduced at the perfect time to avoid detonation. The compression ratio is high enough that the air/ether mixture will explode well before the piston finishes its upstroke.. risking detonation and the piston damage that comes with it
  14. Mar 27, 2020 at 9:37 AM
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
    @T4life Hope you haven't been confused by all you have read hear.......Good Luck
    Rachelsdaddy likes this.
  15. Mar 27, 2020 at 8:34 PM
    NvrSyNvr
    NvrSyNvr Well-Known Member
    Jim
    2000 Green PreRunner Xcab V6 Auto w/locking diff
    Hayden 678 Transmission Cooler
    Some years ago I had an issue where my 3.4 would turn over for a long time before it would start. After some failed troubleshooting I bought a fuel pressure gauge and found that I did not have fuel pressure on the fuel rail after turning off the engine. My understanding was that the fuel pressure regulator was not doing its job and letting the fuel in the rail drain back to the gas tank. I bought an aftermarket fuel pressure regulator and still had the problem. I ordered the regulator from Toyota, installed it, and the truck has started right up ever since.
    Also, one time I forgot to put one of the grounding straps back on a 3.0 liter lexus and got Air Fuel mixture codes. It might be worth checking the ground if you have not already.
    cruxofthebisquit likes this.
  16. Mar 27, 2020 at 8:58 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Your having a fuel pump issue. Relay or more likely pump.
    Starter fluid is for gas engines. WD40 is for diesels.
    Truth.
  17. Mar 28, 2020 at 5:55 AM
    Rachelsdaddy
    Southern NH
    Starter fluid is for potato cannons and wd-40 is great for removing stickahs
