Only 5 quarts drain in oil change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jamiemm18, Jan 29, 2018.
  1. Jan 29, 2018 at 5:12 PM
    jamiemm18
    jamiemm18 [OP] Member
    Just curious if anyone else has seen this. 2012 4 cyl tacoma 4x4. I do my own oils changes. I drain the oil with the oil cap off, empty the old oil filter into my drain pan, etc. When I pour my waste oil back into the containers, I barely get rid of 5 quarts but when I replace the oil, I put in 6 quarts. It puts the dipstick in the correct range. My truck doesn’t appear to burn oil, I can’t see any smoke or anything while starting it or driving it. The truck has 138K. I’ve done the last 4-5 oil changes myself and each time, I only have to dispose of roughly 4-5 quarts of oil even though I put 6 whole quarts in when I do the oil change. I drive super easy on the truck, in fact I just had the original front brakes done at 137K and there was still a little life left in ththe pads. I do wait 10K to do the oil. The truck says to do it at 5k and I do it around 9-10k and use good 0w20 synthetic oil and a high mileage oil filter. If I can’t see it burning any oil, I’m wondering where the 1-1.5 quart is going between oil changes. Thanks!
  2. Jan 29, 2018 at 5:24 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Burn off, and oil that still stuck in the engine’s nooks and crannies.
  3. Jan 29, 2018 at 5:37 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    The filter will hold some
  4. Jan 29, 2018 at 5:41 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Do you keep an eye on the dip stick? Or do you just toss 6 quarts in and go? If the latter you may be fairly overfilled. These engines take a long time to fully drain. On my last I popped the drain plug off, rotated the tires, and when I came back there was still an appreciable drip.
  5. Jan 29, 2018 at 5:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Keep doing what you are doing.
    Yes, it seems weird, but there's not a problem.
    The 'lost oil' is clinging to engine internals (and within the old filter.) All the oil will never drain out, nor would you want it to, because then you'd have dry parts every startup.
    balljoint likes this.
  6. Jan 29, 2018 at 5:48 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Do you ever check the level between those 10k changes?
  7. Jan 29, 2018 at 6:43 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Saturated oil filter media can hold 1/3 to 1/2 quart of oil.
    330d and taco2010trd like this.
  8. Jan 29, 2018 at 8:27 PM
    L J
    Illinois
    The math says you’re burning about 1/2 quart or more between changes. Oil clinging to the engine internals doesn’t count as it is relatively static.
  9. Jan 29, 2018 at 8:31 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Some oil never makes it back to the drain pan. Some is burned even if you think you see no smoke.
  10. Jan 30, 2018 at 7:09 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Check your oil in the morning before you start your truck, snap a picture of it , and do this every month or 1000 miles. If you see a even decline of the oil level, its probably the nature of the ageing beast. If you go several months and then start to see a steady decline in the oil level, you may be asking too much of your oil. Reduce the maintenance interval , in the latter case.
