On-board Bottle Jack for 3" Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Jul 6, 2010.
  1. Jul 6, 2010 at 4:57 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    Obviously the stock jack wont work now that I have put the toytec ulk and my 33s on my taco. What do you guys use for an on-board jack in case you get a flat on the road?
    I'm guessing I'll need a 22" or higher bottle jack. What do you guys use? Link?
    Thanks for the help! :D
  2. Jul 6, 2010 at 5:36 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    48" hi lift jack mounted inside side of the bed on the passengers side.
  3. Jul 6, 2010 at 5:40 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    When you are lifting to change the tire, lift off of the lower UCA or the axle. If you must 'jack off' a slider, use a ratchet strap and compress the spring to hold and then 'jack off' the slider. You don't need a 22" bottle jack.
    k8md likes this.
  4. Jul 6, 2010 at 6:03 PM
    DrRabbitFurHead
    Salem, VA
    If you lift the back of the truck off of the axel with a bottle jack, MAKE DARN SURE you chock the front tires. Very dangerous IMO, but I'm just a dumb engineer so what do I know... :D
    Bulljolly and Stryker420 like this.
  5. Jul 6, 2010 at 6:13 PM
    HBMurphy
    Paul
    So California Coast
    None
    Good Point - should go without saying anytime you jack up a car regardless of axle - chock the opposite wheel. Also, I always keep a piece of 2x4 handy for the top of the jack to compress into what ever I am jacking. I also keep a square peice of 3/4" plywood for a jacking base. I was educated as a rocket scientist but what does that have to with Jacking? ;)
    Stryker420 likes this.
  6. Jul 6, 2010 at 6:36 PM
    jmed99
    SC
    Not sure I quite understand :confused:
  7. Jul 6, 2010 at 6:38 PM
    jmed99
    SC
    Yeah, always chock the tires. I dont really want to carry a hi lift jack around. Any other ideas?
  8. Jul 6, 2010 at 6:50 PM
    HBMurphy
    Paul
    So California Coast
    None
    let's say you lifted your truck 6 inches - the lowest part of your truck is still the lower control arm and the axles. They have not been lifted.
    I carry a bottle jack and a hi lift - the high lift is just a great all-around tool but most people will never need one if they are just changing tires.
    When you lift from the body (sliders, rocker panels, etc) you are jacking the truck a lot more than you would have to lift it, and you are risking more problems. If you can not lift from lower control arm or the axle, then you can compress the spring so that when you do lift the body (rock slider, etc), you are only lifting the truck as much as is required to lift the wheel an inch or two off the ground verses lifting the truck through the amount of spring travel (5-6 inches) and then the tire coming off the ground an inch or so.
    Here is a picture of a jeeper doing what I am talking about... although I would do it with a good ratchet strap instead of the POS he is using.
    Rattlejay65 likes this.
  9. Jul 6, 2010 at 6:53 PM
    jmed99
    SC
    I got ya now.
    What about this and a 4x4 block of wood?
  10. Jul 6, 2010 at 6:54 PM
    jmed99
    SC
    Or this one and no block of wood may do it...
  11. Jul 6, 2010 at 7:11 PM
    HBMurphy
    Paul
    So California Coast
    None
    Just MO but you won't be able to fit those monster's under your truck in most cases - I have this: It works fine with block of wood and a plywood base.
  12. Jul 6, 2010 at 7:13 PM
    HBMurphy
    Paul
    So California Coast
    None
    One other point, I have been taught to store jacks with the valve open so that the seal for that valve doesn't loose it's elasticity.
  13. Jul 6, 2010 at 7:15 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Geeze...when I first read this thread title I coulda swore it said "On Board Bottle of Jack"!!!
    ricco333 and Blais03 like this.
  14. Jul 6, 2010 at 7:20 PM
    HBMurphy
    Paul
    So California Coast
    None
    Sorry, we polished that one off, we're on to hydraulic fluid now! :) Kinda like any time I see a red dot on a women's chest, I automatically think it's her nipple! :D
  15. Jul 7, 2010 at 7:25 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    how would you use a highlift without sliders on the truck? I just have the stock tube steps...
  16. Jul 7, 2010 at 7:36 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    If you are not offroading, you don't need a high lift or other type of specialty jack. Just keep you stock bottle jack and stow a couple squares of 2x6 in with the jack under the back seat. The squares of 2x6 placed under the stock bottle jack will take up the 3" of additional height from your lift. Use as you would on a stock truck to jack up from the front LCA or the rear axle.
  17. Jul 7, 2010 at 7:38 AM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    nope, those steps aren't designed to handle 1000lbs :eek:
  18. Jul 7, 2010 at 7:41 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    About the only place you can use a hi-lift on a tacoma is inside the rear receiver hitch - if you have a hitch. DO NOT use the hi-lift on your tube steps - the tube steps can't handle the weight and might collapse.
    Or, you can buy hi-lift accessories:
    Lift mate
    http://www.hi-lift.com/accessories/lift-mate.html
    Bumper lift
    http://www.hi-lift.com/accessories/bumper-lift.html
  19. Jul 7, 2010 at 8:25 AM
    HBMurphy
    Paul
    So California Coast
    None
    Use a lift mate...
  20. Jul 7, 2010 at 8:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thats what I keep in my truck
