On Board Air Tanks - Where to Mount?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EdinCincinnati, Sep 20, 2018.
  1. Sep 20, 2018 at 5:26 PM
    EdinCincinnati
    EdinCincinnati [OP] Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Found a good deal on a Viair On Board Air system on Amazon...but it has a decent size air tank.
    If you have an air tank, where did you mount yours??
  2. Sep 20, 2018 at 7:03 PM
    mt1961
    mt1961 Well-Known Member
    Kingsport, TN
    2015 TRD Sport
    I have two 6" diameter x about 15" long tanks mounted inside the frame on the passenger side. Had to weld a bolt on the tanks to tighten to pull it in to the frame. Have used these on an 06 and now a 2015.
  3. Sep 20, 2018 at 7:07 PM
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    I have a 5 gal where the spare used to be.
  4. Sep 21, 2018 at 4:06 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
  5. Sep 21, 2018 at 4:08 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Put it on your roof. Vertical. You won't
  6. Sep 21, 2018 at 4:31 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Please note that I didn’t post this in our local regional thread cause I was hoping to get intelligent responses.
  7. Sep 21, 2018 at 4:59 AM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    Got any pictures of them?
    christian06 likes this.
  8. Sep 21, 2018 at 5:46 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Ok there firecracker. Put it where the spare tire mounts if you don't wheel, put it in the bed if you do wheel.
    Kwikvette likes this.
  9. Sep 21, 2018 at 6:50 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    So I don't wheel as much as most, but I'm planning to change that as the truck gets older. This was actually where I was planning on putting a tank. I was hoping to get a full-size spare mounted on a bumper or tailgate to clear the space underneath.
    Why do you say don't mount it underneath if you wheel?
  10. Sep 21, 2018 at 6:51 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    i have mine over the raised wheel well on the driver side.
    Slashaar and EdinCincinnati[OP] like this.
  11. Sep 21, 2018 at 7:44 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    that viair relay pressure switch thing is crap as well. if you want to run something like that id suggest just buying a small pressure switch that ties into the relay coil for turning on/off the compressor
  12. Sep 21, 2018 at 7:49 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    I guess it depends on where you wheel and how hard you wheel but it's just a puncture risk. I've seen folks scrape their spare up pretty good on the way to hanging their diff. Obviously an air tank is more sturdy than rubber, but I'm not interested in testing how much so
  13. Sep 21, 2018 at 7:54 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    People also mount stuff under the drivers side bed cubby. Not sure how big your tank is, or how much it weighs though
    Gunshot-6A likes this.
  14. Sep 21, 2018 at 8:03 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Good to know!!! When it craps out...does it just keep the compressor running until the relief valve activates?
    Just wondering what to look for if it does fail.
  15. Sep 21, 2018 at 9:36 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i smashed mine :laugh:
    im just suggesting going a better route and avoid installing it all together. its bulky and looks like shit. buy a cheap pressure switch. i dont even use one tbh
  16. Sep 21, 2018 at 11:51 AM
    Wild Crow
    Wild Crow Well-Known Member
    James
    Anywhere is home
    2014 Baja
    Tank and pump are mounted in the bed and can be disconnected and removed. The box is mounted using t bolts in the bed rail. Pressure switch and QD connector for air hose is in the tool box side door of the cap right above the pump/tank combo
  17. Sep 21, 2018 at 12:28 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Very nice!!
  18. Sep 21, 2018 at 2:38 PM
    whipper
    whipper Well-Known Member
    2007 PreRunner
    I put two 2 - 2 1/2 gallon tanks 1 on each side behind rear tires. I20180513_064738.jpg 20180513_064700.jpg nstalled a regulator and quick connect fitting. 20180921_142316.jpg 20180921_142401.jpg 20180921_142305.jpg20180921_142247.jpg
    bikerx, samysquanch, robfox and 10 others like this.
  19. Sep 21, 2018 at 7:07 PM
    SR-71A
    Zack
    Southern Maine
    Damn, that is a sweet setup!
  20. Sep 21, 2018 at 8:50 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
