OME Dakar Leaf Pack: Medium or Heavy w/ Variable Load Weights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CoTacos, Jun 30, 2020.
  1. Jun 30, 2020 at 2:26 PM
    CoTacos
    CoTacos [OP] Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    I've been looking at these leaf packs and from what I've read here I'm still unsure which route I want to go.
    I've read the medium duty will carry about 300 lbs before sagging from the advertised 2 inch lift, and the heavy duty will carry about 650 lbs.
    That being said, I've also read you can just get the heavy duty and remove the 3rd leaf to make them the mediums.
    I will always have 200 lbs on the bed. RTT, & rack at minimum. In the summers, water, camp gear, cooler, recovery, gas, etc. gets added back there in the following configurations
    100% constant load (RTT & Rack): 200 Lbs
    Basic Camping Load: 350 Lbs
    Camping and wheeling/long distance load: 500 lbs
    Also noteworthy: I'm also running steel sliders and 3 steel skids. With plans for bumpers, winch, etc.
    I'm leaning towards the heavy duty ones since at full load I'll be pretty close to the max it will take, but if I unload everything for the winters and only have the 200 lbs on there, will I end up with a crazy high rear lift (rake)? Or will it always sit at the 2 inch lift and always be there until I put more than the 650 lbs load?
  2. Jun 30, 2020 at 3:13 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    get the HD's and install them with all the leafs. Ill bet you leave the 3rd leaf in (thats the leaf you take out to be a medium)
  3. Jun 30, 2020 at 3:18 PM
    CoTacos
    Steven
    Denver, CO
    With only the tent on though, will these things ride crazy high? Or do they always sit at the advertised 2 inches until you load it up with over 600 lbs?
  4. Jun 30, 2020 at 3:24 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I run Dakar HD with the AAL. I daily drive with bedrack, RTT, fridge, full skids/sliders/bumpers, and I have 35s.
    added camping weight is around 100lbs. I think im at 3" in the rear
    sanchez, Landpirate, Newlife and 2 others like this.
  5. Jun 30, 2020 at 3:25 PM
    CoTacos
    Steven
    Denver, CO
    Hrmmm...seems pretty consistent with the advertised info. I think I read its something around 2.75 on the 2nd gen's and 2 on the 3rd.
    CocaineAndCreatine likes this.
  6. Jun 30, 2020 at 3:26 PM
    fatfurious2
    David
    Ashburn, VA
    I think the AAL adds something like 66% weight capacity and less than 1/2" of actual height? I forgot now its been so long
  7. Jun 30, 2020 at 3:27 PM
    CoTacos
    Steven
    Denver, CO
    Oh you're right. I missed the fact that you did HD's with an additional AAL.
    fatfurious2[QUOTED] likes this.
  8. Jun 30, 2020 at 3:29 PM
    nd4spdbh
    SoCal
    My mediums after settling maybe get me 2in of lift with nothing in the back.
    CoTacos[QUOTED][OP] likes this.
  9. Jun 30, 2020 at 3:31 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Get the HD's or get a custom pack from deaver.
    I had HD Dakars and with a topper, HC swing out and a RTT (Empty bed) they were sitting flat or slightly negative arch.
    I got Deaver stage III U402's now
  10. Jun 30, 2020 at 3:31 PM
    arrakis429
    arrakis429 Waiting for the Mets to repeat 1986
    Ben
    Springfield, OR
    2016 Quicksand TRD Sport ACLB 3.5L 6MT (OVTuned)
    Fuel Mavericks w/ Falken Wildpeak AT3W 285/70/17 (Soon to be SCS Ray 10 w/ Falken Wildpeark AT4W 255/80/17) Leer 100 Topper + Prinsu Cabrack Cali raised Bed stiffeners RCI Sliders RCI skids Bilstein 6112 Front 5/4 w/ Eibach 700lb Coils SPC LR UCA's Bilstein 5160 Rear OME Dakar HD Leafs Wheeler's UBolt Flip w/ Bumpstops N2 Designs MT remote starter OVTuned ARB Awning w/ Windbreak and Deluxe 'Room' SpartanXCustoms Amber Scoop light Pelfreybilt Aluminum Front Plate Bumper w/ CaliRaised 32” light bar and Baja Designs Amber Squadrons Wide Cornering Warn Zeon 10s Platinum Winch 2Lo Mod URD Stage 3 Clutch with Heavy flywheel Accumulator delete mod TacoGarage Dash Multimount Warfab Phantom Rear Bumper OVTune Dump tubes
    Get the dakar heavy, I don't usually carry around much weight, have armor from the engine back, sliders - but when I do go drive long distances for whitewater trips I am totally loaded down with the bed full of gear and the canopy rack full. I also will occasionally transport bags of cement and gravel... I upgraded the suspension all around with 6112s 6/5 and 650 lb coils in the front and 5160s in back. I don't regret the dakar heavy at all and would be most likely underwhelmed with the mediums. Go heavy and don't look back.
    CoTacos[OP] likes this.
  11. Jun 30, 2020 at 3:33 PM
    fatfurious2
    David
    Ashburn, VA
    Im pretty sure my are sitting flat, but they still flex when called for. And this is my 2nd set. They hold some weight.
    Its hard for someone coming into the "game" of modding, to spend the $ for Deavers, so I get the appeal of the Dakars and AAL.
  12. Jun 30, 2020 at 3:33 PM
    CoTacos
    Steven
    Denver, CO
    Wow! Seriously?! Empty bed, that's gotta be like what...400-500 lbs at most?
  13. Jun 30, 2020 at 3:39 PM
    arrakis429
    Ben
    Springfield, OR
    Forgot here’s a picture with nothing but a hi
    Lift jack and a come along
    In the beds 7AB2EAC6-E4A5-4DE6-8A31-A2F2DC14A7BE.jpg10D1B480-08D6-4317-808C-D1CDC5CE2A3C.jpg
  14. Jun 30, 2020 at 3:53 PM
    PopeHodge
    PopeHodge Well-Known Member
    High Country, Colorado
    23 TRD OR DCLB
    100% get the HD’s.
    I got the mediums and almost immediately they were flat. Just put in the AAL and the ride is no different, but I’m no longer sagging in the rear.
    I’m not close to the “600lb constant load”
    Follow the advice you’ve received so far and get the HD’s and never look back.
  15. Jun 30, 2020 at 3:56 PM
    geekhouse23
    No doubt. But if you want them to hold some weight, you'll be looking to upgrade. Buy once, cry once.
    HC swing out, topper and a RTT is somewhere around 600 at my best guess.
  16. Jun 30, 2020 at 3:58 PM
    fatfurious2
    David
    Ashburn, VA
    Im on my 2nd set of Dakars + AAL :anonymous:
    geekhouse23[QUOTED] likes this.
  17. Jun 30, 2020 at 4:01 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    How are you liking them? I need to get out of my Dakars.
  18. Jun 30, 2020 at 4:05 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I am
    Running Dakars hd. Shell, rtt, storage, fridge 100% of the time in the bed. I’m adding the aal.
    PopeHodge and fatfurious2 like this.
  19. Jun 30, 2020 at 6:24 PM
    sprocket_rocket
    sprocket_rocket Well-Known Member
    2017 Quicksand TRD Off-Road DCSB M/T!
    glad I found this thread. I'm debating between HD and Med as well, with a 200lb cap and variable cargo weight of tools or supplies. To all recommending the HDs...do they ride rough when unloaded with the higher spring rate?
  20. Jun 30, 2020 at 7:07 PM
    CoTacos
    Steven
    Denver, CO
    Fwiw, some other threads said they ride surprisingly good even with little or no weight on them, but I will let those who actually have them chime in to confirm
