OME COILS SUCK
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jan 29, 2021.
  1. Jan 29, 2021 at 9:04 AM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Not very happy with the bilstein 5100 and old man emu 2880 coil combo on lowest setting. It’s about the same height as stock suspension with a 1.25” lift spacer. Was hoping for a little more lift than that.
  2. Jan 29, 2021 at 9:05 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    thats the coils fault not the shock lol
  3. Jan 29, 2021 at 9:06 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm not familiar with 880's but, Bilstein 5100's are adjustable. With that said, your coil provides lift.
    The other thing is, you upgraded your suspension.
    This will yield a different ride quality versus a stock setup and spacer lift...as the Bilstein will be valved different than stock.
  4. Jan 29, 2021 at 10:07 AM
    98_3RZ_NIC
    so I should have got 2881’s? I’m not replacing them though. They are gonna stay on there because that was a pain in the ass.
  5. Jan 29, 2021 at 10:07 AM
    coopcooper
    alberta canada
    Or move the collar up a notch
  6. Jan 29, 2021 at 10:11 AM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    BILSTEINS RULE
    phoenix ray and 98_3RZ_NIC[OP] like this.
  7. Jan 29, 2021 at 10:15 AM
    Tacoma1192
    Tacoma1192 GD MOTORSPORTS
    Kyle
    Boise, ID
    2015 DCSB Sport
    39's, LT, 4 Link, Spidertrax 9"
    .... "on the lowest setting".... "it's about the same height as stock"...
    well no fuckin shit.
    levie125, Poncate, DJB1 and 8 others like this.
  8. Jan 29, 2021 at 10:17 AM
    98_3RZ_NIC
    Bilstein said with the coils I got it has to be on the lowest setting for the safest ride quality.
    Z7Xtreme likes this.
  9. Jan 29, 2021 at 10:18 AM
    98_3RZ_NIC
    bilstein said with the coils I got and on the lowest setting it’ll still lift an inch to an inch and a half. Yeah it didn’t lift it that much.
  10. Jan 29, 2021 at 10:20 AM
    Tacoma1192
    Kyle
    Boise, ID
    2015 DCSB Sport
    you can't lift much past 2 inches without compromising down travel so yes, if want more lift, move the goddamn collar up a notch or two. not the end of the world
    levie125, JoeyWales, Mully and 2 others like this.
  11. Jan 29, 2021 at 10:22 AM
    coopcooper
    alberta canada
    hey dumb dumb they are lift coils your supposed to have the collar on the lowest setting
    treyus30 and Z7Xtreme like this.
  12. Jan 29, 2021 at 10:23 AM
    coopcooper
    alberta canada
    it might ride a little more firm but its fine
  13. Jan 29, 2021 at 10:24 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Sorry OP but this is funny.
    alarka, 98_3RZ_NIC[OP] and Z7Xtreme like this.
  14. Jan 29, 2021 at 10:26 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    So you ended up with about stock height + 1.25” spacer ish, and they told you you’d see about 1-1.5”?
    I’m either reading it wrong or that seems like you got what they told you.
  15. Jan 29, 2021 at 10:26 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    880s only advertise about 1" of lift, so yeah it will look lower than a 1.25" spacer. A 1.25" spacer on top of the coils will give you 2.5" of lift, if you're looking for that you want the 882 or 883 springs
  16. Jan 29, 2021 at 10:29 AM
    naaack
    naaack PUBG MOBILE: 彡No๏ḊʟєS
    naaack
    Exeter, CA
    4th Gen T4R
    Bilstein 6112/5160 Eibach 1" rear coils SCS Ray 10's 17x8.5 Falken Wildpeak AT3 285/70R17 Falken Wildpeak AT01 275/70R17 5th Gen T4R Brake Conversion 06+ OEM Headlight Conversion Xenon Depot 5K HID
    I was dying "lol's & hahaha's" :rofl:
  17. Jan 29, 2021 at 10:46 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Laughing aside, if there was a true misunderstanding on ride height perhaps whomever you purchased from would be willing to work with you on changing to a different coil with a higher ride height. Despite the ass pain for you to swap.
    It’s worth a try and the way in which you approach the seller (assuming you bought new) will dictate your odds of success. Honey over vinegar. Hope you get the outcome you’re looking for.
    otis24 and 98_3RZ_NIC[OP] like this.
  18. Jan 29, 2021 at 10:48 AM
    98_3RZ_NIC
    It is you dumb dumb
  19. Jan 29, 2021 at 10:48 AM
    98_3RZ_NIC
    I bought from bilsteins website.
  20. Jan 29, 2021 at 10:49 AM
    98_3RZ_NIC
    882 or 883 on lowest setting still? Or middle?
