OME 881 + 5100 too stiff, any other shock options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by c3 rolling, Mar 16, 2015.
  1. Mar 16, 2015 at 12:36 PM
    c3 rolling
    c3 rolling [OP] Well-Known Member
    Santa Clarita, CA
    04 PreRunner 3rz
    I recently installed brand new OME 881 springs with billy 5100's (Set at 0) on my 2004 2.7 extracab and they ride a bit stiff for the roads around me. Will investing in Nitrochargers really make a big difference in softening up the ride? Any other shock options that will work with the 881 spring? Hell I would even consider OEM type shocks if they will soften up the ride yet function well with the slight lift. Thank you. I did search but I couldnt find a very clear answer from people that felt the same way as I did.
  2. Mar 16, 2015 at 12:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Are the 5100s preloaded at all or are they set at 0? Springs should settle and be a little less bouncy with some time and miles under their belt.
  3. Mar 16, 2015 at 1:52 PM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    I have the OME 881's with 5100's set to zero. Now, I do have a little more weight with the 3.4 V6.
    It is definitely not a car-type ride, but it is one of the better "truck" rides I have been in. No complaints after about 40k since install. I don't remember if it was stiffer when first installed and loosened up - I don't think it has changed much, though.
  4. Mar 16, 2015 at 3:49 PM
    stumpman
    stumpman Well-Known Member
    tn
    2019 Dclb cement
    This would cause a stiff ride along with the fact it should not be preloaded.
  5. Mar 16, 2015 at 4:31 PM
    c3 rolling
    Santa Clarita, CA
    04 PreRunner 3rz
    The shocks are set at the "0" setting. I really enjoy the stable ride on smooth freeways/roads but it is too stiff when the roads are rough. I have less than 3k miles on the springs/shocks now and didnt notice a ride change other than the springs settling a tiny bit. I tried airing down my tires to 35 psi and that helped a tiny bit but is probably hurting MPG too. The light 4 banger definitely doesnt help. I was contemplating getting OEM spec Monroes and see if the ride improves. I think the springs may overpower the shocks though and be too short. The 881's gave me about 2.25 inches of lift. I think I can deal with the ride but its annoying hearing my wife complain that its a lot bouncier than the stock set up.
  6. Mar 16, 2015 at 4:35 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Tell her its a truck, go buy a caddy if she wants a plush ride. That's what I tell mine for a guaranteed eye roll
    04tacoadobo likes this.
  7. Mar 16, 2015 at 4:47 PM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    I went with OME 880s with 5100's (V6 DC) because I thought 880s were slightly softer, no complaints on ride.
  8. Mar 16, 2015 at 4:47 PM
    T4RFTMFW
    Might be just too lightweight for that spring rate?
  9. Mar 16, 2015 at 5:46 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I have that same setup on my 98 xtra cab 2.7 4x4 and it rides really nice, near stock imo.
    I do have a winch up front and a custom mount though.
    Probably just need to get them broke in.
  10. Mar 16, 2015 at 7:40 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I have a '99 with 881s and 5100 set at zero. It was noticeably stiffer, so much so that I removed the sway bar. Not recommended for daily use either. But I have a plate bumper coming and it should smooth out once it's mounted. When the wife rides with me she complains as well. But it's from her boobs bouncing.
    What tires are you running that you aired down to 35psi?
  11. Mar 16, 2015 at 7:49 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to ALL of this.
  12. Mar 16, 2015 at 9:42 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    well there's a fundamental problem with your setup. You're running a linear spring with a shock that's valved for a more progressive one. The 5100's are meant to be used with stock TRD coils which are progressive and the OME's are all linear which makes for an interesting style of coilover.
    I'd recommend you change either your coils to a softer linear, get some progressive coils, or change the shocks to match the coils (OME Nitrochargers).
    Oh and to the rest who say its a truck it'll ride like one: it's not a tractor it doesn't have to ride like a tank. there's nothing wrong with someone who expects they can get a better than stock ride out of a lift.
    Mujtaballa, mrjordan415 and steve2267 like this.
  13. Mar 16, 2015 at 9:45 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    and I feel your pain OP. had the same setup for a year and a half, put ~30k miles on that setup and HATED IT. It never softened and I wheeled the hell out of it on the weekends. Switched to Eibachs and I can't say it's a world better but my kidneys don't shift place over bumps anymore. That's a victory.
  14. Mar 17, 2015 at 1:08 AM
    c3 rolling
    Santa Clarita, CA
    04 PreRunner 3rz
    Thanks for the help! Which springs are linear that arent OEM? I'm not sure if the Eibachs are linear but they weren't an option because they exceed 3" of lift on the 2.7 xtracabs. I was originally going to purchase the OME 880 but I was told they are also 500# like the 881 so the ride is the same.
    Are the OEM V6 TRD springs different from standard Pre Runner springs on a 2.7? I always thought TRD tacomas seem to be higher in the font than my OEM springs.
    I am running Nitto Terra Grapplers 265/75/16 load range E. Not sure whats really ideal for a light truck like mine but it seems to be wearing evenly at that cold psi. I tried 40 psi + and it was bone jarring. My wife has smaller breasts so I don't even get the satisfaction of visible bouncing.
  15. Mar 17, 2015 at 9:03 AM
    T4RFTMFW
    E rated tires are really not helping your ride.
  16. Mar 17, 2015 at 9:07 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    Outside of Eibach and OME, I don't see many people running other springs. They're pretty much the most popular around here. Other than that people usually run full coilover setups (Fox, King, Icon, etc).
    You might look into Pro Comp but I feel like they're not as "serious" about off roading and quality parts as others.
    Yeah the TRD springs are different than the regular V6 springs and I think 4cyl also have different springs (not exactly sure). You could experiment with these different springs or ask around to some other dudes who have run a couple different ones.
    I feel your tittie pain.
    I run as low as 32 up front and 30 in rear just to offset the stiffer lift I have.
  17. Mar 17, 2015 at 11:00 AM
    Brake Weight
    It'd be just as easy to put the factory springs back on and put the plate at the 2.5" setting.
  18. Mar 17, 2015 at 12:25 PM
    T4RFTMFW
    I'm not sure there's any ride improvement going from 881s to fully maxed out 5100s on stock coils.
    I'd try a softer spring, softer strut, softer tire, or any combination thereof instead.
  19. Mar 17, 2015 at 10:21 PM
    scocar
    scocar hypotenoper
    35 psi is still very high. You should be closer to 26 front 28 rear, check your door sticker and try lower pressure.
    I had 881s and 5100s set on zero, and they seemed to get stiffer over time. I ditched them and got nitrochargers, which are designed specifically to work with the OME coils. Much better.
    You could also try removing your swaybar. You need to be a little more cautious driving in certain conditions, but it allows the front to be truly IFS and helps to soak up bumps better. I took it off and left it off.
  20. Mar 17, 2015 at 10:23 PM
    T4RFTMFW
    Good post.
