Old Man Emu setups on 1st gens
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Feb 19, 2011.
  1. Aug 19, 2018 at 12:09 PM
    #4001
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    Watch "Old Man EMU Dakar Leaf Installation on a 2013 Tacoma" on YouTube
    https://youtu.be/31ORzqSCKHQ
    this vid helped me with the rear
  2. Aug 19, 2018 at 12:11 PM
    #4002
    TacoSauce04
    David
    ARE Shell
    Watch "Suspension Lift (Coils and Shock Replacement)" on YouTube
    https://youtu.be/0HJx6HH2yno
    this vid helped with the front
  3. Aug 19, 2018 at 12:16 PM
    #4003
    TacoSauce04
    David
    ARE Shell
    OEM Pitman arm puller for light-trucks screw type 27170 - Read Reviews on OEM #27170
    https://m.autozone.com/loan-a-tools...r-for-light-trucks-screw-type/209523_0_0?aqs=
    i rented this puller because the stock arms are too wide for the standard pitman arms found around town. i did however have to buy longer bolts with nuts (atleast 1" longer) in order to fit over the UCA and press down the UBJ.
  4. Aug 19, 2018 at 1:11 PM
    #4004
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Wonder if this will help me from rubbing the pinch weld on mine
  5. Aug 19, 2018 at 4:04 PM
    #4005
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I think @Wheeler's Off-Road Inc sells those.
  6. Sep 3, 2018 at 3:08 PM
    #4006
    Dirty White
    Dirty White Well-Known Member
    02 DC Prerunner and 03 ext can prerunner
    2002: 2.5" ome lift springs, 2.5" lift bilstein 5100 front shocks on oe coils and 5100 rear shocks. Topper. 285 75 16 toyo at2s. K&N intake. 2003: super spring progressive aal. Slide master 1000lb bed slide. Custom utility bed with lumber rack. Diamond aluminum 6ft boxes.
    I have a pair of 882's that have about 5000 miles on them. To stiff for my prerunner. I'm looking to trade someone that has 881's with a 10mm top spacer for my 882's . All you guys that are adding weight up front and ready to upsize your springs let's trade!
  7. Sep 3, 2018 at 3:30 PM
    #4007
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I’m so excited to drive my truck after the 4x4 conversion/skid and winch is done. It’s been a rough 10 months. Do you have a bad lean going on with your Prerunner and the 882s?
  8. Sep 3, 2018 at 3:45 PM
    #4008
    Dirty White
    Never installed em. Bought em used fir a good price before I really did my homework. The more research I did, the more I knew it would be a bad call.
    04Pre_Runner[QUOTED] likes this.
  9. Sep 3, 2018 at 5:35 PM
    #4009
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I am about an inch higher in the front completely stock other than suspension. I'm probably just going to roll with it til I can get a new bumper
  10. Sep 6, 2018 at 9:28 AM
    #4010
    QuikSilver02
    QuikSilver02 Well-Known Member
    A.D
    02 DC 3.4L PreRunner. 1STGENN
    881 + 5100s + 10mm spacer plate 265s with TKOS Roof Rack Pioneer stereo Tailgate brake light Spyder tail lights Custom grille with toyota letters JBA UCA's Nerf Bars
    just installed 881s + 5100s + 10mm plate
    with my new JBA UCA's
    ride is firmer, smooth and feels great.
    Measurements before with 3inch spacer was 24"
    With new setup im at 24 3/8" on both sides.
    No lean.
    time to do a build thread now :bananadance:
  11. Sep 6, 2018 at 11:22 AM
    #4011
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    I install my full Ome setup (881, Dakar Leaf pack, and spc uca) which gave me about 2” rake in the back. However I also now have the full All Pro armor (front/rear bumper, sliders, skid plates, no winch yet). I have a V6 Double Cab 4x4 which is the heaviest configuration for the 1st gen. I’m going to switch to the 883 springs and get the Toytec 1/2” top plate spacer. Will this be a good move? Even with the plate spacer I figure I would still have a little back rake which is fine. Hopefully it will only be a 1” rake?
    Thanks for the input.
  12. Sep 6, 2018 at 12:32 PM
    #4012
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    you prolly won't need the top plate spacer with the 883's.
    And the rear will settle a bit over time. Throw some sandbags in there for a bit and that will help settle them out.
  13. Sep 6, 2018 at 2:39 PM
    #4013
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    My 881s are finally broke in with a .25 top plate and the same setup as you. My front.is 23.25" inches Center hub to flare. And 38 overall.
    The real question is do you like the ride characteristics now, if not to soft the 882 has the same rate just longer and a top plate for fine tuning if it nose dives and is sloppy the 883 has a higher rate or stiffer ride, but the same length.
    I enjoy my 881s and will end up on 882s with a .25 or .50 top plate. With the family, full tank I'm at 4k total.
  14. Sep 6, 2018 at 3:13 PM
    #4014
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    So you also have full body armor and a winch? I don’t have a winch yet but just my Apex bumper with skid plates is about 150-160lbs up front. Most winches are about 70lbs so that would put me over 200lbs easy just in the front.
    I hear 882 aren’t really recommended anymore since they are just taller which will eventually sag. That and they put more strain on your cv without a steel bumper and diff drop?
  15. Sep 6, 2018 at 3:20 PM
    #4015
    Adude
    Pnw
    04 Double cab
    I dunno man, Its all interchangeable so It comes down to personal preference right. Each truck and driver are not identical situations or parameters. And 883s will stress your CVS ect out as well. They have a higher spring rate so they dont compress as much making it a higher ride. Do you agree?
    Edited first half.
  16. Sep 6, 2018 at 3:23 PM
    #4016
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Yes I agree that’s why I am only considering it because I have full body armor. I also have a diff drop as well. If I was stock I would just stick with the 881 I already have. Anyways thanks.
  17. Sep 6, 2018 at 4:47 PM
    #4017
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    they give the same lift as the 883's, just a softer ride. Does not affect the CV any more than the 883's will.
    I've been running 882's for a couple years now, no sagging. The top plate spacer, if used, will cause more harm to the upper ball joint.
    I've run all 3 springs 881, 882, and 883. There is a comparison in my build thread.
    Adude likes this.
  18. Sep 6, 2018 at 5:09 PM
    #4018
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Thanks. I’ll check out your build. How else would someone minimize the rear rake without using spacer? Would having spc uca help with the ball joint wear? I read that 1/2” spacer were the max size while still being safe without extra wear?
  19. Sep 6, 2018 at 6:17 PM
    #4019
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    SPC would be fine.
    Anther way to minimize the rake is to remove 1 leaf from the rear pack.
  20. Sep 6, 2018 at 6:41 PM
    #4020
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Its a great feeling huh? Loved taking my spacers off lol
