Okay to put wax on black vinyl wrap material between doors?
Discussion in 'Detailing' started by rob4092xx, May 10, 2017.
  1. May 10, 2017 at 5:57 AM
    rob4092xx
    rob4092xx [OP] Well-Known Member
    Phoenix, AZ
    Getting ready to put my first coat of wax on my 2017 Limited Tacoma and am wondering if it okay to wax the black vinyl pieces located between the driver's and passenger doors on each side? These are the pieces that fit between the two door's window glass, above the handles. Thanks!
  2. May 10, 2017 at 6:23 AM
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    sure... its just vinyl
    CusterFan and Tacowin1013 like this.
  3. May 10, 2017 at 6:28 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    sure why not! It just won't really benefit the vinyl any and if you happen to muck it up--most people remove theirs anyways :). I leave mine on because i use that to close my door to prevent from surface scratches down the road. You can put wax on just about anything---its not like the old turtle wax that used to stain stuff white like the old days. Hell you can even put wax/sealant on your glass and it works like rain-x.
  4. May 10, 2017 at 8:27 PM
    DST75
    DST75 Well-Known Member
    Omaha, NE
    2017 BBP TRD Sport DCSB w/ JBL
    Depends on the wax. I used Meguire's Ultimate Liquid Wax https://www.walmart.com/ip/Meguiar-s-Ultimate-Liquid-Wax/16550272 and did two coats on the whole truck when I first bought my truck about 3 weeks ago. I waxed those pieces you're describing and have one of the flat black hood decals and waxed that too. Just don't let it dry and harden and it will buff right off.
    Benzdriver81 likes this.
  5. May 10, 2017 at 8:34 PM
    LawTaco
    LawTaco Well-Known Member
    Lawrence
    Bay Park,San Diego,Ca
    TRD SPORT 24
    I wax mine to keep them looking new it doesn't hurt the vinyl it freshens and protects it . The wax I use is canuba and not abrasive from detail supply store
  6. May 10, 2017 at 8:38 PM
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    Don't use an abrasive wax and you'll be fine. I've used Killerwaxx Love Potion (non abrasive) on a partial wrap before and it worked well.
  7. May 11, 2017 at 3:06 AM
    rob4092xx
    Phoenix, AZ
    Thanks everyone for taking the time to respond!!!
    Hondah likes this.
  8. May 11, 2017 at 3:19 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Wax won't last a month in AZ. You should look into some type of sealant. Polymer net shield, chemical guys v7, opti seal are a few I really like. Wax is tedious and doesn't last long.
  9. May 11, 2017 at 3:27 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I wouldn't. Armour All or other UV blocking product. If you have to strip the wax, the stripping product could have a detrimental effect on the vinyl.
  10. May 11, 2017 at 4:03 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    I wouldn't armor all anything! It dries stuff out. A good citrus wash like the ones chemical guys makes will strip any type of protectant off and not harm trim or vinyl.
  11. May 11, 2017 at 4:57 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    Hydro2 is the way to go, lasts long and is stupid easy to put on. However you do need to apply it without the sun beating on the vehicle and a pressure washer or a good spray hose is a must. Work in small sections at a time, you don't want to leave it on the vehicle long.
  12. May 11, 2017 at 5:40 AM
    robssol
    Rob
    S. Wisconsin
    OK
  13. May 11, 2017 at 6:28 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Love this stuff, easy on , easy off and long lasting.
    CusterFan likes this.
  14. May 11, 2017 at 8:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I use 303 protect on that black vinyl area.
    Clay7160 likes this.
  15. May 11, 2017 at 8:21 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I'm going to have to try it. Been using Duragloss #105.
  16. May 11, 2017 at 9:37 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    still shouldn't put wax on non-painted plastic though. like for instance the black fenders on TRD ORs
    Benzdriver81 and shakerhood like this.
  17. May 11, 2017 at 9:40 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    I just pulled mine off, looks much better without them.
  18. May 11, 2017 at 11:09 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Menzerna powerlock is great too. I've been interested in polymer net shield; how do you like it?
  19. May 11, 2017 at 11:11 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    We like helping out around here. :thumbsup:
  20. May 11, 2017 at 11:25 AM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    I like it a lot, depending on temperature and humidity, it can be sorta a pain to use sometimes though. Power lock is great stuff. Guess I've gotten lazy and like the stuff I can get the whole vehicle done in <5 minutes though lately lol.
