Ok to use head gasket stop leak to diagnose issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ides98, Aug 16, 2017.
  1. Aug 16, 2017 at 12:18 PM
    ides98
    ides98 [OP] Active Member
    I have a 2006 Tacoma, 4 cyl. I've noticed coolant being consumed but no leaks externally. Also had burning smell under hood with some white vapors upon startup for about a month. Thought it might be valve cover leak. Mechanic noted slight oil leak at valve cover but nothing notable that needed repair yet. The smell has gotten more frequent in last week or so and had to add coolant twice. Collectively with these two symptoms wondering if I might have a head gasket leak. No rough idling or misfires though. I am thinking of adding a head gasket stop leak product into the coolant reservoir to use as potential diagnosis of head gasket issue. Will this stuff hurt my engine if there's no leak? Any recommendations on quality brands? Thank you for any help.
  2. Aug 16, 2017 at 12:29 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    I'd only use that crap as a last resort. Like, it's either this or I tear the entire engine apart.
  3. Aug 16, 2017 at 12:31 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    All stop leaks are advised against. Is there coolant in your oil? White smoke from exhaust? The coolant has to be going somewhere. Has the system been pressure tested by a mechanic?
    98tacoma27 likes this.
  4. Aug 16, 2017 at 12:31 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No do the proper test.
  5. Aug 16, 2017 at 12:31 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    It sounds like a head gasket to me. Instead of using stop leak, run and then check your plugs. If one or more look wet then you guessed right
  6. Aug 16, 2017 at 12:33 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Do a block test to determine if exhaust gasses are present in the cooling system. The kit is pretty cheap and it doesn't take long to do.
  7. Aug 16, 2017 at 12:53 PM
    ides98
    Oil looks normal on dipstick and haven't noticed anything from exhaust. I'll check plugs for wetness and look into other suggested kit. I travel full time in the truck and not in a place where I know a trustworthy mechanic. Trying to diagnose before taking so I can inform someone of what to look for and not get screwed over (I prefer to look credible considering my gender and past experience.)
  8. Aug 16, 2017 at 12:56 PM
    ides98
    So thank you all for helping me look credible btw :)
  9. Aug 16, 2017 at 1:04 PM
    Justinlhc
    Can I assume your gender? :spy:
    CurtB likes this.
  10. Aug 16, 2017 at 1:05 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I've used Bars Leak successfully in the past.... like 30 years ago. No way would I put it in a modern engine.
  11. Aug 16, 2017 at 1:14 PM
    ides98
    Not really no. I prefer to be considered a third gender. My mechanical and analytical skills well exceed any engendered and assumed domestic abilities. Unfortunately society still sucks ass and assumes you don't know anything if you look female. Just had to vent.
    Torspd likes this.
  12. Aug 16, 2017 at 1:19 PM
    Justinlhc
    :ohsnap:
  13. Aug 16, 2017 at 1:22 PM
    Bebop
    Nick
    Word...
  14. Aug 16, 2017 at 1:36 PM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Have you seen today's males? They are bigger bitches than most females. I assume nobody knows anything.
    TrapComa and TexasWhiteIce like this.
  15. Aug 16, 2017 at 1:39 PM
    Bebop
    Nick
    This!!!!!! You wouldn't believe the number of grown ass "men" that can't put air in a tire without assistance. Or even drive a 5 speed manual.
  16. Aug 16, 2017 at 1:41 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Never use those stop leak things unless you need some leak to stop dripping right before you sell a vehicle.
  17. Aug 16, 2017 at 2:58 PM
    ides98
    Thanks again for all the input. I'll stay away from the stop leak and try out ways to diagnose as suggested.
  18. Aug 16, 2017 at 2:58 PM
    ides98
    You may have just read my mind but only if it comes down to it. ;)
  19. Aug 16, 2017 at 5:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That stop leak works by plugging basically everything, then hardening. It is only to be used if you don't care about the engine, and HAVE TO get somewhere.
    It will plug up the small coolant ports & passages in the heads, plug up radiator passages, mess with the water pump.... ask me how I know, if you really want.
  20. Aug 16, 2017 at 5:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Also, @ides98 , take a peak underneath the water pump. There is a weep hole which tends to leak.
