OK, all bullshit aside
Discussion in 'Audio & Video' started by beaverseeker, Jun 27, 2014.
  1. Jun 27, 2014 at 12:46 PM
    beaverseeker
    beaverseeker [OP] Member
    Safford Arizona
    2009 shortbed double cab prerunner
    Spyder headlamp housings, HID low beams, 20 inch GENSSI led light bar, all interior and exterior lights converted to LED, lighted cup holder, pop and lock tailgate wired to door locks, valentine one radar detector,removed the ugly sun-visor stickers
    I have changed out my factory HU in my 2009 Tacoma 4 door.
    I am installing 2 10 inch sub's behind the seat powered by a 1600 watt Rockford Fosgate amp.
    Question is, are the RCA cables at auto zone good cables or is it really necessary to purchase the expensive ones? How much of a sound difference do the more expensive ones really give?
  2. Jun 27, 2014 at 12:53 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Don't get cheap ones for your project. Get the best shielded ones you can with good solid gold connections and quality strands. The potential interference you can get from cheap wires is the worst you will deal with. Alternator whine, crackling, etc. all get in through cheap RCA's. Spend the money and get something good that is designed for higher power car audio installs. And don't go to Walmart.
  3. Jun 27, 2014 at 12:55 PM
    Aw9d
    Aw9d That one guy
    No.
    What amp are you running from Rockford that is 1600watts?
  4. Jun 27, 2014 at 1:04 PM
    beaverseeker
    Safford Arizona
  5. Jun 27, 2014 at 1:08 PM
    Aw9d
    Aw9d That one guy
    That 600 watts. Can you list all the parts he is installing? The most you are going to get out of your two subs is 150watts max. Since this is a prime amp (low end Rockford) it's more like 100watts per sub.
    if your install guy is going to vatozone for cables, you might want to find a new install guy. Either he doesn't know what he is doing or he's trying to pull a fast one on your.
    List everything he is installing, give me more details. I'm in Az and I have a buddy who knows Safford pretty well. We might be able to find you a better place to go.
  6. Jun 27, 2014 at 1:16 PM
    beaverseeker
    Safford Arizona
  7. Jun 27, 2014 at 1:19 PM
    Aw9d
    Aw9d That one guy
    That amp will work with those subs just fine.
    Get some good RCA's.
    Should sound pretty good. Good luck! Keep us posted on the build.
  8. Jun 27, 2014 at 1:21 PM
    beaverseeker
    Safford Arizona
    Thanks, not wanting a huge system, just a little better than stock
    The guy that is installing it is a friend, not charging
    Thanks for the info
  9. Jun 27, 2014 at 1:36 PM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    get some good quality RCA's you can get some really good ones off Amazon. I have a set of monster (have had them for 4 years) and they are great quality.
