Oily PCV valve
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmross, Jun 2, 2021.
  1. Jun 2, 2021 at 11:39 AM
    tmross
    tmross [OP] Well-Known Member
    2002 Tacoma 2.4L 2wd Reg Cab
    Just pulled the hose off my PCV valve to check on it and its full of oil, oil dripping down it and out of the hose. Its a brand new valve, the old one was a little oily too. Is that normal / what does this indicate?
  2. Jun 2, 2021 at 11:48 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I actually just replaced mine yesterday and noticed the same thing. As long as you're not using oil between changes then you should be fine. Some people install a catch can if they're worried about the amount of oil going into the intake.
  3. Sep 24, 2021 at 4:07 AM
    RustyShackaleford
    RustyShackaleford R. Shackleford
    Rusty
    2004 Tacoma 2.4 2WD
    tmross, I need to replace my PCV but I have not been able to successfully find a diagram of where it is located. Do you mind posting a pic of where it is located? I have almost the same model 2004 2.4l 2wd Xtracab. Thank you much
  4. Sep 24, 2021 at 4:13 AM
    goldentaco03
    Liam
    NJ
    Rear of the valve cover near the firewall. You’ll see a hose about 1 inch in diameter coming off it, held on with a spring clamp
  5. Sep 24, 2021 at 7:02 AM
    tmross
    (with hose removed) between the 3rd and 4th coils
    AAWUweUdrzppEhKNmG3F8suMOFLNCSsXCauUaznH_0b7d9857dc7423a0abaf5bad1a900c8352b5f162.jpg
    RustyShackaleford likes this.
  6. Sep 24, 2021 at 8:52 AM
    99taco80
    99taco80 Member
    Daniel
    99 Black Tacoma SR5
  7. Sep 24, 2021 at 8:55 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
  8. Sep 24, 2021 at 9:02 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Oil in the PCV is normal.
    Oil mist, atomized, is carried out of the hot crankcase. The oil mist will condense when it hits the cooler temperature outside of the c'case. This is why the hose leads back to the engine intake, so the oil can be burned.
    Although, on a 2002, this could indicate the piston rings are worn allowing excessive blow-by.
    What is your oil consumption between oil changes?
    Mileage?
  9. Oct 18, 2021 at 11:38 AM
    RustyShackaleford
    Rusty
    2004 Tacoma 2.4 2WD
    Thanks for all the assistance everyone. Here are some additional pics to help those in a similar situation.
    USMILRET likes this.
  10. Oct 18, 2021 at 11:44 AM
    RustyShackaleford
    Rusty
    2004 Tacoma 2.4 2WD
    I have about 185k miles. Oil consumption varies. Anywhere from a quart a month to nothing needing to be added. Almost two months ago I went from GA to MI and back with no issue and oil was normal. Then about two weeks later my oil was almost on empty. I changed PCV about two weeks ago and so far so good. Fingers crossed.
  11. Oct 18, 2021 at 11:47 AM
    RustyShackaleford
    Rusty
    2004 Tacoma 2.4 2WD
    Just out of curiosity, does anyone clean their PCV instead of buying a new one. For less than $4 I bought a new one from Rock Auto.
  12. Oct 18, 2021 at 12:03 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Careful with those pcv's on the 2001 - 2004 models....
    there's a number who over torque that soft aluminum ....and heard that dreaded POP...
    evidently that cover is a little thin there.....
    For us older taco heads.....that $3 doorman grommet fails/turns to shit....and then you've got a rubber party on top your valves......so I dig it out and replace it about 18mo....
    You look at it at the top of the engine and it looks fine....but over time and heat at some point....MAJOR VACCUM LEAK going on there......because there's no bottom on it anymore.....valve happy hour.....
    and for those real oily ones...leaky internals....I'd grommet every 12mo....
    Wish they made silicone ones....someone finds em, I'll buy....dont care what it costs
  13. Oct 18, 2021 at 12:31 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Nice delete there Rusty
  14. Oct 19, 2021 at 5:26 AM
    RustyShackaleford
    Rusty
    2004 Tacoma 2.4 2WD
    I don't understand. What did I delete? All I recall doing is posting some pics and adding some text.
  15. Oct 20, 2021 at 2:04 AM
    USMILRET
    The Exhaust Gas Recirculating system and I initially thought you did it, I stand to be corrected.
