Oil Type and Brands?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Amanwithnoplan, Dec 29, 2021.
  1. Dec 29, 2021 at 6:19 AM
    Amanwithnoplan
    Amanwithnoplan [OP] Member
    Sievrrhyn
    2015 Black Tacoma TRD Pro
    I am going to change my oil this Friday and AutoZone says my 4.0 V6 uses conventional oil, not synthetic. I have synthetic in now from when I bought it from the dealership. The truck just hit 60,000 miles. Should I continue using standard synthetic 5w-30 or switch to high-mileage? Is there a "better" brand to use?
    tacotoe likes this.
  2. Dec 29, 2021 at 6:26 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Synthetic is fine, so is conventional. Don’t mix them together. Make sure whatever brand you use is API certified (look on the bottle, it should have a stamp for this unless it’s cheap garbage).
    No need for the high mileage stuff.
    Suggest using an OEM Toyota filter if you can get them.
    Welcome to Tacoma World.
    Edit: Seems the haters are out today so let me clarify. You CAN mix conventional and synthetic, it is my OPINION that you shouldn’t because really what’s the point. This is not bad information. Id personally just use synthetic because it’s cheap nowadays and same base anyways. Anyone calling this fake news should go circlejerk themselves on Bob Is The Oil Guy for a while and see how that works out.
    Edit 2:
    This has all been done before. 36 pages of who has the best oil: https://www.tacomaworld.com/threads/best-motor-oil.58460/
    Fantastic thread with more filter pictures than a pinup calendar: https://www.tacomaworld.com/threads/toyota-oil-filter-made-in-thailand-vs-the-competition.123608/
    I'm off to do something actually productive now. Good luck OP.
  3. Dec 29, 2021 at 6:33 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Change it ever 5k miles and use either one as long as certified as suggested above. (Clean that MAF sensor at each oil change as well)
  4. Dec 29, 2021 at 6:42 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Mobil 1 and a Toyota filter
  5. Dec 29, 2021 at 6:43 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  6. Dec 29, 2021 at 6:44 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    SuperTech and a Toyota filter.
  7. Dec 29, 2021 at 6:45 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    Walmart has synthetic oil cheap. AutoZone has K&N filters.
    NAAC3TACO likes this.
  8. Dec 29, 2021 at 6:53 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    To meet the 2011 gf5 standard, most conventional oil is a synthetic blend. You own one of the best built V6 engines ever made. Just change the oil regularly with a quality 5w30 and a good oil filter and your engine should last you a very long time. I’ve been in the auto repair business for over 30 years and I’ve never seen an engine failure due to brand of oil, only lack of maintenance.
  9. Dec 29, 2021 at 6:54 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    This. I started with Mobil 1 and then switched to SuperTech after seeing some test results and deciding the extra money wasn't worth it. I do use Toyota filters though.
  10. Dec 29, 2021 at 7:15 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    AL W, tacotoe and kidsmoke like this.
  11. Dec 29, 2021 at 7:17 AM
    Amanwithnoplan
    Sievrrhyn
    I see the general consensus about using a toyota oil filter. Since the filter screws downward, it would be difficult to put some oil in the filter. Some friend of mine swear by this and some other say to keep it dry. Is there any actual benefit to doing either?
    tacotoe likes this.
  12. Dec 29, 2021 at 7:25 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Whoever said this is a fucking idiot. Use synthetic oil, welcome to the 20th century
  13. Dec 29, 2021 at 7:26 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No not with the tiny filter most gas engines use, the few secs the engine runs without oil pressure won't hurt a thing.
    Now the big diesel filters that hold 1 quart+ those I usually will pre fill.
    reallifedog and jlemmond like this.
  14. Dec 29, 2021 at 7:27 AM
    Gen2 Man
    Midwest
    07 Sport DCLB
    This is dead wrong information. Conventional or synthetic are fully compatible can be mixed. The amount of bad info here is astounding
  15. Dec 29, 2021 at 7:28 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Dab some oil on the filter gasket and spin it on. No need to worry about filling these small filters with oil.
    Plain Jane Taco likes this.
  16. Dec 29, 2021 at 7:30 AM
    Gen2 Man
    Midwest
    07 Sport DCLB
    Try this anyway. Prefill the filter and you’ll see the oil soak into the pleats, turn it on its side you can usually wet the filter enough then just turn the engine over without starting. It usually primes very quickly.
    tacotoe likes this.
  17. Dec 29, 2021 at 7:32 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    You should use synthetic oil. I buy Napa Synthetic 5w-30 on sale for around $4/qt, and use a Toyota OE oil filter (2005 4.0 v6)
  18. Dec 29, 2021 at 7:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Hypothetically there is a benefit to prefilling the filter, and I prefill the cartridge housing on my 3rd gen, but it's obviously too messy with the upside down filter.
    Depending on which part of the country you live in, don't worry about the Tacoma powertrain. Spend your time and money on corrosion protection, because ultimately rust will be the limiter on the truck's life.
    willie2, tacotoe and NAAC3TACO like this.
  19. Dec 29, 2021 at 7:37 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Montana_Actual likes this.
  20. Dec 29, 2021 at 7:40 AM
    10thMTNgrunt
    2013 TRD Sport
    When did you snag your Pro, was it recently (in this shit show of a sellers market)?
    Either way congrats on owning the sweetest Taco ever put together (15 Pro), in my opinion.
    And take good care of her:thumbsup:
    tacotoe likes this.
