Oil sitting on top of coolant “overflow tank”
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Texastaco2010, Dec 19, 2021.
  1. Dec 19, 2021 at 12:42 PM
    Texastaco2010
    Texastaco2010 [OP] Well-Known Member
    2010 TRD Tacoma
    2010 4.0 95k miles
    The other day i noticed my overflow looked dirty inside but the coolant was still pink, looked inside and saw what looked like oil sitting on top of the coolant *not mixed. I checked the radiator and the coolant was not milky nor is my oil. My motor has never over heated. The day I noticed was the day before I had a big trip, I drove about 5k and truck never over heated or skipped a beat. I check the trans and still red as ever. I removed the oil sitting on top of the coolant but getting back from my trip it returned. My oil was not low either. What are y'all thoughts? I read it could be a faulty oil cooler. But not sure trying to see if can figure it out before I take it in. I added some photos of the overflow how it looked and the oil spots and the coolant I removed
  2. Dec 19, 2021 at 12:43 PM
    coff33
    coff33 Well-Known Member
    5vzfe manual
    old coolant + corrosion
  3. Dec 19, 2021 at 12:46 PM
    Texastaco2010
    2010 TRD Tacoma
    I thought the same and no when I tried to clean the overflow tank the top part of the overflow became milky
  4. Dec 19, 2021 at 12:47 PM
    Texastaco2010
    2010 TRD Tacoma
    Coolant still clean
  5. Dec 19, 2021 at 12:49 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Head gasket?
  6. Dec 19, 2021 at 12:52 PM
    Texastaco2010
    2010 TRD Tacoma
    Lol man ill be so pissed if it is at 95k but I'm hoping it ain't since it never over heated ever
  7. Dec 19, 2021 at 12:54 PM
    Texastaco2010
    2010 TRD Tacoma
  8. Dec 19, 2021 at 1:17 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    A few thoughts in no particular order of importance. First, oil will float on water and coolant, so this is why it's showing up in the top of your coolant overflow tank. Second, it doesn't take much oil at all to show up like that. A little bit goes a long way. Since there is no oil in your cooling system normally, it has to be coming from someplace it already is - like your crank case. The most common way for it to get between those two closed systems is a failed head gasket. Why isn't your oil level going down if you have a failed head gasket and it's allowing oil to get into the coolant? Because the amount is too small to show up on your dip stick.
    How do you determine if you have a failed head gasket? A cooling system pressure test will show it if the failure point is big enough. Time for professional help.
  9. Dec 19, 2021 at 2:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I wouldn't worry just yet. The coolant sample you took out looks fine, the reservoir plastic just looks a little "stained"
    Remove the reservoir and wash it out with really hot soapy water, and then monitor it for a while
  10. Dec 19, 2021 at 8:22 PM
    OnHartung'sRoad
    I hope its not too, sorry if it is. Overheating isn’t always a symptom or cause of a bad gasket though. You may have only won the bad lottery. Get some help with that though- they can test it. Hopefully its something else and not as big of a deal.
  11. Dec 20, 2021 at 4:01 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    What's the pH of the coolant? 7pH is target, +/- 0.5pH is acceptable. Anything higher or lower is time to replace. Too long in that condition will start breaking down gaskets and metals.
  12. Dec 20, 2021 at 4:05 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Test the coolant for exhaust gasses.
    wi_taco likes this.
  13. Jan 6, 2022 at 1:27 PM
    Texastaco2010
    2010 TRD Tacoma
    So i tested it multiple times and i did not have any exhaust gas in the coolant used near half the bottle tested it for about 10 min and the fluid did not turn color
  14. Jan 6, 2022 at 1:28 PM
    Texastaco2010
    2010 TRD Tacoma
    Have you ever heard of oil coolers going bad ?
  15. Jan 6, 2022 at 9:32 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If it came back after your trip, something is definitely not right. Did you check the ATF again? believe Blackstone or other similar business can test the coolant. Maybe have the ATF and motor oil tested for coolant also.
  16. Jan 7, 2022 at 12:58 AM
    Texastaco2010
    2010 TRD Tacoma
    Do you have there website so i can send some samples
  17. Jan 7, 2022 at 2:13 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
  18. Jan 7, 2022 at 2:25 AM
    Texastaco2010
    2010 TRD Tacoma
    Awesome appreciate y’all
  19. Apr 25, 2023 at 12:56 PM
    Rickeycv
    Rickeycv New Member
    What was the issue? Bad transmission oil cooler system?
  20. Apr 25, 2023 at 1:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Hasn't been seen sinc:
    Texastaco2010 was last seen: Oct 11, 2022
    TnShooter likes this.
