Oil pump seal / o ring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jobu, May 26, 2021.
  1. May 26, 2021 at 9:54 PM
    Jobu
    Jobu [OP] New Member
    2014 tacoma 4x4. I'm looking for a part number for the seal that goes between the timing chain cover and the upper oil pan (oil pickup)
  2. May 26, 2021 at 10:23 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    2.7L or 4.0L?
  3. May 27, 2021 at 12:14 AM
    Jobu
    It is a 4.0
  4. May 27, 2021 at 3:20 AM
    Taco'09
    Taco'09 Well-Known Member
    OP, the description is a little confusing but I can narrow it down to one of four:
    There is an O ring at the top of the oil strainer pickup tube it is 96722-24030.
    There is one from the oil pump cover to the oil pump outlet pipe (lower end of pipe) it is 15119-31050.
    There is also one from the top of the oil pump outlet pipe (upper end of pipe) to the timing cover it is 15188-31050.
    And finally there is one called Gasket, Oil Pump that goes between the timing cover and the cylinder head it is 15193-31010.
    BassAckwards likes this.
  5. May 27, 2021 at 10:22 AM
    Jobu
    The part number I was looking for was for the strainer pickup. The local dealer could not find the part. Appologies for the vagueness. This was the my first time posting a question on this forum, and didn't know if I was wasting my time, or not. Thank you for your prompt reply.
    b_r_o likes this.
  6. May 27, 2021 at 8:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t know why?
    But there seems to be 2 different part # for it.
    1 for the 05-09 trucks.
    Then a different one for the 10-15 trucks?
    2EE228F5-C9AD-4ABA-B193-206C29C32529.jpg 5403AB11-6963-4ADC-9615-80D63220FBA7.jpg BEAD901D-14EB-4A7F-9533-FF59683F60D7.jpg 54B75292-5419-44DF-9CB5-00204344A45F.jpg 48D01AE8-CE6B-4DA0-9777-37F8D69094D1.jpg 9D071164-04DB-4CB4-A913-FEC431911502.jpg 56584487-9E0F-40F7-9393-F68A4BBC93D0.jpg
  7. May 27, 2021 at 11:50 PM
    Taco'09
    @TnShooter
    I am not a Toy parts expert but will give a couple of my observations as to why there may be the part number differences. There may also be import issues and inventory control matters.
    The entire oil pickup assembly no longer looks like those drawings at all with the original being an inverted mushroom-looking metal part. But it has been revised to a roughly rectangular-shaped part constructed of black plastic and looks nothing like the first, complete with different openings. I've seen the thing.
    Also, for several years Toy seems to have imported some engine parts from Japan for later assembly here and elsewhere(?). Such parts are listed with different part numbers in the dealer's PNC (part number catalog) with the following designations:
    (J) = Japan Sourced Part
    (L) = Local Sourced Part
    Here is an example of this, the part being the Oil Pump Rotor Set for the 2007 engine as it would appear in the dealer catalog:
    15102 ROTOR SET, OIL PUMP
    15103-0P010 (L)
    15103-31050 (J)
    When a certain a part is desired and a choice like this appears, how would one know to choose an (L) or (J)? >>>> :notsure:
    Fortunately I have had occasion to previously test this and when I ordered something that turned out to be a different source, it was automatically revised to the correct part number by computer on the order.
    TnShooter likes this.
