Oil pump replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by protaz, Jan 4, 2025.
  1. Jan 4, 2025 at 10:57 AM
    protaz
    protaz [OP] Member
    David
    vancouver CANADA
    17 tacoma 3 inch toytec lift with 33smuders
    aftermarket head lights aftermarket tail lights billet grille 3 inch suspension lift MTX speakers
    Hey Guys , has anyone replaced there oil pump and have a procedure for this work ? I am experiencing a low oil pressure light on start up that goes away within a few seconds but a recent engine noise that also goes away after 30 seconds is making me feel like the oil pump is on its way out. any insight to this is appreciated
  2. Jan 4, 2025 at 10:59 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    What engine? How many miles? What kind of oil filters are you using?
    Chew and t0p_d0g like this.
  3. Jan 4, 2025 at 11:05 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The pump is a part of the timing chain cover, directly driven by the crankshaft.
    Need either pull the engine or remove front suspension, diff to get the cover off
    Chew and protaz[QUOTED][OP] like this.
  4. Jan 4, 2025 at 11:37 AM
    protaz
    protaz [OP] Member
    David
    vancouver CANADA
    3.5 V6 95,000 miles . I believe it’s a oem filter
  5. Jan 4, 2025 at 11:38 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Feels more likely that it would be the pressure sender failing.
    Chew and BillF1564 like this.
  6. Jan 4, 2025 at 11:43 AM
    protaz
    protaz [OP] Member
    David
    vancouver CANADA
    Possibly! I guess I need to check oil pressure at idle and see the readings. the light is only on for 1 second and disappears
