Oil pressure light followed by Engine shut off on long trip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zbumm, Mar 10, 2018.
  1. Mar 10, 2018 at 8:31 PM
    zbumm
    zbumm [OP] New Member
    Zack
    2009 Tacoma TRD Sport
    2inch leveling kit, new leaf springs and hardware
    Forgive me for the long post but I have a situation.
    So yesterday I took my Tacoma (2009 TRD Sport 135k Miles) on a long trip to visit a friend in another state about a 9 hour drive. I got roughly 2.5 hours north of Las Vegas and got a low oil pressure light. Drove another 20 minutes (babied it) slowed to about 25mph going through a small town (Lund NV) and the truck shut off. I let it sit about 15minutes checked oil level and it was good, no overheating no engine knock. It fired right back up drove about another 30 minutes no issues and light came back on but I pulled over immediately this time and shut truck off.
    I did an oil change about a week ago, I’ve owned truck for about 2 months and it was sitting about 6 months when I bought it so there was some sludge in oil. Monday I have to drive back home I’m trying to take care of any issues beforehand if anyone has had this issue before or can provide any insight I would be very greatful
  2. Mar 10, 2018 at 9:00 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose it's s bad sensor....six months would sludge that bad I would think with modern oils.
  3. Mar 10, 2018 at 9:37 PM
    zbumm
    Zack
    That’s what I’m hoping
  4. Mar 10, 2018 at 9:48 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Your oil pump could be toast. Might be worth dropping the oil pan and having a look. This would also give you a good excuse to clean the sludge out. I'm not sure if you have to move anything to get to the pan or if it will just slip out I'm sure somebody will chime in about that.
    You could also check the resistance across the sensor. Im taking a guess at this but max resistance could be @ 0.5 ohm
  5. Mar 10, 2018 at 10:02 PM
    zbumm
    Zack
    Unfortunately I didn’t bring any real diag tools with i May just replace sensor to be safe and change oil, I put some seafoam in it yesterday to help break up any sludge. Drove it for about 45min today, to a couple fishing spots, and had no issues.
  6. Mar 11, 2018 at 3:23 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    First rule of thumb is: If you get an oil pressure light Do Not keep driving the truck. Turn off the engine and stop. If you keep driving with low oil pressure you will seize the engine.
    On a brighter note it didn't lock up after you drove for 20 minutes with a low oil pressure light. As stated you need to determine if your oil pump is going out or being clogged at the oil pickup by sludge. Sitting for 6 months is not going to cause sludge. Not doing proper oil changes and burning the oil causes sludge.
    I would be afraid to depend on that truck for a nine hour drive.
    Markcal, 2WD, outlawtacoma and 3 others like this.
  7. Mar 11, 2018 at 6:53 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Sounds like the original owner didn’t take care of it.
    kidthatsirish likes this.
  8. Mar 11, 2018 at 8:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check the oil level with engine off.
    Start the engine and check the level while it is running.
    If the level is lower, your oil pump is circulating.
  9. Mar 11, 2018 at 9:06 AM
    zbumm
    Zack
    Had I not been in the middle of nowhere with no cellphone signal I would have pulled over immediately the first time but I was worried if I did the truck wouldn’t start again
  10. Mar 11, 2018 at 10:49 AM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    If there is a lot of sludge the pick up screen could be blocked as well.
    07 sport 4x4 likes this.
  11. Mar 11, 2018 at 11:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had this happen to me on a used engine. Only two tiny clear spots were allowing oil passage. The size of a pinky finger tip.
    A high rpm rev-match down shift and I let the rod knock choir out.
    dirtdigginjoe likes this.
  12. Mar 11, 2018 at 4:20 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    As a easy, cheap little bit of insurance, I would buy a filter and a quart of oil. Change the filter and top off the oil, just to eliminate that piece of the puzzle.
    PzTank and kidthatsirish like this.
  13. Mar 12, 2018 at 4:07 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    This gets my vote as well. Pull the lower oil pan and see what it looks like. If the oil pickup tube is getting clogged and you don't take care of it you'll soon be looking for a new engine.
  14. Mar 12, 2018 at 5:49 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Hey @zbumm , you gotta let us know if you made it back and how the truck did (not that I’m advocating for driving with an oil light on)... Good luck :cheers:
  15. Mar 12, 2018 at 6:09 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    6 months of sitting can cause oil to sludge? I would say that original oil that came with the truck probably was in their longer than. 6 months. Could be it was literally the original oil that came with the truck back in 2009.
  16. Mar 12, 2018 at 8:28 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Ok, I thought of this ....
    "If" the oil drains from the valve area under their cover is partially blocked with crud or whatever ..... The oil will be slow to return to the oil pan/sump. At an Idol or low RPM it may just increase the time that the oil needs to return to the pan. At High RPM the oil pump may pump faster than the oil is returning. If the oil builds up in the valve covers it may hold enough oil to let the oil drop in the pan until the pump starts to suck air and the oil light comes on.... Running at high RPM in this scenario is not good for the engine but my still supply enough oil to keep the engine from seizing.
    The next time this happens - Immediately pull over and check the oil dip stick. If it's below normal or none - the oil my be in the valve cover(s).
    JMO
    SteveC
    Hawco636 and Jimmyh like this.
  17. Mar 12, 2018 at 8:31 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  18. Mar 12, 2018 at 10:52 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Your engine will be toast if the oil light came one that long unless the sending unit is bad.
  19. Mar 12, 2018 at 10:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup.
  20. Mar 12, 2018 at 11:01 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    damn..subscribed for a good outcome i hope.
