Oil on coilpack and spark plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghitt1117, Jan 14, 2020.
  1. Jan 14, 2020 at 10:23 AM
    Ghitt1117
    Ghitt1117 [OP] Well-Known Member
    Garrett
    Enterprise, al
    2015 TRD SPORT
    Are the any good write ups on changing the valve cover gasket on a 2015 4.0 ? I found oil on cylinder 3 coilpack and plug and from what I have read so far seems like the tube seal has most likely worn out. I'm I going in the right direction in changing the valve cover gasket ? received_2283519321734949.jpg received_1136136279925161.jpg
  2. Jan 14, 2020 at 10:57 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
  3. Jan 14, 2020 at 2:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes the valve cover gasket set should take care of the coil tube seal leak.
  4. Jan 15, 2020 at 5:28 AM
    SJBlack
    SJBlack Well-Known Member
    How many miles are on the truck ? is it a 2015 or a 2004 like in your signature? Thanks
  5. Jan 15, 2020 at 5:32 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    That looks like a classic valve cover leak to me
