Oil light comes up when braking or stopping
Discussion in '1st Gen. Tacomas (1995-2004)' started by MammothTacoma2002, Dec 28, 2020.
  1. Dec 28, 2020 at 12:03 AM
    MammothTacoma2002
    MammothTacoma2002 [OP] Member
    Aldo
    2002 Tacoma Prerunner 2.7L doublecab
    None
    Hello, I recently bought a 2002 2.7 prerunner with 250,000 miles. The first couple of days the truck drove good and smooth, but then the oil light started popping up when I came to stop or idled. The previous owner said it could be a oil sender switch, while a local mechanic shop said I might need a new motor. Does anyone know what this might be? I spent most of my money buying the truck so I’m scared of the idea of needing a new motor.
  2. Dec 28, 2020 at 12:55 AM
    Tarl_Cabot
    Tarl_Cabot Well-Known Member
    SC
    Gen 1 2000 2x4 2.7 A/C SR5 Gen 3 2021 4x4 3.5 A/C SR
    is it low on oil ? buy an 18 yr old vehicle with 250k miles and NOT expect to have to do some maintenance or repairs ??? pull the codes, if any...don't trust someone guessing it's nothing but a sensor, nor a garage that just says it needs a new motor. Last time i checked...motor runs off of electricity, engines run off of fuel....(typically gasoline) 2.7 is an engine, not a motor
    DocD and SR-71A like this.
  3. Dec 28, 2020 at 12:57 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    light comes on stopping or idling? check the oil level. its probably not even on the stick.. then figure out why youre losing oil.
    other possible cause is failing oil pump not putting out enough pressure while at idle. Have it looked at ASAP. if the motors saveable now, driving around with oil pressure issues will make it much more expensive to fix when it does completely fail
    Black DOG Lila likes this.
  4. Dec 28, 2020 at 1:07 AM
    MammothTacoma2002
    Aldo
    None
    The oil is good and all, I use 10w-30 fully synthetic
  5. Dec 28, 2020 at 1:08 AM
    Empty_Lord
    Dan
    Then I would have the oil pressure checked. Or replace the sender and see if it fixes it.
  6. Dec 28, 2020 at 1:23 AM
    MammothTacoma2002
    Aldo
    None
    Definitely I’m going to have it checked out tomorrow by the previous owners mechanic so we can get it fixed. Will it be fine to drive about 55 miles on the freeway?
  7. Dec 28, 2020 at 1:27 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    wrightme43 and ThatBoyBill like this.
  8. Dec 28, 2020 at 4:53 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I would have put a mechanical oil pressure gauge on the first time the oil light came on.
    Just for peace of mind !!
    Your truck if it quits your repair bill
  9. Dec 28, 2020 at 5:19 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Engines get sludged up over time.
    Degrese engine, pull valve cover to check how gunked up the oil drain journals are. Takes time for oil to move from top end to pan in clean engine.
    Takes longer in sludged engine.
    I had a 22R that gunked up at 289,000 mi. Hand cleaned what I could and flushed with Kerosene. Ran another 100,000 mi. W/O oil light coming on.
    Crank seized at 399,891 mi.
    Turns out Quaker State had high parrafin content.
  10. Dec 28, 2020 at 9:19 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    https://www.merriam-webster.com/dictionary/motor
  11. Dec 28, 2020 at 10:30 AM
    Black DOG Lila
    Virginia
    I'm guessing Tesla engines are a thing now.
    Maybe not
    Who cares?
  12. Dec 30, 2020 at 11:15 AM
    MammothTacoma2002
    Aldo
    None
    My motor blew out y’all
  13. Dec 30, 2020 at 5:25 PM
    Black DOG Lila
    Virginia
    Sorry for your loss
    MammothTacoma2002[OP] likes this.
  14. Dec 30, 2020 at 5:43 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Ya, purchasing an old vehicle with a quarter million miles on it is risky business. Sorry for your loss, maybe you can find a lower millage engine at a salvage yard. Good Luck
  15. Dec 30, 2020 at 6:04 PM
    ThatBoyBill
    ThatBoyBill Well-Known Member
    Robert
    2017 Super White TRD Off Road 4*4
    This helps a lot
  16. Dec 30, 2020 at 6:12 PM
    Black DOG Lila
    Virginia
    Slow night in the 3rd gen forum?
  17. Dec 31, 2020 at 1:28 AM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
  18. Dec 31, 2020 at 11:52 AM
    MammothTacoma2002
    Aldo
    None
    It’s a real pain in the ass to deal with but shit happens, gonna get up and running asap. I’ll post here again soon. Thank you guys for your help :)
  19. Dec 31, 2020 at 12:02 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Sounds like previous owner knew something was wrong with it. Drag city.
    Good luck and keep us posted with what you are going to do.
    DocD likes this.
