Oil leak from oil filter housing(?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by slymedusa, Feb 28, 2024.
  1. Feb 28, 2024 at 5:49 PM
    slymedusa
    slymedusa [OP] Complete Newbie
    Jorge
    Miami, FL
    2002 Silver Tacoma Prerunner
    Finally found the source of a minor leak I've been chasing. My oil level never drops significantly between changes, but I noticed the skid plate and the area immediately above were always gunked up after 5,000 miles.
    The attached photo shows where the leak is coming from. May be hard to tell because I had just wiped it to confirm that it was coming from there. Looks like where the oil filter housing meets the engine block. Previous owner had the oil filter housing replaced, supposedly it had cracked. What are the chances that they: 1. didn't replace the two gaskets inside, or 2. didn't torque it up enough?
    Any advice on taking care of this is appreciated. From videos I've seen, seems like it's not that difficult of a job, but it is kinda tough to get to it.
  2. Feb 28, 2024 at 6:02 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Easy fix, at least on a 2.7l. Couple of o rings and you will be fine.
    slymedusa[OP] likes this.
  3. Feb 28, 2024 at 6:11 PM
    slymedusa
    Jorge
    Miami, FL
    Sweet, I hope so. I just spent the last few days busting my ass changing out steering rack bushings and UBJs.
    koditten and THatt[QUOTED] like this.
  4. Feb 28, 2024 at 6:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Those oil cooler seals leak all the time on lots of different cars. Don't overthink it
  5. Feb 29, 2024 at 4:17 AM
    slymedusa
    Jorge
    Miami, FL
    Can someone confirm whether I need an o-ring and gasket or just the gasket? When I check partsouq it says I need both, but the dealer’s website says I need just the gasket. Put my VIN in both.
  6. Feb 29, 2024 at 4:20 AM
    TuRDLYFE
    TuRDLYFE Well-Known Member
    An over-taxed town, county, and state
    2020 AG TRD Pro 6MT
    As far as consumables go, I would snag them both without overthinking it.
  7. Feb 29, 2024 at 5:53 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Nice and easy here, this is what I bought for my 2.7. Way easier if you pop the passenger tire off takes longer to jack the truck up then to replace the gaskets. Get yourself a small pick for the o-ring.
    https://www.lceperformance.com/3RZ-OEM-Oil-Filter-Housing-Seal-Kit-p/1019000.htm
    slymedusa[QUOTED][OP] likes this.
  8. Feb 29, 2024 at 6:04 AM
    slymedusa
    Jorge
    Miami, FL
    Thanks brother, ended up ordering both from the dealer since I’m passing it on the way home from work today anyway. Wanted it in hand asap so I can get it done over the weekend.
