Oil Filter Relocation Kit for 2nd gen 2.7L
Discussion in '4 Cylinder' started by Blais03, Mar 20, 2018.
  1. Mar 20, 2018 at 10:42 AM
    Blais03
    Blais03 [OP] Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
  2. Mar 20, 2018 at 3:17 PM
    Blais03
    Nick
    Easthampton MA
    Anyone???
  3. Mar 21, 2018 at 6:19 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    ive read that these remote filter relocation kits have tendencies to blow off the fittings sometimes which would be an utter mess and disaster, i would look into reading reviews and research thoroughly before using these, although they do sound like a good idea for the 2.7 engine. im starting to get used to mine since ive changed the oil since changing the oil more times.
    Robnik likes this.
  4. Mar 21, 2018 at 6:21 AM
    Blais03
    Nick
    Easthampton MA
    I do the bag trick right now and it works alright but I saw this and thought it would totally take the mess away. But Idk if i like the idea of it lol
    Robnik likes this.
  5. Mar 21, 2018 at 6:25 AM
    BillsSR5
    bill
    2014 SR5
    I looked at these kits too for the same reason but read about the lines blowing off under pressure and that turned me off. I just did my oil 2 days ago I just barely crack the filter till the oil dribbles out of it, and then remove when it has emptied, although I did get some splash on the cross member, its just part of the 2.7 OCI deal, im getting used to it and it don't bother me as much as it did when I first got the truck.
    DGXR, Robnik and Blais03[QUOTED][OP] like this.
  6. Mar 21, 2018 at 7:59 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    I agree Nick, they are messy to get off. I would not use that kit though. Too many fittings that can leak over time or blow out as Bill said. You could always puncture a hole in it with an ice pick & let it drain for awhile. ;)
    DGXR, BillsSR5 and Blais03[OP] like this.
  7. Mar 21, 2018 at 8:07 AM
    Blais03
    Nick
    Easthampton MA
    im not complaining, im just saying it could be easier and less messy. But I just use a thick plastic bag and do it dog poop style for now... :rofl:
    Tigerian and BillsSR5[QUOTED] like this.
  8. Mar 22, 2018 at 10:46 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'm not a fan of messing with the bulletproof factory oil system. The 2.7L oil filter is NOT hard to change, if you think it is you need to try changing oil on some other cars because some are a real bitch. Cut bottom off capped gallon milk jug, break the filter loose, put jug over the filter, spin the filter off with your free hand and all the mess falls into the jug. Wipe the surface off and install new filter and done takes 3 minutes no mess and plenty of room to work.
    dawgn86 and DGXR like this.
  9. Apr 14, 2018 at 6:25 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  10. Apr 14, 2018 at 6:49 PM
    Blais03
    Nick
    Easthampton MA
    I have seen that. I like the canister type filters better. I’m not even that interested in the relocation kit but it’s a neat idea and was more just wondering if other people have done it.
    05Taco4x4[QUOTED] likes this.
