Oil Filter Magnets
Discussion in 'Technical Chat' started by Cavender76, Aug 11, 2008.
  1. Aug 11, 2008 at 1:16 PM
    Cavender76
    Cavender76 [OP] Well-Known Member
    Clint Cavender
    Mobile, Alabama
    2020 SR5
    Removed Window Sticker
    Just left a local offroad shop and the mechanic told me the cheapest mod to save your engine is placing a coaster shaped magnet on top of you oil filter. Has anyone heard this?:rolleyes:
  2. Aug 11, 2008 at 1:21 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
  3. Aug 11, 2008 at 1:22 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    It couldn't imagine it making that much of a difference, considering there is either a magnet sitting in the bottom of your oil pan or it is intergrated in the oil drain plug.
  4. Aug 11, 2008 at 1:25 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    How does a magnet make your engine "Burn fuel more efficiently" ??? (as stated in the ad)
  5. Aug 11, 2008 at 1:33 PM
    Justin626
    Palmer, Alaska
    Everybody's trying to make a buck.:fenforcer:
  6. Aug 11, 2008 at 1:38 PM
    05PreRunner
    <-(714)-> SO-CAL
    i dont know but, that sounds like b/s to me.....
    the only thing i CAN see it doing is helping out by slightly cleaning the oil of contaminants.....
  7. Aug 11, 2008 at 7:53 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It's the same idea as having a magnetic drain plug. It'll collect the metallic particles out of your oil. Neat idea putting it on the oil filter...but it won't give you all the benefits they're claiming.
    Besides that.... Personally - the drain plug idea is much better. When you change your oil, you can SEE how much metallic particles are in the oil.
    If your engine is puking metallic particles on a regular basis (after full break-in), then you've got some problems.
  8. Aug 12, 2008 at 3:27 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    Interesting . . . I just searched filtermag.com and the website didn't even find a magnet for an 08.
  9. Aug 12, 2008 at 6:25 PM
    MPhipps
    MPhipps Member
    Do the Tacos have a magnetic drain plug?
    I just acquired (the bank owns:)) a '09 and was wondering about that but didn't want to do an oil change just to find out.
  10. Aug 12, 2008 at 6:30 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    If oil filter magnets are such a great idea, wonder how come none of the filter manufacturers haven't built them into their product? Can't cost too much for them to get some magnets, and it would make a great marketing gimmick.
  11. Aug 12, 2008 at 6:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes they do.
  12. Aug 12, 2008 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its because, as mentioned above, the magnetic drain plug works best.
  13. Aug 12, 2008 at 6:57 PM
    HerNameIsLucy
    RIP Lucy.
    Long time back I was on a now defunct Corolla forum. Peeps there were swearing by a mod that involved running welding cable between the front and rear of the engine block, then to the battery. IIRC they called it the "ground mod". They were swearing it did everything from butter their toast in the morning to raising their gas mileage 300 percent.
    Quieted them right down when I said Toyota spends millions of dollars figuring out ways to make their engines more fuel efficient, why would they not put 5 bucks worth of cable under the hood if they could raise the price of the car 500 bucks for being able to claim incredible gas mileage.
    Nobody had an answer...
  14. Aug 12, 2008 at 11:49 PM
    Justin626
    Palmer, Alaska
    I'm sure some of them may be, but mine is not. Just changed the oil 3 days ago and I tried to hang it off the bottom of the oil pan while it was draining. Decided to go for synthetic now, of course.:)
  15. Aug 13, 2008 at 1:57 PM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    After the first oil change, I'd be concerned to find any filings, etc, stuck on my drain plug, but I'd sure prefer to see it there than hidden inside a filter.
    Now, if I did think a magnetic filter made sense I'd buy a couple rare earth magnets and stick them to the filter. This would magnetize the filter good enough. And it would cost maybe fifty cents.
  16. Aug 13, 2008 at 2:12 PM
    HerNameIsLucy
    RIP Lucy.
    Get yourself a dead hard drive and yank the magnets out of it. Those little things are so strong if you stick it to the front of your 'fridge you have to slide it to the side to get it off.
    Freebies!
  17. Aug 13, 2008 at 5:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I stand corrected. Are you sure yours isnt magnetic? :confused:
  18. Aug 19, 2008 at 8:14 AM
    Justin626
    Palmer, Alaska
    Yep, pretty sure. :poking:
  19. Aug 29, 2008 at 12:54 PM
    MattF
    MattF Member
    England
    Surf 2.4TD
    One other possible, (not likely, but possible), pitfall of the filter magnets is what could happen if the band was removed from the filter for any reason, whether by accident or otherwise, and there were metal particles in the filter?
  20. Aug 29, 2008 at 12:58 PM
    05PreRunner
    <-(714)-> SO-CAL
    Wow, Good Point!!
    and since some filters aren't too easy to remove, you would have to move around the band or actually remove it.:eek: to get a good grip on the filter.
