Oil filter housing replacement....
Discussion in '3rd Gen. Tacomas (2016-2023)' started by H6G, Nov 5, 2018.
  1. Nov 5, 2018 at 2:40 PM
    H6G
    H6G [OP] Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    Since lots of owners have replaced their oil filter housing with an aluminum one.... Has anyone ever had an issue with a dealership, regarding warranty? Even though, the replacement part is made by Toyota.... any problems with first two oil changes that Toyota includes?
  2. Nov 5, 2018 at 3:23 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I've seen a post some time ago where the owner went to dealer to change the oil with a metal housing and came back with the plastic one.
    Taco_Coma, H6G[OP] and 2016Tacoman like this.
  3. Nov 5, 2018 at 3:48 PM
    H6G
    Far from home...
    So a Toyota Tech. actually replaced it with an OEM plastic one? That’s interesting....
  4. Nov 5, 2018 at 4:14 PM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Buy the Baxter Performance spin on adapter. Best mod I ever did.
    H6G[OP] likes this.
  5. Nov 5, 2018 at 4:22 PM
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    which adapter did you get?
  6. Nov 5, 2018 at 4:24 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    @Xena1 What spin on filter do you use after the adapter is installed?
  7. Nov 5, 2018 at 5:48 PM
    H6G
    Far from home...
    I believe he’s referring to
    TS-101-BK Cartridge To Spin-On Adapter
    that require Toyota filter #04152-YZZA1.
    DTaco18[QUOTED] likes this.
  8. Nov 5, 2018 at 5:56 PM
    DTaco18
    Yes, but the website doesn't show what aftermarket spin-on filter to use after you install the adapter. I'm assuming they recommend a spin-on that would be equivalent to the 04152-YZZA1 cartridge filter.
  9. Nov 5, 2018 at 5:57 PM
    WARPED5
    WARPED5 Well-Known Member
    Ted
    NW IN
    2017 Blue TRD OR
    Will the use of a spin-on adapter have clearance issues with a skid plate?
  10. Nov 5, 2018 at 6:01 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    It may have clearance issues since it roughly adds 1.5” plus the length of the filter.
  11. Nov 6, 2018 at 4:11 AM
    Xena1
    Ron
    Actually the WIX 51348 works better. It is a bit shorter and gives more room between the skid plate.
  12. Nov 6, 2018 at 4:12 AM
    Xena1
    Ron
    No there is plenty of room especially with the WIX filter.
    kgilly[QUOTED] likes this.
  13. Nov 6, 2018 at 5:50 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I've done about 4 oil changes in this truck. I don't really see the need to change the filter housing to metal. The original is fine as is.
    I can see the desire to change to a spin on filter. It's a little more convenient. That being said, the cartridge filter creates less wasted resources, so I'll stick with that.
    tonered and shakerhood like this.
  14. Nov 6, 2018 at 7:22 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I really didn't see a need to change to the metal housing either, I did however buy another plastic one. I swap them each change so the extra is already clean, dry, and ready to install.
  15. Nov 6, 2018 at 7:25 AM
    smiles2
    smiles2 Well-Known Member
    2017 Blue Tacoma TRD Offroad
    The reason I changed mine to metal was because I let the dealer do an oil change and they tightened it so much that when I did the next one I broke the tabs off trying to remove it.
  16. Nov 6, 2018 at 7:26 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    shakerhood[QUOTED] likes this.
  17. Nov 6, 2018 at 7:30 AM
    smiles2
    Changing that part out legally shouldn't create an issue with the warranty unless Toyota can prove that it was the cause of the damage to your vehicle.
