Oil filter drain plug question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_Trev, Feb 1, 2020.
  1. Feb 1, 2020 at 8:33 AM
    Taco_Trev
    Taco_Trev [OP] Active Member
    2019 Tacoma TRD
    Bone stock
    Is it normal to leak oil out the drain hole with the cap and oring off? I would have thought the little plug was just to keep debris out or if the internal plug portion failed. When I take the cap off mine leaks oil. I tried reseating it but still leaks. Once the cap and oring are on, nothing leaks out, but I wasn't expecting that.
  2. Feb 1, 2020 at 8:40 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    It probably has a cap and an o-ring for a reason
    Rockefelluh, Skydvrr and LivinOnEdge like this.
  3. Feb 1, 2020 at 8:44 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
  4. Feb 1, 2020 at 8:45 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Yes, when you remove the bottom cap from the filter housing oil will drip out. Totally normal.
    Big tall dave likes this.
  5. Feb 1, 2020 at 8:50 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Um...
  6. Feb 1, 2020 at 8:54 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
    There is a drain hole on the bottom of the filter housing, you take the cap off and push the valve I, this allows you drain the housing before removing it. When I take the cap off oil drain out, not a lot but just a slow leak. I wouldn't have expected it to do that.
    CaptainBart45 likes this.
  7. Feb 1, 2020 at 8:55 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
    Good to know. I've had previous vehicles with similar designs but they don't leak unless you depress the valve. Just making sure mine isn't defective.
  8. Feb 1, 2020 at 8:56 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
    Yeah, I just thought it might be more for a precaution or in case the valve failed.
  9. Feb 1, 2020 at 8:56 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That ONLY drains ths filter housing. Not much in there.
  10. Feb 1, 2020 at 8:57 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    People actually use those filter drains? Cant you just spin off the cap and deal with the mess?
    Kev250R and 2000prerunner23 like this.
  11. Feb 1, 2020 at 9:07 AM
    Plain Jane Taco
    USA
    Yes. Most "professional" oil changes are done that way
  12. Feb 1, 2020 at 9:10 AM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Just Drain it all into your Morning Coffee and you'll soon discover you have no need for anything else.
    wiredweasel and MadKatt like this.
  13. Feb 1, 2020 at 9:14 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
    My new filter even came with a little plastic piece you can use to drain it with a tube. Next time I'll just pull the housing without draining prior.
  14. Feb 1, 2020 at 9:15 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
    Pinch of salt takes out the bitterness.
    Ol'gray mare likes this.
  15. Feb 1, 2020 at 9:15 AM
    AustinMada
    AustinMada Thinking About Tacos
    WA.
    19 DCSB OR
    Normal
  16. Feb 1, 2020 at 9:27 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    IMHO it makes too much of a mess if you dont drain some out of the canister first.
    Anton338, over60, b_r_o and 2 others like this.
  17. Feb 1, 2020 at 9:28 AM
    Plain Jane Taco
    USA
    Yes....all filters come with 2 new o-rings and a drain adaptor. Other than being messier...nothing wrong with skipping draining the housing 1st
    Taco_Trev[QUOTED][OP] likes this.
  18. Feb 1, 2020 at 9:41 AM
    AustinMada
    WA.
    19 DCSB OR
  19. Feb 1, 2020 at 10:59 AM
    Taco_Trev
    2019 Tacoma TRD
    Bone stock
  20. Feb 1, 2020 at 12:32 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    This works as well. Leftover tubing in the garage.
    Big tall dave and CaptainBart45 like this.
