Oil filter ? Bigger is better ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Armed in Utah, May 23, 2019.
  1. May 23, 2019 at 10:04 AM
    Armed in Utah
    Armed in Utah [OP] Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Wix 51515XP vs the OEM Toyota filter..
    using 5w30 full synthetic every 6-6500 miles
    Bought two of these monster Wix for my next two Taco oil changes
    Wix made in USA......Toyota made in Thailand......IF that matters
    Just thought I'd post a comparison pic of the two in size.....
    yes its what on the inside that counts....but both filter brands highly regarded
    Rick's 2012 likes this.
  2. May 23, 2019 at 10:22 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Don't think it really matters tbh. Heck I change my oil every 12,500 miles with the cheapest I can find so whatever. I do use a long life oil filter.
    13txtaco likes this.
  3. May 23, 2019 at 7:49 PM
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    Only way to really find out is to cut them open and measure filter media surface area
  4. May 23, 2019 at 11:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @Armed in Utah I use same size filter in Purolator Boss, PBL30001. I put in 6.5 qts of full synthetic oil. Had been using Mobil1 but after watching some Project Farm oil comparisons, I'm switching to Amazon's brand. The Boss has a very thick shell and is rated to 15K miles. Only $12 on amazon, about the cost of a six pack of craft beer; my truck is worth it.
  5. May 23, 2019 at 11:24 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Larger filters add oil capacity
  6. May 24, 2019 at 12:29 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    That yzzd3 Toyota filter IS the oversized filter....
    A spec’d Fram ultra 3614 or Mobil 1 201a is the stock size (yzzd1).
    Those filters are warrantied to 15000 miles or more.
    The larger Fram 3600 or Mobil 1 209a are similar in size to the “oversized” yzzd3.
    What else could you possibly need?
  7. May 24, 2019 at 12:55 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    If you want really clean oil , run a remote oil filter set up with dual filter pad set up with (2) 1qt filters . To make sure oil flows freely to and from the motor run #10AN or #12AN lines
    PzTank, StillNoPickles and FastEddy59 like this.
  8. May 26, 2019 at 10:42 AM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    What am I missing? They appear to have different diameters so how will they seat and seal?
  9. May 26, 2019 at 11:20 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    That is for the Land Cruiser, not the Taco.
    I doubt that filter would even fit where the oil filter goes.
    FWIW, the Toyota filter is rated very high, no need to go aftermarket shopping.
    {The six cylinder land cruiser engine}
    Sig45 likes this.
  10. May 26, 2019 at 12:32 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Will it fit on the 4.0 ,looks larger than the oil filter housing can handle.
  11. May 26, 2019 at 1:09 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Yes, it fits. Been using the equivalent size Purolators for 2-3 years. The gasket size is larger but fits on the base plate. You’ll find oldum threads going back to 2009 of using this size filter.
  12. May 26, 2019 at 1:13 PM
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    What would the added benefit be of this with normal intervals? I’ve used nothing but Toyota filters for half a million miles between my 1st, 2nd, and 3rd gen trucks. Never had any issues whatsoever. These trucks are pretty easy on oil to begin with.
  13. May 26, 2019 at 1:17 PM
    TacomaSport86
    Zero benefit imo
  14. May 26, 2019 at 1:19 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Added oil capacity. I run the Wix and 6qts of oil over the stock 5.5qts.
    Key-Rei and Norton like this.
  15. May 26, 2019 at 2:03 PM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    I use the Baldwin B2-HPG on my 2tr-fe. Excellent filtration and flow specs, holds an even 6 qts with this filter.
  16. May 26, 2019 at 3:10 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Added benefit is increased oil capacity and oil filtration area, for a nominal expense as oppose to adding a remote filtration system. More oil in system means cooler engine temp as there is more oil to absorb it. Will one notice the difference; probably not; definitely not in the short run. There is no disadvantage, that I can see, other than an increase in price of about $5-10 per oil change - worth the trade-off, imo.
    Norton likes this.
  17. May 26, 2019 at 3:21 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    It's kinda like an oil catch can mod. Will it help in anyway whatsoever? Eh? Maybe? But I did it. It's a cheap and any easy way to possibly help my engine out.
    Norton and Tacorific like this.
  18. May 26, 2019 at 3:32 PM
    StillNoPickles
    2020 RAV4 Hybrid LE
    However with normal intervals, you’re really getting no noticeable benefit, especially when oil analysis tests can show that much longer intervals are easily achievable with normal OEM filters. If you worked your engine to the point where extra oil would prevent damage, something else on your truck would likely be damaged already anyways. Just figure why try and fix something that isn’t broken. Most of you likely have 1GR-FE engines by the looks of it, one of the most bulletproof engines out there, and is extremely easy on oil. Adding more with no interval change won’t do much other than waste $$$
    Accipiter13 and TacomaSport86 like this.
  19. May 26, 2019 at 3:37 PM
    Chuy
    Lakeside, CA
    Silver Taco
    The don't-fix-it-if-it-aint broken philosophy contradicts the preventive maintenance philosophy.
  20. May 26, 2019 at 3:44 PM
    lynlan1819
    Tacoma
    Lifted
    Not when it comes to using Factory spec parts.
