Oil Drain Plug 2 Crush Washers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by G65P9810, Dec 31, 2022.
  1. Dec 31, 2022 at 10:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    No magic here. Check the drain plug as-is for leaks around the gasket. If you don't see leaks, leave it. If you see leaks, drain the oil into a clean container and replace the gasket. I'd say odds are 70% you won't have a leak.
    In the future use Dorman 12mm / 1/2" copper drain plug gaskets P/N 65271 (2-pack). These don't stick to the oil pan. It's available at most auto parts stores.
    YE2KA and fathomblue like this.
  2. Dec 31, 2022 at 10:37 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Have a buddy help you here.
    Place oil pan under the truck.
    Have clean rags on the ready.
    Have new washer on the ready.
    Loosen drain plug, but don't loosen completely.
    With a plastic scraper, pop the old washer loose from the pan so it drops down against the drain plug.
    Have your buddy ready to receive the drain plug w/ old washer.
    Loosen drain plug completely with your dominant hand, and right as you pull it away from the hole plug the hole with a finger from your other hand.
    Hand off the drain plug to your buddy to clean off and swap washers.
    Buddy hands back the plug with new washer installed.
    You lineup the drain plug to the side of your finger currently plugging the drain, and quickly swap.
    Screw in the plug in, and torque to spec.
    Check oil level amd adjust as needed.
    Done!
    PzTank and Greene368 like this.
  3. Dec 31, 2022 at 10:42 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    Shop vac hose on the fill port. Done it several times over the years on various cars to replace leaking and doubled up drain plug gaskets.
    PzTank, 3JOH22A and INSAYN like this.
  4. Jan 1, 2023 at 5:38 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    regardless of the risk for a leak being low, i believe in doing a job right especially one as important as an oil change and installing the drain plug.
    no way i could live with that. i'd fix it with just one crush washer and try and salvage the oil so i could re-use it.
  5. Jan 1, 2023 at 5:58 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    For God's sake, just drive the damn thing! It ain't gonna leak and you can correct it when you do your next oil change.
    TacoTime55, YE2KA, Chew and 3 others like this.
  6. Jan 1, 2023 at 6:18 AM
    Fastbolt
    Fastbolt Member
    SW PA
    White 2022 Toyota Tacoma TRD Pro
    ReTraxPro MX Bed Cover, Miller Cat Shield
    To the original poster, the exact same thing occurred with me and my 22 Pro. I have been keeping an eye on mine and have discerned no leaks. This appears to be a non-issue.
    When I change the oil again, I plan on removing the extra washer.
    HTH. Good luck with your Trail Edition.
    YE2KA, G65P9810[OP], Chew and 2 others like this.
  7. Jan 1, 2023 at 6:18 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    ^This.
    So many either forget, don’t believe or don’t know…
    mattleg[QUOTED] and whatstcp like this.
  8. Jan 1, 2023 at 6:37 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    How much is the oil worth compared to your engine if you don't notice a leak while your driving. Knowing that there are 2 washers on the drain bolt would bug the crap out of me. Do it right,drain the oil ,forget about it, pop the washer off and reinstall properly. So you waste $35 worth of oil,big deal, you did learn something about your truck,priceless.
    YE2KA and 22Coma6MT like this.
  9. Jan 2, 2023 at 7:37 AM
    mitt22
    mitt22 Well-Known Member
    I have found the toyota washers really stick to the pan. I was hoping it would get better with oil changes, but the 2nd one was just as stuck as the first.
    YE2KA likes this.
  10. Jan 2, 2023 at 9:04 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    If you are like the more, er...excitable... members here and won't be able to sleep at night without going to a lot of trouble and expense fixing a nonexistent problem, then you should by all means do so. Otherwise just check underneath for leaks, (there won't be any), a few times in the first couple of hundred miles and call it good.
    For all the doomsayers, don't read the next part lest you have a stroke.:)
    A few years back I did an oil change on my second gen and after buttoning everything up I found the drain plug gasket in the bottom of the drain pan.:facepalm: I thought about fixing it at first but decided just to keep an eye on it. In 5,000 miles, until my next oil change, I never lost a discernible amount of oil.
    YE2KA likes this.
  11. Jul 20, 2024 at 8:46 AM
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    It seems like this mistake was more common than I anticipated lol....I did the same. I figured it fell into the oil drain pan after transferring it to another container to take it to recycle I noticed it wasn't there. Upon checking the drain plug I saw the new gasket over layed the old one. No leaks I will monitor next couple days but I think I should be fine and I'll fix the issue on my next oil change.
  12. Jul 20, 2024 at 11:20 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    My oil drain plug crush washer just started to show some wetness. I noticed a small stain on my garage floor. Checked the torque and don’t want to go tighter so I put a piece of cardboard on my floor. Dipstick looks good so I will deal with the washer during my next scheduled oil change.
    Just look for stains and check your dipstick regularly and you will be fine.
    YE2KA likes this.
  13. Jul 20, 2024 at 11:23 AM
    YE2KA
    JB
    You accidentally doubled up as well?
  14. Jul 20, 2024 at 11:34 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    2 crush washers isn’t a big deal. It’s not like 2 filter gaskets on center threaded oil filters. It won’t leak. I’ve done it maybe 3 times. What I do now is drain the oil and when it’s through dripping take a 1 foot piece of pvc pipe and rub it over the hole. It will knock the old washer off without scratching the pan. Also I coat the washer with a little oil on both sides before installing it. It helps sometimes when removing it. Good luck.
    YE2KA likes this.
  15. Jul 20, 2024 at 12:33 PM
    #35
    TA2016
    Oregon
    No double washer. I believe the new washer is defective. I wonder in my case if 2 washers may have been a benefit.
  16. Jul 20, 2024 at 1:27 PM
    #36
    YE2KA
    JB
    Has your drainplug always leaked?
  17. Jul 20, 2024 at 1:38 PM
    #37
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    Check out Fumoto drain valve and you won't need drain plug gaskets.
    TA2016 likes this.
  18. Jul 20, 2024 at 1:40 PM
    #38
    TA2016
    Oregon
    No never had a drip before. Also just noticed the wetness around the drain plug 8 months after the oil was changed. Pan bolts are tight and the outside of the oil pan is clean so I know the leak is coming for the plug.
