Oil drain crush washers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 147 mulie, Jul 29, 2017.
  1. Jul 29, 2017 at 10:28 AM
    147 mulie
    147 mulie [OP] New Member
    I have a 2012 Tacoma and a 2016 Camry and i do all of my maintenance by myself. I've been changing my own oil for 40 years now.
    When I first bought my truck, the Toyota oil drain crush washers were blue and loosening the drain bolt took the same amount of effort as tightening it.
    A couple of years ago Toyota switched to a black crush washer and I noticed that the drain bolt became very easy to remove....it was nowhere as tight as I had originally tightened it. Concerned about the bolt falling out, I'll retighten the bolt between oil changes.
    Has anybody else noticed the? It has to be a deformation of the crush washer over time.
    TXpro4X4 likes this.
  2. Jul 29, 2017 at 10:32 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Torque the drain plug to spec and you won't have a problem. If you start noticing an oil leak around the drain plug it's time for a new crush washer. If your really paranoid they make drain plugs that are able to be safety wired. Mark the drain plug with a sharpie or nail polish and see if it turns by itself if your that concerned.
    wilcam47, ecgreen and Tex-Tac like this.
  3. Jul 29, 2017 at 10:40 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    Black crush washer? The ones I get with my filters are silver, I assume aluminum.
  4. Jul 29, 2017 at 10:42 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  5. Jul 29, 2017 at 10:44 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    I buy them for $1 at the dealership. Change it out ever oil change.
    ajb6948 likes this.
  6. Jul 29, 2017 at 10:46 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Get a fumoto valve and you don't have to worry about this anymore
    Daves300, TegoTaco, Blockhead and 4 others like this.
  7. Jul 29, 2017 at 10:48 AM
    Justanotherhemi
    Rick James
    I just bought this. Waiting for next oil change to put it on.
    TexasWhiteIce[QUOTED] likes this.
  8. Jul 29, 2017 at 10:50 AM
    TexasWhiteIce
    Texas
    You'll love it man, it changed my life.
    Can do an oil change with zero tools, and no mess to clean up.
    Daves300, Bagman, Blockhead and 2 others like this.
  9. Jul 29, 2017 at 10:52 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    How do you get the filter off without tools?
    My 2.7 l 4 cyl doesn't have a crush washer on the drain plug, there's a rubber gasket. No leaks.
  10. Jul 29, 2017 at 10:53 AM
    TexasWhiteIce
    Texas
    I hand tighten+ quarter turn the oil filter. Next time you change the filter, you can twist it off easy.
    CusterFan and camdenthekid like this.
  11. Jul 29, 2017 at 10:53 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    With your bare hands :muscleflexing:
  12. Jul 29, 2017 at 10:55 AM
    cosmicfires
    David
    Everett, WA
    You're tougher than I am. The filter is hot.
    EatSleepTacos[QUOTED] likes this.
  13. Jul 29, 2017 at 10:55 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    The problem with the fumoto valve is my oil pan and tranny pan had significant dents in them and I had to change them both out.
    Don't ask me how that happens lol but the crossmambers only had scratches.
  14. Jul 29, 2017 at 10:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't change my oil when the engine is hot. Only mildly warm.
  15. Jul 29, 2017 at 10:57 AM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    The mere mentioning of these drive me nuts. Why risk losing your oil if that component fails? What is the issue with removing a drain plug that makes it worth the risk?
    blm, TacoZmtn, bax and 9 others like this.
  16. Jul 29, 2017 at 10:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe because a shit load of people run these and I haven't heard of any failing. Especially if you get that little plastic clip on it.
  17. Jul 29, 2017 at 10:59 AM
    TexasWhiteIce
    Texas
    I have yet to read a failure of these on this website. I've had mine for 5 years now and never a problem and I do my oil changes twice a year.
  18. Jul 29, 2017 at 11:00 AM
    Justanotherhemi
    Rick James
    Pictures of said clips please
  19. Jul 29, 2017 at 11:00 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  20. Jul 29, 2017 at 11:01 AM
    TexasWhiteIce
    Texas
    You don't need the clip, the valve itself requires you to push in on the lever and then turn, it's not like you can just turn the lever.
    CusterFan and Silverspool like this.
