Oil change volume, 85% and call it good?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by malatx, Jul 24, 2022.
  1. Jul 24, 2022 at 7:59 PM
    malatx
    malatx [OP] Well-Known Member
    2022 TRDOR DCLB Army Green
    Just did my first oil change on the 2GR-FKS 3.5L V6
    I poured 6 qts and the dipstick reading is at 85% full.
    I really hate to break open another quart bottle and bring it to full with 0.1-0.2 qt and have that opened bottle sit around.
    Can I just run it with 6 qts not at full mark and call it good? The service manual for oil change does say add to full, but I wonder what happens if I don't add exactly to full line?
    Reduced heat absorbing capacity? Oil runs hotter? Less capacity to hold contaminants?
  2. Jul 24, 2022 at 8:08 PM
    malatx
    So the instruction calls for adding to full mark, should just be ideally shoot for full, but anywhere between min and full is fine.
    I'd be so less stressed out about it
    CusterFan likes this.
  3. Jul 24, 2022 at 8:11 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Anywhere above the add/min line is completely fine for safe operation.
    SR-71A and CusterFan like this.
  4. Jul 24, 2022 at 8:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The acceptable range is anything between the marks. We have a low oil sensor that doesn't trigger until well below no oil on the dipstick.
  5. Jul 24, 2022 at 8:13 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The nice thing about getting it full is you know where it started so it’s easier to tell if it’s consuming any. I would be tempted to get it perfect until I was familiar with the engine and certain that it doesn’t consume. After that, go nuts.
  6. Jul 24, 2022 at 8:13 PM
    Bishop84
    Bishop84 Well-Known Member
    It's a min max. I always go slightly below. Don't worry.
    LOL 15 PAGES INCOMING
    ToyoTaco25, Whacko, Kev250R and 8 others like this.
  7. Jul 24, 2022 at 8:15 PM
    0xDEADBEEF
    ToyoTaco25, jon_elc, mtip and 12 others like this.
  8. Jul 24, 2022 at 8:15 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    No harm if it's slightly below the full mark. That said, I open a can and use it as the top off oil then toss it behind the back seat for any topping off between changes. Luckily my engine doesn't consume any measurable amount between 5-6k mile changes so I've never used it for anything besides the next oil change top off. Modern synthetic oil doesn't oxidize easily in a hot engine and doesn't oxidize at all sitting in the bottle so it's not like it will go bad.
  9. Jul 24, 2022 at 8:22 PM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    Just remember, you poured in cold oil out of a bottle. The oil is going to expand at operating temperature and going to give a higher reading at that time (vs. cold) which is when it matters and when you should check it. Pour in your 6 qts, go for a quick drive and get it to operating temperature, then shut it down. Wait a few min for the excess to drain down the dipstick and then check it.
    95% of the time I pour in 6 qts at an oil change, let it heat up, and that gives me about 75 to 85% the way up between the two marks on the dipstick. That is perfectly fine.
    Taco dv likes this.
  10. Jul 24, 2022 at 8:25 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    Why not just crack open that 7th quart? Stressin out about minor oil levels just to save $7.00!
    Taco owners now days:fenforcer:
    TacoTin0350, jon_elc, mlcc and 3 others like this.
  11. Jul 24, 2022 at 8:29 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I'm concerned how stressed you are with either choice.
  12. Jul 24, 2022 at 10:02 PM
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    If you checked it before running the motor (after your oil change), then you’ll lose about a 1/2 quart filling up your oil filter after you start it up. Mine takes 6.5 quarts to read full.
    Asgard likes this.
  13. Jul 24, 2022 at 10:10 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Crack open another bottle and keep in your Tacoma for unforeseen events.
    jon_elc and Superdave1.0 like this.
  14. Jul 24, 2022 at 10:42 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    The consensus I have read is an opened bottle of oil should be used within one year.
    https://www.oildepot.ca/shelf-life-opened-bottle-motor-oil/
    However, for me by changing the oil in my Tacoma, Corolla and Scion I use very close to 15 quarts to get all 3 vehicles to the full mark. If you have multiple vehicles in your household, see if you can change the oil in all of them and end up with no remaining opened bottles too.
  15. Jul 24, 2022 at 10:42 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Crack the next bottle. Pour in .2 qt. Save open bottle for next oil change. Ta da! I take venmo, zelle, cash, gas, @$$.
    Taco dv likes this.
  16. Jul 24, 2022 at 11:08 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    85% of 6.2 qts is 5.27 qts.
    85% of 6.0 qts is 5.10 qts.
    Are you sure that you used 6 quarts and not just 5 quarts?
    Parking on a slight incline will also affect the dipstick reading, showing lower oil.
    ScrippsRanch67 likes this.
  17. Jul 24, 2022 at 11:12 PM
    OregontoBajaCA
    2017DCLBOR
    If you can drive your vehicle for an entire year and use the oil for 10,000 hard miles of dirt, gas, moisture and combustion contamination, I think that new oil can sit in an opened bottle for a lot longer than one year and still be perfectly good to go.
    TacoTin0350, jon_elc, Kev250R and 4 others like this.
  18. Jul 25, 2022 at 3:36 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    my truck is new and i've changed the oil once so far. i put in 6 quarts and on level ground, it's very close to the full mark and i called it good.
    Taco dv, #4TOY4ME and CusterFan like this.
  19. Jul 25, 2022 at 3:39 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    How much does the manual call for? Put that much in.
    jackn7 and zoo truck like this.
  20. Jul 25, 2022 at 3:41 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    My tail is of the dealer changing my oil and not filling it to 100%, they have a 55 gallon to pump from.. no excuse . I called them on it and they said bring it back in.. I laughed and will never bring it back in to that dealer.
