Oil change through dip stick hole????
Discussion in 'Technical Chat' started by sultan, Dec 16, 2007.
  1. Dec 16, 2007 at 1:09 PM
    sultan
    sultan [OP] New Member
    Is it permissible to syphen out the oil through the dip stick hole when doing an oil change?
  2. Dec 16, 2007 at 1:12 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Why would you want to try it that way? I don't know how far into the pan the tube goes but pulling the drain plug is considerably easier than trying to push a small hose down the tube and sucking out the oil that way.
  3. Dec 16, 2007 at 1:19 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Why would you do that?
    Did something happen to your oil drain plug? Or can't you get it off?
  4. Dec 16, 2007 at 2:45 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Maybe he likes to do things the more difficult way?
  5. Dec 16, 2007 at 2:58 PM
    sultan
    Several manufacturers recomend oil changes that way......
  6. Dec 16, 2007 at 3:09 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Oh yeah ? who ?
  7. Dec 16, 2007 at 3:18 PM
    sultan
    VW and Mercedes
  8. Dec 16, 2007 at 3:31 PM
    Nitro_rc
    Nitro_rc Active Member
    07 DoubleCab TRD Sport 4X4
    It's possible to siphon the oil. But because the Tacoma's oil pan has a smaller bow/hump toward the rear of the engine, you might not be able to siphon out all the old oil. You have to make sure your siphon hose somehow reach this area, that way you can siphon all the old oil (pretty hard to do).
    On my MBZ 280C, I siphon the oil out. Because the pan at the bottom is perfectly flat, I just stick the siphon hose down the dip stick, make sure it touch the oil pan, turn on the pump, sit back have a couple beers, then fill her up with new oil again.
    On a Tacoma, I recommend doing it the old fashion way. Here's a few link for you if you still want to go the siphon way.
    http://www.amazon.com/dp/B00008VE3X?smid=ATVPDKIKX0DER
    http://www.acehardware.com/product/index.jsp?productId=1272832
    http://www.amazon.com/dp/B0002AJR8E?smid=A3ONVYY4BUAORQ
  9. Feb 16, 2008 at 8:06 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    I had a setup for my VW. Tried it on my Tacoma. I got about 2-3 quarts out. So I put the pump away and unbolted the drain. You have to get under the truck to get the filter off anyway. They sell drain valves so you thread a hose on and can fill a container (less mess) I did that on a few cars. As long as you make sure the threads don't leave a puddling area in the pan it works great.
  10. Feb 16, 2008 at 9:46 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    huh? My filter is up top near the battery.... :confused: Are the 4-bangers in a different spot?
  11. Feb 16, 2008 at 10:27 PM
    marvin02
    marvin02 Well-Known Member
    '07 Access Cab SR5 - Black
    Top Dawg Folding Tonneau Cover, DIY Bed Light, Aux. Input for MP3 Player, OEM Bed Mat
    Yes, and I am jealous of the nifty location that the 6-cyl's have. Way easier to get to the filter on the six!
  12. Feb 17, 2008 at 1:11 PM
    lawnrevenge
    Southern California
    I too am jealous of the filter location. Am tempted to relocate the filter. First time I yanked it I got oil all over everywhere. The easiest trick is to put an old tubesock over it to absorb any spilled oil.
  13. Feb 17, 2008 at 2:32 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Had a filter relocator on my '99 by Permacool I believe. I think I got it from performance products back when. I put it under the drivers front fender under the battery and a change only took about 10 min. tops. Drain pan set on the tire for filter and one under the pan. Haven't had to change the '08 V6 yet but must say that the engineers did good on this one.
