Oil change on my 2013 Tacoma 6 cyl
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baseball6931, Jun 16, 2020.
Type of synthetic oil for Tacoma 6 cyl that tows
Poll closed Jun 23, 2020.
  1. Type of oil synthetic
    3 vote(s)
    100.0%
  2. Type of oil filter
    0 vote(s)
    0.0%
  1. Jun 16, 2020 at 12:28 PM
    baseball6931
    baseball6931 [OP] New Member
    William
    2013 Tacoma
    Hello I usually get my oil done at a jiffy lube, but now trying to save some money in these crazy times. What do you recommend for full synthetic oil and what oil flilter? for 2013 Tacoma that tows? Also how much does it hold. 6 cylinder.
    Thank you
  2. Jun 16, 2020 at 12:38 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Toyota oil filter, 5w-30 Mobil 1 full synthetic high mileage protection if you have over 75k and 5.5qts.
  3. Jun 16, 2020 at 1:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Dont bother with high mileage. If the vehicle shows no signs of oil leaks DO NOT USE HIGH MILEAGE OIL. High Mileage oil is designed to swell seals and reduce or stop leaks. If you arent leaking you will swell seals, causing excess seal wear.
    Regular Mobil 1 5-30 syn is good stuff. Realistically any oil standard or synthetic so long as its the right weight 5w-30 and meets the specs of the truck will be fine. But like stated steer clear of high mileage oils. And if you do use high mileage oils, DO NOT SWITCH BACK unless you like oil leaks.
    OEM toyota filters can be had online for 4-5 bucks a piece and have MUCH greater filter media than most others.
  4. Jun 16, 2020 at 1:12 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    you don’t realize how much money you’ve been wasting,man. (And risky letting Jiffy Lube change your oil).
    Highly recommend a fumoto valve. I can change my oil with no tools and no mess in about 1 hour ( only about 5 minutes of actually work, the other 55 minutes is letting the oil drain out)
  5. Jun 16, 2020 at 1:19 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
  6. Jun 16, 2020 at 1:41 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    OEM filter
    Mobil-1 5w-30
    New crush washer
    nd4spdbh likes this.
