Oil Change, I'm Stupid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jage, May 17, 2013.
  1. May 17, 2013 at 9:36 AM
    jage
    jage [OP] Well-Known Member
    Franktown CO
    '010 Silver Double Offroad Leather/Sunroof
    So I didn't read and I didn't search and changed my oil for the first time in a hurry. Easiest oil change ever? Not when you manage to drain the entire filter onto the driveway, sorry, half- the other half is all over the A arm and skidplate. WTH is that little drip cup for when it just directs the oil immediately onto the A arm?
    Seriously, what am I doing wrong because it seems like the top oil filter is much worse as it just dumps all over.
  2. May 17, 2013 at 9:41 AM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
  3. May 17, 2013 at 9:45 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    That is why you use a catch basin of some sort, they sell them for $2.99 at the parts store where you got the oil, skid plate should come off for cleanest approach to oil filter...
    I then transfer the contents of said basin to a 3 gallon container which I use for draining the pan, then recycle when full...
    Once you get good at it, about 30 minutes and you should be good to go...
  4. May 17, 2013 at 10:08 AM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    when you take off the oil filter theres a drain hole in the catch, your supposed to but like a chopped off water bottle or any container that fits under there to catch the oil....the oil wont magically disappear and drain into the abyss
  5. May 17, 2013 at 10:11 AM
    tacofire38
    tacofire38 Captain Taco
    Land o Pears,TX
    08 Taco PreRunner SR5
    V-Tech gunmetalrims, BFG All-Terrains, Front 5100s and OME 884 coils, Rear 5160s, Rear AAL, SpiderTrax Wheel Spacers, Hummer Bed Rack, Thule Kayak Roof Racks........
    I use a plastic Dixie cup just hold it under the drain hole and unscrew the filter and waalaa! no spilled oil lol:D
  6. May 17, 2013 at 10:12 AM
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    Attach a hose to the drain and run it underneath the truck. Next time you change the oil you just have to put a bucket where you routed that hose.
  7. May 17, 2013 at 10:12 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    The 4.0l Tacoma is the easiest oil change I've ever done. I love the filter design, use a hose or water bottle to catch the oil remnants in the filter
  8. May 17, 2013 at 10:14 AM
    Slesse
    Slesse Tacoma level 27
    Kyle
    Port Coquitlam
    08 Tacoma
    Pro Comp Rims;32" Duratrack Tires; OME heavy duty lift in rear; 2" spacer lift in front; custom raised bed in box; Lear canopy; grillcraft grill; Rosen Head unit; Trail gear sliders; Tinted windows all around; Intermittent Wipers; White LED dash; Deactivated seat belt buzzer; Blue Sea Fuse panel; BAMF light bar running 4 Lightforce 170's (2 HID); FX-R retro HID's 4300k, with amber halo's, BHLM with black reflector bowl; stealth mode; Fenix Hide-a-way flashers as DTRL's; VIAIR OBA kit with 2.5 gal tank; 14" Magnaflow stainless steel cat back exhaust; de-badged; Hybrid badge applied; seasonal 4wheel camper "Fleet"
  9. May 17, 2013 at 10:16 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    like sex, first time is always sloppy
  10. May 17, 2013 at 10:16 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i usually end up taking a 20oz bottle and wedging it under there. lost the cap for the nipple, so no need to remove that anymore.
  11. May 17, 2013 at 10:24 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Like the others said. You just need a bottle or tube to catch it. :) At least your just stupid not krazie!!! Pun intended
  12. May 17, 2013 at 10:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I do this also. Just wedge a 20 oz. bottle from your favorite soda under the drain hole and you're all set.
  13. May 17, 2013 at 10:38 AM
    Snowbrdr1220
    Snowbrdr1220 Well-Known Member
    PA
    13 DC TRD Off Road NBM
    I just put an empty quart size oil container under the drain nipple, they easily fit right in there without any modification. Crack the oil filter slowly and let it drain. Easiest and cleanest oil changes I have ever done!
  14. May 17, 2013 at 2:48 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Just don't do what I did last time. I forgot to take the stupid rubber nipple off the drain hole.
    After making a big mess, that rubber piece is now in the garbage.
  15. May 17, 2013 at 2:52 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    :laughing:
  16. May 17, 2013 at 2:53 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    I think a lot of us did that the first time if you didn't read the DIY first. McDonald's or any large fast food cup wedges in nicely, plus has a large enough mouth to catch it all if you can't get something right up to the drain hole.
  17. May 17, 2013 at 2:53 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  18. May 17, 2013 at 3:06 PM
    Riverdog
    Riverdog Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    I did that the first time as well. Sucks. Now I just hang a pop can (or soda can depending on where you live) below the little drain to catch the oil. At least you didn't drain the transmission fluid. I've heard of at least one person that did that. :eek:
  19. May 17, 2013 at 3:10 PM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    I used an empty oil quart with the top cut off once. And left it there for like a month
  20. May 17, 2013 at 3:18 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I'm a tube man myself...........:D
