Oil Change Dilemma - Need to add oil?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CenterKnurl, Sep 3, 2021.
  1. Sep 3, 2021 at 4:45 PM
    CenterKnurl
    CenterKnurl [OP] Well-Known Member
    I like to buy my own oil and filter, take it to a mechanic that I've used forever, and have them do the labor of changing it. I forgot that my 3.5l V6 is supposed to take 6.2 quarts of oil - I only brought 6 quarts with me. I bought an extra quart on my way home, but I'm not sure how to check if I actually need to add oil. The dip stick looks "full" per oil being on the dimple on the stick, but it doesn't seem very precise. There's a small chance that the technician may have added a little bit of oil to top it off after my oil was put in.
    What can I do to know if I need to add the extra .2 quarts without risking overfilling?
  2. Sep 3, 2021 at 4:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    .2 is 6.4 oz.
    You can add that much if it makes you happy, or you can leave it alone, as likely close to that was residual in the engine.
    Either way no harm will come.
    Markcal, zoo truck, Stoked4 and 5 others like this.
  3. Sep 3, 2021 at 4:52 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I wouldn't sweat it.
    Tacos4ever15 and Bleep100 like this.
  4. Sep 3, 2021 at 5:00 PM
    Nymbus
    Nymbus Well-Known Member
    2021 TRD Offroad DCSB Cement 4x4 AT
    I’ve always done my oil changes on my vehicles. On the Tacoma I put 6 quarts when I change the oil. There will always be some residual left after draining. Even then being off .2 quarts will not harm anything. I do keep a quart of oil in the car just in case I ever do need to add
    kahanabob likes this.
  5. Sep 3, 2021 at 5:05 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just leave it. No sweat at all.
  6. Sep 3, 2021 at 5:06 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Check the dipstick and trust it. If it is a quart low, add one full quart. Anywhere between the full, and the add one quart line on the dipstick is OK. If you're right in the middle and want to add 1/2 quart then that is OK too. But I'd not bother with anything less than 1/2 quart, and even 1 quart low won't hurt anything.
    Key-Rei likes this.
  7. Sep 3, 2021 at 5:09 PM
    Bishop84
    Bishop84 Well-Known Member
    I set all my oil changes a bit low from full marks, this allows for heat expansion.
    You'll have no issue with 6 qt
    kahanabob and TnShooter like this.
  8. Sep 3, 2021 at 5:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You can be 1.6qt low on oil before it’s “Low”.
    According to the manual, between the 2 dots is Normal.
    I prefer the level to be closer to the top dot. But even the middle is ok with me.
    I wouldn’t worry about it. :thumbsup:
    davidstacoma, tacotoe and Skydvrr like this.
  9. Sep 3, 2021 at 5:53 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You are fine. Worry about important stuff. Like popcorn and tube tops.
    davidstacoma, Skydvrr and tacotoe like this.
  10. Sep 3, 2021 at 8:58 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Honestly, I am a bit surprised we haven't heard from THAT person telling you to add that .2/qt or there will be engine failure in your future. Wait for it, it'll come. In the meantime, your good in the eyes of the majority. :thumbsup:
    Skydvrr likes this.
  11. Sep 3, 2021 at 9:17 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I read somewhere and it makes sense, better to be a hair under than a hair over....
    I don't know why it makes sense but it did at the time.
  12. Sep 4, 2021 at 5:13 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    :rofl:
  13. Sep 4, 2021 at 5:54 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    You should be good. You know what's bs? when the dealership charges you for the extra .2 quarts of oil and charges a full quart. like they don't have it in a giant ass drum
  14. Sep 4, 2021 at 6:03 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Over full by an appreciable amount will cause more drag on the crank as it has to run through more volume in the pan, oil sitting where it's only expected to splash, etc.
    zoo truck likes this.
  15. Sep 4, 2021 at 6:12 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yeah, way worse to overfill. Same for an automatic tranny.
  16. Sep 4, 2021 at 6:17 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    You are right. Never thought about that. Also I think the rear differential takes 1.1 quarts, they probably will charge for 2 quarts. I may just demand that they bottle the rest of the fluid that I paid for and hand it to me. Just to watch them stammer while they come up with an excuse why they can’t do that.
    TRD2021SPORT and DanoTay like this.
  17. Sep 4, 2021 at 11:59 AM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Trust the dipstick.
    Bleep100 likes this.
  18. Sep 4, 2021 at 12:12 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I always add the .2 Quart but it also wouldn't bother me to just leave it out either.
  19. Sep 4, 2021 at 2:12 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Let your truck sit on level ground for a couple of hours, then pull the dipstick out and look at it before wiping. The dipstick can be hard to read with new oil. See where you are at on the picture in post #8 and adjust if needed.
  20. Sep 4, 2021 at 2:16 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    I posted this in another forum and it is the best way to check oil on most vehicles with such tight fitting dipsticks.
    The best way (in my opinion) is to shut the vehicle off and pull the dipstick up a few inches - that allows the air seal to break in the tube. Let it sit a few minutes or even overnight. I always find it best to check when the oil is cool. If you wait till morning, there is no need to pull and wipe the stick. Just push it down and pull it out and the reading will be absolute. Regards Scott
