Oil burning after new PCV valve
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattsyota529, Feb 16, 2022.
  1. Feb 16, 2022 at 12:34 PM
    Mattsyota529
    Mattsyota529 [OP] Active Member
    2009 Tacoma Prerunner
    Has anyone had trouble with the 4.0 burning oil? I just recently replaced my pcv valve with the oem part and now it's slowly burning oil. There is some smoke coming out the exhaust and the oil level is lower. Trying to get it fixed and be done with it. Engine has 91k. Thank you
  2. Feb 16, 2022 at 12:35 PM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    What made you replace the PCV valve?
    TnShooter and SR-71A like this.
  3. Feb 16, 2022 at 12:37 PM
    Mattsyota529
    Engine wasn't running the best and had trouble accelerating and was sucking gas more than normally. I inspected the old one and it was dirty and clogged. I read online for our trucks they need to be replaced every 30k and I know mine has never been replaced.
  4. Feb 16, 2022 at 12:41 PM
    fourfourone
    That's odd to have those issues at only 90k. Sounds like something else is wrong. Did the truck throw any error codes when it was running rough?
    wilcam47 likes this.
  5. Feb 16, 2022 at 12:49 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    ^ I agree. Got ~96k on mine and not a single drop of oil between changes.
    Did the oil burning start when the new PCV went in?
    wmb67 likes this.
  6. Feb 16, 2022 at 12:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Where did you read it needs to be replaced every 30k miles?
    It's easy to check, take it out and shake it if it rattles it's probably still good, alternatively though I don't recommend it as it is combustion fumes but you can suck on the line and if you can pull through it it's venting then try to blow through the line and if it stops the back floe it's good.
    I replaced mine last over 60k ish ago, still good.
    Monkeybutt2000 and 6 gearT444E like this.
  7. Feb 16, 2022 at 12:55 PM
    Mattsyota529
    Absolutely no codes. Still runs fine but it's a little concerning. Still runs fine.
  8. Feb 16, 2022 at 1:01 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just because you changed the PCV doesn't mean that is the cause or if you even have a problem. Install the old PCV and see if the "oil burning" stops.
    All engines burn some oil.
    How much oil is being burned between oil changes? Be specific.
    What do the spark plug tips look like?
  9. Feb 16, 2022 at 1:24 PM
    Mattsyota529
    This was the first time it's ever burned it. And I only assumed it was the valve because whenever I replaced it I saw bits of smoke coming out the exhaust even though the motor was warmed up. It hasn't ever done it before to my knowledge until I changed that valve. At first I assumed it was carbon build up but it seems much more than that now
  10. Feb 16, 2022 at 1:42 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d dive for a week. Keep an eye on the oil level. When you changed the PCV maybe it is flowing better. And the oil that makes it’s way in the line had “built up”. Maybe you just need to drive if for awhile?
    Some guys go as far as installing an oil catch can. I myself don’t find it necessary on the 4.0. At least not yet. As I haven’t had any issues with excessive oil build up in the intake as far as I know.
  11. Feb 16, 2022 at 1:46 PM
    fourfourone
    If the truck is blowing smoke and eating oil I personally would not recommend driving it until you get it sorted.
    SR-71A and Key-Rei like this.
  12. Feb 16, 2022 at 1:46 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Lets try this again:
  13. Feb 16, 2022 at 4:33 PM
    Mattsyota529
    I checked it later today and the level is fine. Not low. It just seems to smoke a lot more so I'm guessing it's old oil and moisture built up flowing freely. I've only driven like a total of 100 miles with the new valve. Maybe it needs to be fully broken in or so. It mainly does it when it's cold started and once it's fully warmed up it doesn't do it anymore. It does it whether it's cold or hot.
  14. Feb 16, 2022 at 4:44 PM
    Mattsyota529
    If I'm being honest, I don't think it's burning but I think it is burning bits of oil built it from the clogged pcv valve. Spark plugs look good. Changed them 8k miles ago with oem plugs.
    Jimmyh[QUOTED] and Key-Rei like this.
  15. Feb 16, 2022 at 7:32 PM
    Anothertacomadriver
    Anothertacomadriver Active Member
    Anthony
    2014 Tacoma V6 Manual
    Let’s try this again “between oil changes” so if he’s running synthetic that will be 20,000 miles. So for now he’ll pull the spark plugs and then drive 20,000 miles to answer your question. Maybe you should try this again and you should be more specific. You sound fun to hangout with.
  16. Feb 16, 2022 at 7:53 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    synthetic oil change interval isn’t 20k. Toyota recommends 10k or 12 months which ever comes first if your vehicle requires synthetic from the factory. If your vehicle requires dyno oil from the factory (all second gens) Toyota recommends sticking to 5k/ 6 month intervals regardless of what oil is used (dyno or synthetic). To say some people don’t stretch intervals would be a lie. Some people suggest 10k. I haven’t heard 20k recommended yet. Ive run full synthetic since I purchased my truck and change it every 5k no questions. Doesn’t mean my intervals are correct however it is what Toyota recommends and gives me peace of mind. Oil and filters are cheap compared to the alternative.
    https://www.whiterivertoyota.com/blog/toyota-synthetic-oil-change-intervals/
    Asking how much oil is being consumed between changes and if newly changed plugs are oil soaked provides additional insight to suggestions.
  17. Feb 16, 2022 at 7:57 PM
    Anothertacomadriver
    Anthony
    I meant 20,000k as in 2 oil changes
  18. Feb 16, 2022 at 9:11 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    A faulty PCV valve will not cause oil loss in the manner you describe. It can cause oil leaks if the valve, or PCV hose, is plugged due to buildup pressures, but not oil burning. Blue smoke out the tail pipe, more so at startup after a few days sitting, is more indicative of worn/torn valve stem seal(s). It’s a costly repair if that is the diagnosis. If oil burning is not great, there are oil additives that may help. Some also recommend going to thicker oil, but with the low mileage you have, I wouldnt do that.
  19. Feb 17, 2022 at 1:20 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Never replace a cheap part because someone said it’s a good idea. Where in the manual does it recommend a PCV replacement at scheduled interval? Put the old one back in and chug along. Test the original part if you are doubtful, sometimes people create their own problems. 52DCDE82-6CA6-42B4-A1F5-72B03452E566.jpg
  20. Feb 17, 2022 at 1:37 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    For what it's worth, cleaning or replacing the PCV at a regular interval isn't something that @Mattsyota529 made up. @BlackBeerd's 2nd gen maintenance guide calls for this to be done every 30k-50k miles. While this isn't a manufacturer manual, the guy knows his stuff and surely based this figure on some sort of documentation from Toyota.
    https://www.tacomaworld.com/threads/2nd-gen-diy-maintenance-quick-reference-guide.438945/
    I replaced mine at 50k miles, and plan to again at 100k miles. Anything to keep the engine purring along.
    Kolter45 and SR-71A like this.
