Oil and Transmission Drain Plug Confusion
Discussion in 'General Automotive' started by KenLyns, Feb 24, 2012.
  1. Feb 24, 2012 at 8:29 PM
    KenLyns
    KenLyns [OP] 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    My local dealer had a Corolla displayed sideways to advertise rustproofing. I couldn't help noticing the similarity between the oilpan and transmission drain plugs. If you thought the Taco was bad... From what I can tell the smaller pan is for the engine, while the larger pan is the tranny, because of the driveshafts coming out of it.
  2. Feb 25, 2012 at 5:15 PM
    KenLyns
    Belly of the Beast
    ^ Seems perfectly logical, doesn't it? Yet a couple of experienced people on TW have done it. And the Taco's drain plugs have more distinction between them. I think a lot of people don't get under their vehicles far enough to get a look at the oil pan, especially on a car with low ground clearance. Instead, they fit a wrench over the most prominent bolt and start turning...
  3. Feb 25, 2012 at 5:26 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    It's so easy for Toyota to add labels to the plugs, I don't understand why they don't.
  4. Feb 25, 2012 at 6:38 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    My wife can change my oil ... nuff said
  5. Feb 25, 2012 at 6:45 PM
    KenLyns
    Belly of the Beast
    Meanwhile, another TW member's wife drove the truck in the middle of an oil change, with the oil filter missing. She didn't get very far...
  6. Feb 25, 2012 at 6:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Mine can too since I installed a Fumoto valve ;)
  7. Feb 25, 2012 at 7:00 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    The Taco's engine oil drain bolt is a no-brainer...it's the one under the engine.
  8. Feb 25, 2012 at 7:12 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    The other common thing (other than the oil plug being under the engine haha) is most oil plugs are on an angle and the vast majority of trans drain plugs are parallel to the ground.
