oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. Jan 17, 2021 at 8:19 AM
    #881
    Stighe
    Stighe New Member
    Scott
    Tacoma TRD
    By the way this TRD is stock and has 25k.
  2. Jan 23, 2021 at 6:36 AM
    #882
    Stighe
    Stighe New Member
    Scott
    Tacoma TRD
    Toyota TRD Sport drive line vibration (cont...)
    A update on the TRD Sport that has 27k on it. Stock everything. No mods. just a daily driver to and from work. No towing. No accidents. As I said it is now at Heritage Toyota in Burlington. A pretty big outfit. They have their two very best mechanics, Andrew and Toby, working on it. Maybe I should call them scientists. These two have a “can do” attitude. They have 65 years of Toyota experience combined. Wow.
    So new drive shaft and Diff was installed 3 weeks ago by a dealership in Berlin Vermont that left me with the shake and vibration . Service manager said too bad. Live with it. Decided With that attitude to run, not walk. I only went there because Heritage was back logged by 3-4weeks.
    So far the team at Heritage have been remarkable...thinks drive shaft ok. Drove without it. Still shakes and vib. We have replace brake drums and Toyota approved tires. They bleed the brakes because previous dealership did not do it well. Left them spongy. Air in left caliper confirmed. Shake vibration still there. What’s left? Diff, axles, and the crappy Tacoma wheels. Two wheels are not able to be road forced. Off by 40+ oz. So new ones on the way. I have heard numerous issues with defective alloy wheels. Please advise if you have this story.
    By the way I should tell you that I have a EVA vibration analyzer on the truck. I am a former ASE guy myself. Trucks been in 5 different shops the past month to date. Now Heritage. But maybe the best for last? I have a loaner Corolla from Heritage. So smooth. I’ll let you know if they try to charge me for the loaner. Should tell you I actually bought the truck 6 months ago from Heritage. So they seem to be treating me well.
    I will update you next week.
  3. Jan 25, 2021 at 12:33 PM
    #883
    slo2sixty
    slo2sixty Well-Known Member
    Syracuse, NY
    19 cement DCSB TRD offroad
    I've been fighting with toyota about my 19 offroad for months. Vibe at 55-75 and vibe on braking from 75-10mph. they've, resurfaced the drums, changed out my leaf springs, added shims, steering damper and dive shaft. still shakes and they're trying to tell me its normal like i don't know how trucks are supposed to feel. I'm actually on the line with cooperate for the 100th time trying to get it fixed correctly. My 1997 rotted out frame tacoma was smoother than this 40k junker.
    BrianTaco75 likes this.
  4. Jan 25, 2021 at 3:21 PM
    #884
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    Very interesting thread. I have 2 3rd gens, 2018 & 2020. Both TRD OR 6AT. Neither has the vibration issue. I do notice the "whine" in the 2020 but not the 2018. I can hear it, at times, but it is not constant so not close to something I would, typically take to a dealer. I've owned over 25 vehicles and never had one that didn't have some, annoying trait. The 2017 F250 I traded for the 2020 Taco had an intermittent squealing noise from the engine bay, from day 1. Sounded like a bad pulley bearing. Would come and go at idle. Took it to dealer and, of course, it sat and idled for over 1 hour and never made a peep. Truck never left me stranded so I quit worrying about it.
  5. Feb 11, 2021 at 7:00 AM
    #885
    slo2sixty
    Syracuse, NY
    After having all this done I went to another dealer and they're replacing my rear axle and bearings. Like I told the other dealer to check the first time I went there. But the customer can't be smarter than the tech right? Hopefully it fixes the problem this time.
  6. Feb 20, 2021 at 9:29 PM
    #886
    wmjchastain
    wmjchastain Member
    chazini
    2019 TRD Sport 4x4
    None
    Finally got someone at the Carson City Nevada dealership to listen. The rear diff was removed & disassembled. Irregular wear was found. Diff was replaced & the noise is gone!!!! God, I hope this is all finished.
    slo2sixty likes this.
  7. Feb 23, 2021 at 2:51 AM
    #887
    slo2sixty
    Syracuse, NY
    Toyota just did one of my axles now my rear end is making noise. I'm so done with this truck. Legit 12 visits for a vibration while driving and braking and now it's whining.
  8. Apr 22, 2021 at 3:24 PM
    #888
    pescadoman66
    pescadoman66 Pescadoman66
    CJ
    Livermore, CA
    2017 TRD OR 4X4 Pro Wannabee Stormtrooper
    Tacoma Pro Front Grille Tailgate Letters Console Organizer Clazzio Seat Covers TRD front Grille Emblem Westin Drop Steps Front Widow Tint Tow Strap LED lights Sunshade Prinsu Rack BackFlip Cover rack accessories crutchfield speakers Front Tweeter speakers Tuffy box sound deadening mat Westin LED light bar Led switch Light bar bracket TRD Pro Tail lights TRD Pro Wheels BF Goodrich KO2 tires from America's Tire Old Man Emu Lift Coils - Coil Selection: 2887 Bilstein 5160 Rear Shock with Reservoir Bilstein 5100 Adjustable Front Struts HeadStrong 3 leaf progressive Add-a-leafs JBA UCA's Low Range OFF-Road 1.25" Cast aluminum blocks in the rear
    I'm just curious where you found cinder blocks @ 38lbs a piece...:confused:
  9. May 8, 2021 at 4:47 PM
    #889
    cvisking88
    cvisking88 New Member
    2007 tacoma
    I was contemplating getting a new Toyota but after reading thru all the Service bulletins and issues i think I will either look for a second gen or get something else....
  10. May 9, 2021 at 7:55 PM
    #890
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    they have sold about a million of these trucks, and there may be hundreds on here who complain. Pretty small percentage. What do you think you will be able to buy that is more dependable than this truck? A Gladiator, Canyon, Colorado, Nissan? Have you read about them on their forums? I wish you good luck.
    clownkillerloaf likes this.
  11. May 10, 2021 at 6:49 AM
    #891
    anthonynoriega
    anthonynoriega I just wanna disappear and find nothing.
    Anthony
    Idaho
    2019 Tacoma SR5 QS DCLB
    OV Tune 2.0, UpTop Rack, RTT, Total Chaos Bed Stiffeners, LED Grille Lights, Custom decals and pretty stickers.
    Ugh... I think I am starting to experience this now, but looking for input/advice. 2019 SR5 DCLB AT.
    I can only describe it as shuddering/heavy vibration/shimmying when breaking and decelerating at somewhat mid speed... 30-50mph.
    It feels like I have warped rotors, but it feels like its coming from the engine or transmission area.... I've had bad breaks and worn rotors and this doesn't feel like that.
    Am I making this up in my head? Kinda sounds like this is a real thing... Looking for confirmation so my wife doesn't think I am crazy.
  12. May 14, 2021 at 5:34 AM
    #892
    davered00ss
    davered00ss Well-Known Member
    I'm having the same issue. Dealer just replaced the leaf springs. Now vibration is still there and the truck has a rougher ride.
    ItsGarand likes this.
  13. Jun 19, 2021 at 5:02 PM
    #893
    WoodMan NH
    WoodMan NH Active Member
    Woody
    '17 Tacoma DC LB 4x4 Dark Gray
    Chrome Tubes, Chrome Exhst Tip (yeah, I like the chrome look), Mudguards, HomeLink AutoDim Mirror
    Stighe - Just curious how your late January 2021 service worked out for you at Heritage up in Burlington . . . ?
  14. Jun 28, 2021 at 6:52 AM
    #894
    kmalone1459
    kmalone1459 Active Member
    2021 Tacoma TRD Offroad
    ICON RXT LEAFs, Fox Shocks, Fox Coiovers, CALI RAISED Sliders
    I swapped over to a tom woods driveshaft. Eliminated a lot of the vibration.
  15. Jun 28, 2021 at 4:05 PM
    #895
    WoodMan NH
    Woody
    kmalone - I appreciate the Tom Woods d/shaft solved a lot of your vibration, but I'm hoping Toyota MNA would step up to fix those of us with "bone stock" trucks . . . . (I know, you can wish in one hand and crap in the the other - see which one gets there first) . . .
  16. Aug 1, 2021 at 11:09 AM
    #896
    MCM
    MCM Well-Known Member
    I thought I read these issues had been resolved by Toyota on the 2020 and 2021 Tacoma's?
    Is that the case? Trans, driveshaft, rear brakes etc. Thanks
  17. Aug 1, 2021 at 8:11 PM
    #897
    WoodMan NH
    Woody
    MCM - If you've read that, I'd like to have you point that out in a post . . .
  18. Aug 1, 2021 at 8:17 PM
    #898
    MCM
    Its more lack of posts. I see few 2020 2021 posts with vibration issues.
    Brake or trans issues. Did you see them?
    "What tacomas to avoid?
    Quick answer: Avoid Toyota Tacoma year models 2006, 2007, 2008, 2009, 2011, 2012, 2016, and 2017. There have been a lot of issues reported with the 2006, 2007, 2008, 2009, 2011, 2012, 2016, and 2017 Toyota Tacoma year models and we recommend avoiding them.Mar 2, 2021"
  19. Aug 1, 2021 at 8:21 PM
    #899
    WoodMan NH
    Woody
    MCM - Please let me know what source you quoted that from, and how to get that in electronic print form.
  20. Aug 1, 2021 at 8:24 PM
    #900
    MCM
