Offset calculator?
Discussion in 'Wheels & Tires' started by Vst, Jun 20, 2023.
  1. Jun 20, 2023 at 8:49 AM
    Vst
    Vst [OP] IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    Hey guys I was wondering how I could tell what an offset would be with wheel spacers. For example I have some 3rd gen Trd Offroad wheels which I know are a positive offset but I have 1.25” spider trax spacers does anyone know what the offset would be with this setup? Thanks
  2. Jun 20, 2023 at 8:55 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    -6.75mm.
    +25 - 31.75 (25.4x1.25) = -6.75.
    What exactly are you trying to determine from this though? Offset being calculated with a spacer is kind of weird. Are you trying to compare where it would sit relative to other aftermarket rims with a known offset?
    DavesTaco68 likes this.
  3. Jun 20, 2023 at 12:34 PM
    Vst
    Scott
    Kodak, TN
    Exactly I want to see if it would be equivalent to like a zero offset but I see now it closer to a -6 correct?
  4. Jun 20, 2023 at 12:37 PM
    BLtheP
    Plano, TX
    The reason I wanted to clarify the purpose was because while it's "like a -6", it's only like a -6 on a 7" rim. Offset factors in the width of the rim. Very few aftermarket rims are 7" wide, so you won't have the same result on a stock 7" wheel placed to be near -6mm offset as you would an aftermarket 8" or 8.5" rim with -6 offset. Same for 0 offset. If you're trying to make it look like an aftermarket wheel that has 0 offset, you need to know the width of the aftermarket wheel you're trying to model after becuase it's probably not 7".
  5. Jun 20, 2023 at 12:39 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    drizzoh likes this.
  6. Jun 20, 2023 at 12:41 PM
    Vst
    Scott
    Kodak, TN
    Ok makes sense so most likely will be on a 17x8.5 wheel. I’m actually using the current 3rd gen wheels and spacers on my 1st gen tundra and the stance is pretty good but a little more negative offset would sit flusher
  7. Jun 20, 2023 at 12:44 PM
    TacoTwoDay
    TacoTwoDay Well-Known Member
    David
    Western PA
    2021 Tacoma TRD OR
    another nice resource...
