Official Bobbed Bed Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrbeggins, Mar 28, 2014.
  1. Mar 28, 2014 at 8:43 PM
    mrbeggins
    mrbeggins [OP] LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    I figured I would start a thread strictly for bobbed beds. I know there are a few people out there who have done this, most on earlier Tacoma's. Let this be a thread for discussions and how-to's for people thinking of shortening the box!
    I removed 11" out of the box and 5" off the frame of my 04 extra cab. The box now sits at 63" and the tailgate sits flush with the rear shackles.
    Finished product
    image by Tanner Tucker, on Flickr
    First I started off by measuring for the lines off the cab, then cut the box liner back so it wouldn't melt during the welding process
    I used duck tape to make the lines. Make sure you leave the rear line(closest to tail light) far enough forward to miss the bracket on the underside of the box.
    I don't have any pictures of the first cut, but here is the second cut with the center section cut out. I used a 7 1/4" cut disk for a skill saw to go through both layers of the box near the top and bottom sides of it.
    The tail light section cut out and prepped for welding
    Box prepped and ground for welding. I used a 60 grit flap disk
    Frame chopped and semi cleaned up for end caps and boxing
    Capped with 3/16" plate, welded on both inside and out of frame
    Some action shots thanks to my dad! Definitely a 2 person job to line everything back up
    The hardest part of the bob was getting the corners in the box to line up after the cut. You can see the gap I had going haha. It was extremely hard to keep a straight line with a grinder on such a tight radius and keep the 2 lines matching up.
    Fully welded out and ground smooth ready for Bondo. It took a long time to get everything perfect. But all my lines matched up nearly perfect. Keeping a straight cut line is very important and makes the tacking process go a lot easier!
    I'm not body guy, but it turned out pretty good for a 5 minute youtube video hahaha!
    I then had my room mate wrap the back of the box with matte black 3M vinyl. He does 3M installation professionally. Does outstanding work!
    Stretch!!
    Finished up!
    jubei, COMAtized99 and Jay-coma like this.
  2. Mar 28, 2014 at 8:45 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  3. Mar 28, 2014 at 8:53 PM
    fuballs
    fuballs Well-Known Member
    Ben
    BC, Canada
    07 Double Cab Long Bed SR5
    Leer Canopy, Thule Roof Rack, Aux Fog Lights, okledlightbars.com 30" double row, AUX fuse Box, Tepui Kukenam
    that looks sick! really well done
  4. Mar 28, 2014 at 10:37 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    +1 looks sick
  5. Mar 29, 2014 at 6:12 AM
    Jessie james
    Jessie james Active Member
    Jessie
    Tennessee
    03 Tacoma Double Cab 4x4 TRD 2016 Tacoma Double Cab 4x4 TRD SR5 Sport
    Looks real nice. Good job
  6. Mar 29, 2014 at 6:47 AM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Thanks guys!! I know I'm not the only one so let's see some more picktarssss
    One build thread that really helped me out was 45acp. He did a very nice job!
  7. Mar 29, 2014 at 7:19 AM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Hope to knock this out later this year! Subbed :popcorn:
  8. Mar 29, 2014 at 1:11 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    On my last Taco, I took 13" out of the bed to make it the same length as a double cab bed so you could run a soft top or hard shell if you wanted.
  9. Mar 29, 2014 at 1:21 PM
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    ^OD GREEN FTMFW.
    Awesome write up though :D. I would have wrapped the tail gate too but it looks great. How well do the MT/R's handle the snow?
  10. Mar 29, 2014 at 2:27 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    Yea...I like the red tailgate though. You can at least tell the truck is red from behind. The MTRs are awesome in the snow. Espcially deep snow. Ice...not so much
  11. Mar 29, 2014 at 5:16 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Colorado
    98 3.4L V6 TRD Ext. Cab 4x4 SR5
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
  12. Mar 29, 2014 at 5:20 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Nice work!!
  13. Mar 29, 2014 at 6:06 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Subd! wanna do this one day but will likely get the sas done first. my bed is about trashed anyway at this point haha
  14. Mar 29, 2014 at 6:15 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Nice work!
  15. Mar 29, 2014 at 6:15 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Wow you can make a thread out of anything these days :D
    :boink:
    I bobbed this baby 11" So short
  16. Mar 29, 2014 at 8:23 PM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    ^^ muddy bitch
  17. Mar 29, 2014 at 8:31 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I plopped 11 out of mine. My biggest word of advice is take the measurements from the front of your bed and do the best you can to transfer those to the inside. This ensures you can get the straightest cut possible.
    Sorry for the upside down pic. I rolled the truck.
  18. Mar 29, 2014 at 8:32 PM
    PcBuilder14
    Brent
    Nor Cal
    Those tires have some good grip! :eek:
  19. Mar 29, 2014 at 8:50 PM
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    This looks great on the A-cabs n single cabs. Has anyone done a double? I love having a camper too much to do this. Just wondering what it would look like.
  20. Mar 30, 2014 at 6:45 AM
    mrbeggins
    Tanner
    Airdrie Alberta
    04 Tacoma
    I haven't seen anyone do a DC come to think of it now that you say something. I think it would look pretty sweet. But their boxes are small enough already hahah, taking another 10-13" out if it would make it completely useless haha.
