Off Road trails near Orange County,CA
Discussion in 'Off-Roading & Trails' started by danbarone1994, Dec 7, 2019.
  1. Dec 7, 2019 at 7:31 AM
    danbarone1994
    danbarone1994 [OP] Well-Known Member
    Daniel
    2019 Toyota Tacoma Gray TRD OR V6 double cab
    LED headlights, TRD PRO grill, Spacer kit 2 in lift front
    Looked around the forum a little bit but was not able to find any posts about this topic. I have been looking for somewhere to take my new Tacoma. Holy Jim has been closed and probably will never re-open. I am looking for something moderately easy at first, no 4x4 but I do have a Locker. Any suggestions are helpful.
  2. Dec 10, 2019 at 1:41 PM
    Samus
    Samus Horror comics. Camping. Jalapenos. @Es_Ayy_Em
    Sam.I.Am
    SoCal
    2019 SR
    SOS sliders, & window stickers for +2 HP each
    Try using TrailsOffroad or Gaia GPS! TO ranks the trails from Easy - Severe and has waypoint locations, pics, sometimes videos, usually a full write-up so you know what you're getting yourself into. Gaia is great as well because you can use the layers to look for USFS roads and sat maps to check terrain. I've mainly been south and east, about 2-3 hours (from north county SD) you'll find Corral Canyon, Pine Valley, Superstition Mtn, Ocotillo, Lusardi Truck Trail, Upper Santa Ysabel, Orosco Truck Trail... A bit farther north is Nate Harrison Grade near Palomar Mtn. I haven't gone to Big Bear and Lake Arrowhead areas yet but I know there's a crap ton up there. Pilot Rock, Gorman as well. Go to the Southern California regional forums and you'll find meetups and trips to join!
  3. Dec 10, 2019 at 1:46 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Drive a couple hours east and the options are endless...tons of trails around the Lake Arrowhead and Big Bear area. Also Cleghorn, Pilot Rock, Rowher Flats/Drinkwater Flats a bit further north as well as Gorman OHV. Out in the desert you have countless options too, this time of year is best for those trails. Redrock Canyon, Johnson Valley, Ocotillo Wells, etc.
    Tainted likes this.
  4. Dec 11, 2019 at 2:42 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    ^^^what they said. I think TrailsOffraod would be the easiest for you. Just sign up so you get all the info.
  5. Dec 14, 2019 at 9:25 AM
    danbarone1994
    Daniel
    I will check out TrailsOffroad first. Anyone here local to the South Orange County area?
  6. Dec 30, 2019 at 2:39 PM
    Jooeee!
    Jooeee! Active Member
    Joe
    2002 TRD Black Tacoma
    OC Cali!
    Gorman OHV is great. All trails are listed from easy to hard.
  7. Jan 4, 2020 at 8:26 PM
    Rx7fighter
    Rx7fighter Active Member
    Derick
    2020 Voodoo Blue Off Road
    Modjeska Canyon/Santiago Peak is open
  8. Jan 4, 2020 at 8:34 PM
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    Is Silverado canyon open? I check frequently and its hit or miss for me. Sometimes its open, sometimes not. At least I think its called that... Its I think the second last left before cooks corner on ur way to holy jim. If your coming from irvine lake.
  9. Jan 4, 2020 at 9:13 PM
    Rx7fighter
    Derick
    It was open 3 weeks ago, it maybe muddy now since it’s been raining and foggy lately.
  10. Jan 26, 2020 at 6:43 AM
    greymachine
    greymachine @taupetacoma
    SoCal
    19 Quicksand TRDOR 4x4 DCSB
    This site is usually up to date on closure status of the local trails: https://www.fs.usda.gov/detailfull/cleveland/alerts-notices/?cid=stelprdb5340229
    Unless it's raining (or about to rain, or rained less than a week ago) Maple Springs, Bedford Motorway and North Main Divide between Santiago Peak and Sierra Peak are open. Indian Truck Trail and North Main Divide between Santiago Peak and Ortega Hwy will probably be closed for a while still. They were burned in the Holy Fire in 2018 and they're likely waiting for vegetation to grow back before reopening to the public, for fear of people roaming off-trail.
    2WD friendly, other than the last bit of trail to the end of Santiago Peak past the antennas. You'll know when you see it...
