Off Road tow hook bolt-on to an SR?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by not a charger, Nov 22, 2023.
  1. Nov 22, 2023 at 8:13 AM
    not a charger
    not a charger [OP] Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    Will the factory tow hook that mounts to the right frame rail bolt on to an SR?
  2. Nov 22, 2023 at 8:27 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    The front 2 factory hooks are for "towing it" on/off a car carrier, not on-road recovery. Factory hooks connect to weaker part of the edge of the frame, not the solid frame. This one mounts to the stronger part of the frame, and "breaks away" in a front impact to separate from the frame and not twist it unsafely:https://www.4wheelparts.com/p/arb-recovery-point-2823010/_/R-BHWQ-2823010
  3. Nov 22, 2023 at 11:26 AM
    not a charger
    NE Ohio
    I'll take a look at that. Thank you. I knew about that regarding the hook welded to the end of the left frame rail. I thought the off-road models had a different hook that bolts on to the end of the right frame rail?
    BC Hunter likes this.
  4. Nov 22, 2023 at 11:56 AM
    RichochetRabbit
    Level, non-bumpy, easy towing, maybe. The ARB mounts to frame-proper instead of the part of the frame the body panels use.
  5. Nov 22, 2023 at 12:48 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Yes the OR and Pro have a beefier hook that bolts on. The ARB recovery point bolts to the same location but also to some additional locations to get to a 17k rating. The ARB recovery point is likely overkill for most people, but it is the only rated recovery point that I am aware of.
    Someone once posted a reply from a ARB rep that explained that the ARB summit bumper recovery points were good enough for winching but not for momentum based recoveries where they considered 17k to be the safe point, because of the design of the Tacoma frame horns. Because of that, ARB developed their recovery point.
    In any case, yes I believe can bolt the OR/Pro hook onto an SR. You might need to remove the chin strap to access it though.
    I’ve made use of mine several times, including being recovered from partially frozen mud up to the frame with a 20k winch.
  6. Nov 22, 2023 at 1:03 PM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    Hey OP, I’ve got one listed in the BST threads that I’ll give you, if you determine it’ll work. You pay shipping.
    It was a takeoff my 21 OR when I put bumper and winch on.
  7. Nov 22, 2023 at 2:57 PM
    not a charger
    NE Ohio
    I'll take it! Thank you!
  8. Nov 22, 2023 at 8:28 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    make sure you paint it to get points at the mall
  9. Nov 22, 2023 at 8:40 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    I have an OR take off hook on my 21 SR, it bolted up fine
  10. Nov 23, 2023 at 5:14 AM
    not a charger
    NE Ohio
    You think yellow will draw enough attention? Or should I go lime green?
    RIX TUX[QUOTED] and Speedfreak like this.
  11. Nov 23, 2023 at 5:20 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Hot Pink is the correct answer!:D
  12. Nov 23, 2023 at 6:01 AM
    BillyE
    BillyE Well-Known Member
    FYI—it takes longer bolts also.
    Finn-2187 and not a charger[OP] like this.
