Off-Road Tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomeDude&Tacoma, Apr 4, 2023.
  1. Apr 4, 2023 at 8:50 AM
    SomeDude&Tacoma
    SomeDude&Tacoma [OP] Member
    MIke
    2023 Tacoma TRD Sport
    Roof Rack, bull bars, turning lights, and pod lights
    I have a stock 23 tacoma trd sport, with stock rims what would be a good off-road tire for them? Dont care about the price I just care about quality and it fits on the stock rims and height of the truck.
  2. Apr 4, 2023 at 9:00 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Apr 4, 2023 at 9:01 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    There are a lot of great options. How “off road” though? The more aggressive for off roading, the worse everything else will be.
    My personal take is that these trucks are best off with tires less than 50lbs. If you’re just looking to modestly increase off road capabilities, I recommend 255/75r17 or 265/70r17 in a standard all terrain flavor. These won’t weigh too much or affect on road performance too much, but will give a bit better angles.
    I have run a lot of tires and I personally really like my Nokian Outpost ATs.
    rainsux likes this.
  4. Apr 4, 2023 at 9:05 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Throwing my 2 cents in for Goodyear Duratracs. If you go to 265/70r17 you will get a 1 inch taller tire that will still fit. You can get C or E, but I'd stick with C unless you tow a ton, haul heavy, or are doing some offroading where you want a tougher tire. Duratracs also have the three peak rating, so that's a big plus.
    hooliganrick and LkdTaco like this.
  5. Apr 4, 2023 at 9:09 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Is this just for looks or do you have off-road terrain that needs tackled?
    What does this terrain consist of, sand, mud, snow, dirt, gravel, rocks, etc?
    Chew and YF_Ryan like this.
  6. Apr 4, 2023 at 9:18 AM
    2019 TRD Off Road
    Duratracs may have good traction, but are not particularly tough tires. Lots of reports of busted side walls.
    TS4x4 likes this.
  7. Apr 4, 2023 at 9:46 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Duratracs are more of a hauling tire and an all around mild OR tire imo instead of true dedicated heavy OR tire. Great tires tho
  8. Apr 4, 2023 at 9:52 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    265/70/17(31x10.4)
    275/70/17(32x10.8)
    255/80/17 (33x10)
    Ant brand name tire will be good to go.
    Dkurtz42 likes this.
  9. Apr 4, 2023 at 9:56 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Since off-road can mean anything from grass fields to mud pits to rock crawling it's hard to give you a useful answer. Something like a Cooper Rugged Trek is an aggressive AT in my book and should do well in a wide variety of conditions.
    LeakyAC likes this.
  10. Apr 4, 2023 at 10:10 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I have very much enjoyed my General Grabber ATX’s. But like the others have said, that’s an extremely vague question.
    Do you need a mud tire? An all terrain? A hybrid? Are you going to be in the mud, sand, gravel, dirt, snow? We would need more info to give you a good answer.
  11. Apr 4, 2023 at 10:23 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Careful what you ask for... LoL!
    I'm running Falken Wildpeaks AT3Ws. I like them much better than BFGs. They suit my needs.
  12. Apr 4, 2023 at 11:09 AM
    YF_Ryan
    Kent, WA
    I just like them as a good all around tire. I'm not doing anything I'd think is crazy, but many people probably think I'm nuts for the weight I carried on the SLs and the terrain I've driven on setup like that. Maybe I've been lucky. That and I'm not looking for an indestructible tire for hardcore wheeling, specially now that I'm carrying a house.
    jackn7 and LkdTaco like this.
  13. Apr 4, 2023 at 11:18 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    I really like my (insert whatever brand of tire poster owns here). They are great because I bought them and have them on my truck.
    Conclusion: You will love whatever brand of tire you end of buying.
    Chew, whatstcp, jackn7 and 1 other person like this.
  14. Apr 4, 2023 at 2:05 PM
    2019 TRD Off Road
    I have used BFGs, Toyo AT3s, Grabber ATX, Nokian Rotiiva, Nokian Outpost AT, Cooper AT3, Cooper STMaxx and more. My conclusion: All modern name brand tires are really good.
    At any given comparable level of tread “aggressiveness” the differences are minor. Pick the one that suits your needs at the right price.
  15. Apr 4, 2023 at 2:13 PM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    Facts
    Junkhead likes this.
  16. Apr 4, 2023 at 5:32 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I agree with the above about tread. But I've personally found big differences in quality between brands (even among the majors)...
    I've had 4 sets of BFGoodrich, two sets of Goodyear, three sets of Toyo, one set of Generals over the last three decades on various vehicles.
    Of all those the Toyos have had the best quality, they actually are infact round and balance very well... BFG and General are about tied for a close 2nd. Goodyear (all of them) were the worst, by far. Goodyear never again for me.
  17. Apr 4, 2023 at 6:17 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    I will still never understand the issues I hear about goodyear on here. I have had 4 sets of duratracs and they are still my favorite all round A/T tire yet. Summer winter snow slush mud highway. Never had an issue with balancing or punctures and the last 2 sets were thoroughly used off road.
    Junkhead and LkdTaco like this.
  18. Apr 4, 2023 at 7:00 PM
    waylork
    waylork Active Member
    2021 Tacoma SR5 4x4
    just picked up some Discount Tire Pathfinder A/T's for $168 per tire. aggressive tires, quiet on the road. Gonna take them off road this weekend. will report back. they look sick, didnt break the bank, and youtube seems to like them. i did lose like 3-4 MPG, though. worth it for the look.
    atc250r and RIX TUX like this.
  19. Apr 5, 2023 at 3:49 AM
    atc250r
    Orange County, NY
    Now that I lifted my truck the 265/70/17's look. A little small and I was eyeing those up in 285/70/17.
  20. Apr 5, 2023 at 9:02 AM
    wayne0
    wayne0 Well-Known Member
    Facts, Shmacks. OK, you're right.
