Off-Road Tips and Gear List
Discussion in 'Off-Roading & Trails' started by Agent475, Sep 26, 2008.
  1. Sep 26, 2008 at 12:41 PM
    Agent475
    Agent475 [OP] "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    I was doing some research on off-roading today and I came across several lists of off-roading gear that I thought would be useful to everyone here… Maybe we can make this a sticky tcBob?
    Basic Tips
    • Always travel in groups of 2 or more vehicles
    • Always alert someone back home where you are going and when you expect to return
    • Take at least a basic supply of tools and gear (see The Basic, Minimal Off-road Checklist)
    25 Top Tips To Do Before Going Off-road
      1. Check the Basics - Check all your fluids -coolant, oil, windshield washer fluid, power steering fluid, brake fluid, ATF, differentials, etc. Make sure there are no leaks, everything is at the proper level, and carry extra fluids just in case. Also check the air filter and the air filter box for debris. Also, if you are aware of any mechanical or electrical problems with your 4x4, repair them before hand.
      2. Check the Tires - Check the condition of your tires, including the spare. Be sure they are all inflated to the proper highway speed pressures. Take note of your tread and think about the terrain you will be traveling on. Are you ready for that deep mud hole with that tread?
      3. Ball Joints - Check all your ball joints, tie rods ends and wheel bearings by jacking up and securing the front of your 4x4. Grab the tire by the and at the top and bottom, and check for any excess movement by rocking the wheel in and out. Do the same by rocking the tire side to side. Any excessive free play should be checked out by a qualified mechanic. Also check the rear in the same manner. In solid rear axles you're checking for worn bearings and other damage.
      4. Shocks - Check your shocks for signs of leakage or damage or just plain worn out. Your going to need those shocks.
      5. Plan the Trip / Inform Others - Tell those that should know where you are going, when you are leaving and when you’ll be back. Let them know when they should start to worry about you if they haven’t heard from you. Give them contacts in case they need them. Prepare your trip. Have a map of the area you are going to and how you should get there (and home again).
      6. Weather - Watch the weather for the region you are visiting and the route along the way. Be prepared with the appropriate clothing and protective gear (rain jacket, hats, sunglasses, lip balm, sunscreen). Pack extra clothing in case you get wet or it gets a little colder than expected. Even if you are not "planning" to stay the night, its good to have a sleeping bag. Its better to be over prepared than under prepared.
      7. Necessities and Nature's Calling - Bring a roll of toilet paper packed in a air tight zip-lock plastic bag. In fact, ALWAYS carry a roll in your vehicle. When you need it, you’ll thank yourself for putting it there.
      8. Communications to the World - Pack a cell phone and give it a full charge before departing. Pack the phone car adapter or the 120 volt charger along with a power inverter. When you're remote and off-road, you can still find a signal even if its atop a ridge or up a tree. Be aware that if your are out of signal range, your cell phone will be hunting for a signal and this will deplete your cell phone's battery quicker than just sitting in standby when in range.
      9. GPS Navigating - A handheld GPS is a great thing to have. Prices have come down to the point that if you spend any time in the woods or off the road, you should have one. Hand-held units are easy to operate and once you are familiar with it, it can be a valuable tool to get you places. Should a real emergency arise, you'll learn quickly how valuable they can be. Bring spare batteries in a zip-lock bag and a car adapter for the GPS unit.
      10. Communications Vehicle to Vehicle / Person to Person - Handheld Family Radio Service (FRS) walkie-talkies are very handy and inexpensive. They have great range and are very portable. Whether on foot or in the vehicles, it makes good sense to carry one. And communication can add to the fun and in the case of an emergency where the you need to temporarily split up the party, you do no want to be out of touch. If you have to separate, stay in range. CB Radio's also fall in this category but are less portable (most units stay with the vehicle) and the range is sometimes shorter than FRS (and the GMRS frequencies on more FRS radios) depending on the radio and the antennas.
      11. Food / Water - Bring plenty of food and drink. Even on the short trips. Bottled water, energy bars, and dried fruit, sports drinks, anything that has compact energy are good items to pack. Pack items that do not need refrigeration. Avoid salty foods such as chips and salsa, beef jerky, unless you have plenty to drink. And no, beer doesn't count. In fact it takes water to metabolize alcohol so the beer and liquor will dehydrate, not hydrate you. Alcohol is never a good idea when you have to think clearly.
      12. Top off the Gas - Fill the gas tank prior to every trip. When you reach your destination, top it off again before hitting the trail. The last thing you want to do is start worrying about running out of gas while off-road. Remember the One-Third/Two-Third Rule: Use one-third of a tank to get where you are going and save two-thirds for getting out. If your fuel tank doesn’t have the capacity for the off-road portion of the trip, carry extra fuel or re-think your route.
      13. Transporting Gas - Always carry your extra fuel outside the vehicle. Fuel containers have vents and gasoline fumes are explosive and toxic.
      14. Jumper Cables - Have a good set of jumper cables with heavy-gauge wire and quality connectors.
      15. Recovery Straps and Come-Alongs - Bring at least one recover strap, preferably 2 or more and make sure you have a place to hook it up on your vehicle front and rear. Also get a good come-along if you don't have a winch. A High-Lift jack also doubles as a come-along and a jack (and lots more). Its also good to have extra pieces of recover equipment such as a D-ring or two and a tree saver. If you have a winch, make sure you have winch related equipment such as a snatch block, gloves, tree saver, Pull-Pal, etc.
      16. Belts and Hoses - Check all your belts and hoses, and carry spares. The lower radiator hose is the one that usually gets damaged while off-roading, so ensure that you have a spare. Alternator/water-pump belts are the most important. Newer vehicles often use serpentine belts. While much less prone to failure, they can be difficult to change. The are also expensive, but carry one. Replacing an old serpentine belt and saving the original as a spare is a good idea.
      17. Jack - Make sure you have a working jack and know how to use it. A High-Lift jack is a great universal tool and also doubles as a come-along (and lots more).
      18. Spare for the Spare Tire - If you have room, carry a second spare wheel and tire. At the very least, carry a repair kit just in case. Nothing is worse than getting a second flat tire on the same trip.
      19. Cold Weather Wheeling - If there is even the remotest possibility of snow, or if you will be at high altitude, carry tire chains for all four wheels and know how to install them. Don’t forget the chain tensioners, which look like big rubber bands with hooks. Remember that the chain tensioners will deteriorate over time, so check them periodically for cracks and splits.
      20. Tool Kit - Carry a tool kit that covers the basics of your vehicle. Put your own together, don't use one of the Christmas gift kits that are junk in a pouch. Carry quality tools.
      21. First Aid - Carry a well equipped first-add kit.
      22. Emergency Kit - Carry an emergency kit that covers situation beyond first aid. This might include special medication, poison ivy treatment, etc.
      23. Flashlight - Carry a flashlight and an extra set of fresh batteries
      24. Blocks of Wood - Brink a few scraps of plywood measuring about about 10 to 12 inches square. You may need them to support your jack if you have to change a tire on the uneven ground. 2x4 or 4x4 blocks also come on handy.
      25. Lights and Markers - Make sure you headlights, taillights, and brake lights work. A ticket from local law enforcement can be a bummer. It’s a good idea to carry spare bulbs.
    Pre-departure Maintenance Checklist
    • Check engine oil
    • Check transmission oil
    • Check brake fluid
    • Check radiator coolant
    • Check windshield wiper fluid
    • Check fan belts
    • Check hoses
    • Check air cleaner
    • Check seat belts
    • Check tire air pressure (air up to recommended pressure for highway driving, air down at trail head, air up prior to trip home)
    • Check for tire wear or damage
    • Tighten drive shaft u-bolts
    • Check and tighten lug bolts
    • Check for frame cracks
    • Check brake pads & shoes (adequate braking pad material, in good condition and without contamination)
    • Check for loose bolts or nuts throughout vehicle
    • Grease all fittings (u-joints, steering)
    • Check gear oils: transfer case/differentials, replace if necessary
    • Check Winch for proper operation, check winch cable for kinks, frays or damage, straighten winch cable if necessary
    • Check shocks
    The minimal list is the basics that you should always carry in your vehicle when off-road. These items are good to have in the vehicle at all times.
    • First Aid Kit (See Safety and Survival below)
    • Basic Personal Essentials (water, food)
    • Spare Tire, Full Size
    • Jack and tire iron to change your tire
    • Tow strap
    • Tree saver
    • Come-alongs
    • Basic Tool Kit
    • Spare Key for vehicle
    Beyond the Basic Off-road Checklist
    What goes beyond the basic checklist are items that depend on many factors. Factors like what form of off-roading you will be doing, your driving style, the terrain you will encounter, how much room you have for packing gear, how remote you will be traveling, how long you will be gone as well as many other factors you should consider. However three primary things you should gear up for are Safety and Survival, Vehicle Recovery and Vehicle Breakage.
    Vehicle Recovery
    Recovery Items
    • Hilift Jack
    • Tow straps - 2 or more, 2 inch width or wider, 20 foot or longer
    • Tree saver
    • Come-along (one or more)
    • D-rings, Shackles
    • Shovel
    • Chainsaw and bar oil, 2 cycle engine oil, spare chain (can be handy in recover situations, as well as for trail clearing on wooded trails)
    • Winch Kit: tree strap, hi-lift jack, snatch block, pickle fork, shackle, gloves
    • Pullpal
    • Snow tire chains (if tires don't cut it)
    Tools
    Basic Tools
    Basic tools are the versatile, essential tool sets that consist of a variety of sizes and combinations of commonly used tools such as socket sets, wrench sets, Allen wrenches, Torx sets and screw drivers. Your tool sets should cover the variety of sizes found in your vehicle. Regardless of whether your vehicle is American made or an import 4x4, when it comes to socket sets and wrenches, it's sometimes wise to carry standard and metric socket since sometimes there are a mix of both standard and metric on custom vehicles not to mention helping a fellow 4wheeler.
    • Complete Socket Set with SAE (standard) and Metric with 3/8" and 1/2" drives. Deep and standard sockets.
    • Crescent, open end combination box wrenches SAE (standard) and Metric
    • Allen Wrenches
    • Torx sockets (especially if you own a Jeep)
    • Standard & Phillips screwdrivers, large, medium, small
    Versatile Tools
    Versatile tools are those that have many uses.
    • Large Hammer (a.k.a. the "BFH")
    • Pliers (various sizes)
    • Needle Nose Pliers
    • Vice Grips, various sizes
    • Large channel-lock Pliers
    • Pipe wrenches - having 2 medium of these can be useful for tie-rods.
    • Utility knife or razor blades
    • Crescent wrenches (medium & large)
    • A BIG pry bar or length of strong metal pipe, inside diameter of pipe large enough to slip over a wrench or socket drive for extra leverage.
    • Magnet
    Specialty Tools
    • Snap ring pliers
    • Air Pressure Gauge
    • Portable air pump
    • Jumper cables
    Additional Items
    Versatile Items
    • Duct Tape
    • Bailing wire
    • wood blocks - Useful as chock blocks, jacking platforms, ramps, suspension supports (for broken torsion bars)
    • Bungee cords, several in multiple sizes - good for securing gear, temporary repairs, etc.
    • Rope lengths
    • Super glue
    • Epoxy
    • Tie wraps
    • rags
    • Work Gloves, leather
    For the Vehicle
    • Engine Oil
    • Brake Fluid
    • Power steering fluid
    • Automatic transmission fluid
    • Coolant or Water
    • Bearing Grease
    • WD-40
    • Starter Fluid
    • Extra gas
    • Funnel, siphon hose
    Spare Parts / Repair Items
    • Lug Wrench
    • Extra Fan / serpentine belts
    • Hoses, fuel line, coolant hoses
    • Spare Tire
    • Tire repair kits, plugs
    • Extra Lug nuts, tire star wrench or lug key with key socket
    • Cotter pins / keys - various sizes
    • Valve stems, Valve stem remover
    • Nuts & bolts assorted standard and metric sizes
    • RTV or Hylomar HPF - form-a-gasket
    • Radiator stop leak - silver flakes in tube
    • Spare Hub (and hub fuses if applicable).
    • Electric fuel pump
    • Coil / electronic ignition
    • Spare Universal Joints (U-joints for drive shaft & axles)
    • Spare Drive Shaft (rear and front)
    • Extra spark plug wire (size of longest wire)
    • Spare points
    Electronics Repair Kit
    • Volt ohms meter (multimeter)
    • Wire cutters / wire crips / wire strippers (multi-tool)
    • Spare fuses of all sizes and types used in your vehicle
    • Electrical tape
    • Spare wire - lengths of various gauges
    • Spare switches
    • Spare relay if you use relays
    • crip on ends (male and female, various gauges)
    • Small pocket sized needle point blow torch (handy for soldering wire)
    • Flux core solder for repairs
    • Wiring Diagram of your vehicle
    Expanded List
    The Expanded list includes items for the extreme wheeler with tools and gadgets that you may want to consider if you are serious about off-roading.
    • Winch and Winch Accessories
    • Onboard Welder, welding supplies and welding gear
    • Onboard Air
    • Spare axles (rear left / right, front left / right)
    • Spare tie rod assemblies (tie rod, drag link, ball joints, ball joint nuts and cotter pins)
    • Spare Idler Arm
    • Parts that have broken twice before (if you can't carry it, you should have upgraded it)
    Camping List for Extended Stay or Remote Excursions
    • Maps, information about the area
    • Camera
    • Compass or GPS
    • Duct Tape
    • Flashlight
    • Propane Lanterns
    • Mosquito repellant
    • Lighter, matches
    • Firewood
    • A knife of some sort
    • Toilet paper
    • Towel
    • Water purification pills
    • Backpack/sacks
    • Cooler with beverages
    • Cooking Pans for breakfast
    • Paper plates
    • Paper towels
    • Folding camping chairs
    • Sleeping bag
    • Sleeping pad or air mattress
    • Stove or grill and fuel
    • Tarps, lots of tarps
    • Tent(s)
    • Bathing suit
    • Flip flops or swimming shoes (no bare feet while swimming)
    • Funky fishing hat
    • Hiking boots
    • Rain jacket
    • Sunglasses
    • Sunblock
    • Binoculars
    • Bottle opener
    • Cooler cup
    • Jacket
    • Pocket knife
    • Snacks
    • Trash bag
    • Water
    • Extra keys
    • Compass
    • Sunscreen
    • Hat
    • Sunglasses and/or goggles
    • Ice and ice chest or cooler
    • Camera, case, film and batteries
    • Maps: Sidekick Off Road Maps, state, county, Forestry, BLM Desert Access Guide, etc.
    Safety and Survival
    The First Aid Kit
    First aid kits come in many shapes and sizes. You can buy them, or you can make your own kit. Whether you buy a first aid kit or put one together, make sure it has all the items you may need. Include any personal items, such as medications.
    Here are suggestions for the contents of a first aid kit:
    • Activated Charcoal (use only if instructed by Poison Control Center)
    • Adhesive Tape
    • Antiseptic Ointment
    • Alcohol swabs, individually wrapped
    • Band-Aids (assorted sizes)
    • Blanket
    • Cold Pack
    • Disposable Gloves
    • Gauze Pads and Roller Gauze (assorted sizes)
    • Hand Cleaner
    • Plastic Bags
    • Scissors and Tweezers
    • Small Flashlight and Extra Batteries
    • Syrup of Ipecac (use only if instructed by Poison Control Center)
    • Triangular Bandage
    • Burnaid gel
    • Snake Bite kit
    • Disposable emergency blanket
    • Instant Cold pack
    • Instant Hot pack
    • Medications:
    • Anti-diarrhea medication, Tylenol ( fever reducer), Ibuprofen (Nuprin, Motrin, Advil) inflammation reduction, sprains bruises, etc, Benadryl for mild allergic reactions, Epinephrine in the form of an Epi Pen to treat more serious allergic reactions that might otherwise be fatal.
    Safety Items
    • Safety Glasses
    • Leather Gloves
    • Fire Extinguisher - Should be mounted in the vehicle in an easily accessible location.
    • Flares
    • Tarp
    • flashlights
    • matches / lighter
    • Water - At least one Gallon per person, per day if not more. Drier, hotter climates may require more. Remember: Alcohol doesn't hydrate. In fact alcoholic beverages dehydrate since it take more water to metabolize alcohol than the beverage contains. Plus it may cause you to require the above mentioned First Aid Kit.
    • Food - Bring food for twice the amount of time you are planning on being gone. Should you be delayed and have to spend a night out on the trail, you wont have to worry about going hungry. Good ideas for trail food: trail mix, beef jerky, fruits, dry/canned food, etc.
    • Extra Cloths - Nobody likes to sit in wet cloths or an extended period of time.
    • Personal items - This includes toilet paper, anti- microbial hand cleaner, etc
    • Sun block
    • Rain Jacket
    • Communication devices - Cell Phone, CB Radio, GMRS/FRS radios
    • Power inverter if necessary (e.g. Cell phone recharger, battery recharger for communication devices and camera)
    • Trash bags - Keep your trails clean
    • Compass or GPS
    • Water purification tablets
    Survival - Seasonal Specific
    Winter
    · Extra clothing
    · Warm outer layers (jacket, wind breaker)
    · Head gear (warm hat, hooded jacket)
    · Emergency blanket (compact survival type)
    Summer
    · Sun Block
    · Insect repellant
    · Sunglasses
    SJmannix, Brie, Romaneo and 18 others like this.
  2. Sep 26, 2008 at 3:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Sep 29, 2008 at 7:33 AM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    Great point!
  4. Apr 17, 2009 at 2:30 PM
    tufftoy2000
    tufftoy2000 New Member
    2000 SR5 4WD
    Custom wheels, 2 inch leveling kit
    Hey, i have a 2000 tacoma 4wd. I was wondering if anyone knows if s skyjacker 3 inch suspension lift will bolt on with my 2 inch leveling kit
  5. Apr 20, 2009 at 5:17 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    yes very important i went on powerlines and got a very expensive ticket
    planesane likes this.
  6. Sep 7, 2009 at 11:06 AM
    Paul Graves
    Paul Graves Paul
    Paul
    Denver
    09 Tacoma 4X4 TRD
    Thanks for the post. A very complete list. It has helped me alot.
  7. Nov 4, 2010 at 2:46 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    THANK YOU
  8. Jan 1, 2011 at 3:19 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Great thread. well done.
  9. Jan 1, 2011 at 3:23 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    wait really? is this relevant to the thread?
    just to answer- no never stack lifts.
  10. Jan 19, 2011 at 5:53 PM
    sloancallaway
    sloancallaway Well-Known Member
    Sloan
    Spruce Grove Alberta Canada
    sub'd I almost asked this very question...
  11. Jan 19, 2011 at 5:55 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    A 2m Radio, they can be used to call for help 50+ miles away when cell phones dont work.
  12. Jan 31, 2011 at 10:23 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Man if I had to carry all that stuff I would need a duce and quarter, I would be lucky to move my V6 baby taco with that much stuff packed on her back, and I'm not sure I could fit it all. I'm just kickin it around a bit. This is a great thread, well thought out and depending on where your going and what your doing you pare down the list. Thanks for the post.
  13. May 8, 2011 at 3:58 PM
    navysealboy93
    navysealboy93 Well-Known Member
    Zach
    Fort Lewis, WA
    Isuzu Trooper
    ARB front bumper, wagon wheels, 235/85 wranger's, OME 1.5 in. lift and Dakar springs.
    :popcorn:
    Good stuff.
  14. Aug 7, 2011 at 9:53 AM
    Bawlzdeep
    Bawlzdeep I'm dropping the hammer
    Jon
    Penn Valley CA
    S/C'd 97 4Runner 5spd
    lift, tires, winch, 5spd swap, dual lockers..
    Overkill! Unless you're referring to the Zombie Apocalypse.
    Cooler with a 1each case o' beer, 2each bags'a ice, iPhone and my SR40, good to go.
  15. Aug 7, 2011 at 10:51 AM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    AWESOME FIND! This is exactly what I have been looking myself.
    mark it eight dude
  16. Aug 7, 2011 at 1:29 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    On that list, besides the obvious stuff... an air gauge and quick air pump will be your biggest help after your tires and 4WD... Lowering the air pressure will get you unstuck in most situations.
  17. Aug 7, 2011 at 1:33 PM
    300rem7
    300rem7 Well-Known Member
    Arlington, Texas
    2011 TRD Offroad 4x4
    Sticky
  18. May 14, 2012 at 3:01 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I just took the time to compile what I always take off-roading into an actual check list to use every time before heading out, so I thought I'd share with everyone:
    From Home:
    □ Tent
    □ Sleeping Bag
    □ Air Mattress
    □ Air pump
    □ EZ Up
    □ Chairs
    □ Ice Chest
    □ Flashlight
    □ Flashlight Charger
    □ Phone Charger
    □ Pillows
    □ Tools
    o Mech. Tools
    o Electrical Tools
    □ Spare Tires
    □ Jumper Cables
    □ Recovery Strap
    □ D-Rings
    □ Toilet Paper
    □ Tie Downs and Ratchet Straps
    □ Jack
    □ Race Radio
    □ CB Radio
    □ Walkie Talkies and Charger
    □ Fuel Jug
    □ Air Compressor for tires
    □ Lug nut sockets
    □ Torque Wrench
    □ Bypass adjustment tools
    □ Warm Clothes
    □ Cool Clothes
    □ Hat
    □ Sunglasses
    □ Sun Screen
    □ AAA Card
    □ Zip ties
    □ First Aid Kit
    □ Wood Blocks
    □ Gloves
    □ Bucket
    From Store:
    □ Water
    □ Food
    □ Energy Drinks
    □ Alcohol
    □ Ice
    □ Fire Wood
    Priv16 likes this.
  19. May 14, 2012 at 3:09 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    A great list for sure :thumbsup: and i normaly carry about 90% of whats ln fhat list when out and about .. one thing that is not on the list is a bucket or somesort of catch basin for leaky fluids or to place under the vehicle during a messy trail repair. I would also suggest a box of latex gloves to help with keeping clean while doing a trail repair :cookiemonster:
    tfro33 likes this.
  20. May 14, 2012 at 3:11 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Sub for future reference
